Very very long code but down towards the bottom is Case1; which is where i've put the code with flags that calls void doLcdMsg() & void doLcdMsg2(). However when I click into this case it only displays the first graphic when it should rotate between the 2 graphics every 10 seconds. If I click the button again is takes me to the next case so good news is no blocking going on.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
unsigned long switchMillis = 0;
unsigned long interval = 10000; //10 seconds for each lcd screen
byte count = 0;
boolean firstScreenFlag = false;
boolean secondScreenFlag = false;
const int buttonPin = 1;
int buttonPushCounter = 0; // counter for the number of button presses
boolean buttonState = LOW; // current state of the button
boolean lastButtonState = LOW; // previous state of the button
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
const unsigned char ThreeZeroTwo [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc1, 0xf0, 0x78,
0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe3, 0xf8, 0xfc,
0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x77, 0x1d, 0x8e,
0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x86,
0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x30, 0x1f, 0xcc, 0x19, 0xfc, 0xc1, 0xfc, 0xc3, 0x3f, 0x80, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x30, 0x3f, 0xec, 0x1b, 0xfe, 0xc3, 0xfe, 0xc3, 0x7f, 0xc0, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x30, 0x38, 0xec, 0x1b, 0x8e, 0xc3, 0x8e, 0xc3, 0x71, 0xc0, 0x00, 0x76, 0x0c, 0x06,
0x00, 0x00, 0x3f, 0x30, 0x6e, 0x3b, 0x06, 0xc3, 0x06, 0xc3, 0x60, 0xc0, 0x03, 0xe6, 0x0c, 0x0e,
0x00, 0x00, 0x3f, 0x30, 0x67, 0x73, 0x06, 0xc3, 0x06, 0x66, 0x60, 0xc0, 0x03, 0xe6, 0x0c, 0x1c,
0x00, 0x00, 0x30, 0x30, 0x61, 0xc3, 0x06, 0xc3, 0x06, 0x66, 0x7f, 0xc0, 0x00, 0x76, 0x0c, 0x38,
0x00, 0x00, 0x30, 0x30, 0x61, 0xc3, 0x06, 0xc3, 0x06, 0x66, 0x7f, 0x80, 0x00, 0x36, 0x0c, 0x70,
0x00, 0x00, 0x30, 0x30, 0x67, 0x73, 0x06, 0xc3, 0x06, 0x66, 0x60, 0x00, 0x00, 0x36, 0x0c, 0xe0,
0x00, 0x00, 0x30, 0x30, 0x6e, 0x33, 0x06, 0xc3, 0x06, 0x3c, 0x60, 0x00, 0x00, 0x36, 0x0d, 0xc0,
0x00, 0x00, 0x30, 0x30, 0x6c, 0x1b, 0x06, 0xc3, 0x06, 0x3c, 0x60, 0xc0, 0x18, 0x36, 0x0d, 0x80,
0x00, 0x00, 0x30, 0x38, 0xec, 0x1b, 0x8e, 0xc3, 0x8e, 0x3c, 0x71, 0xc0, 0x1c, 0x77, 0x1d, 0x80,
0x00, 0x00, 0x30, 0x3f, 0xec, 0x1b, 0xfe, 0xfb, 0xfe, 0x18, 0x7f, 0xc0, 0x0f, 0xe3, 0xf9, 0xfe,
0x00, 0x00, 0x30, 0x1f, 0xcc, 0x19, 0xfe, 0x79, 0xfc, 0x18, 0x3f, 0x80, 0x07, 0xc1, 0xf1, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char ThreeZeroFour [] PROGMEM = {
0x00, 0x00, 0x00, 0x03, 0xf3, 0x01, 0xfc, 0x00, 0x00, 0x30, 0x00, 0x00, 0x07, 0xc1, 0xf0, 0x1c,
0x00, 0x00, 0x00, 0x07, 0xfb, 0x03, 0xfe, 0x00, 0x00, 0x30, 0x00, 0x00, 0x0f, 0xe3, 0xf8, 0x3c,
0x00, 0x00, 0x00, 0x06, 0x1b, 0x03, 0x06, 0x00, 0x00, 0x33, 0x00, 0x00, 0x1c, 0x77, 0x1c, 0x3c,
0x00, 0x00, 0x00, 0x06, 0x03, 0x03, 0x06, 0x00, 0x00, 0x33, 0x00, 0x00, 0x18, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x00, 0x06, 0x03, 0x03, 0x06, 0x00, 0x00, 0x32, 0x3e, 0x00, 0x00, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x00, 0x06, 0x03, 0x03, 0x06, 0x7e, 0x61, 0xb0, 0x7f, 0x00, 0x00, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x00, 0x06, 0x03, 0x03, 0x06, 0xff, 0x61, 0xb0, 0x63, 0x00, 0x00, 0x36, 0x0c, 0xcc,
0x00, 0x00, 0x00, 0x06, 0x03, 0x03, 0x06, 0xc3, 0x61, 0xb0, 0x60, 0x00, 0x00, 0x76, 0x0c, 0xcc,
0x00, 0x00, 0x00, 0x07, 0xf3, 0xc3, 0xfe, 0x03, 0x61, 0xb0, 0x60, 0x00, 0x03, 0xe6, 0x0c, 0xcc,
0x00, 0x00, 0x00, 0x03, 0xfb, 0xc3, 0xfc, 0x03, 0x61, 0xb0, 0x60, 0x00, 0x03, 0xe6, 0x0d, 0x8c,
0x00, 0x00, 0x00, 0x00, 0x1b, 0x03, 0x00, 0x7f, 0x61, 0xb0, 0x7e, 0x00, 0x00, 0x76, 0x0d, 0x8c,
0x00, 0x00, 0x00, 0x00, 0x1b, 0x03, 0x00, 0xff, 0x61, 0xb0, 0x3f, 0x00, 0x00, 0x36, 0x0d, 0xff,
0x00, 0x00, 0x00, 0x00, 0x1b, 0x03, 0x00, 0xc3, 0x61, 0xb0, 0x03, 0x00, 0x00, 0x36, 0x0d, 0xff,
0x00, 0x00, 0x00, 0x00, 0x1b, 0x03, 0x00, 0xc3, 0x61, 0xb0, 0x03, 0x00, 0x00, 0x36, 0x0c, 0x0c,
0x00, 0x00, 0x00, 0x00, 0x1b, 0x03, 0x00, 0xc3, 0x61, 0xb0, 0x03, 0x00, 0x18, 0x36, 0x0c, 0x0c,
0x00, 0x00, 0x00, 0x06, 0x1b, 0x03, 0x00, 0xc3, 0x73, 0xb0, 0x63, 0x00, 0x1c, 0x77, 0x1c, 0x0c,
0x00, 0x00, 0x00, 0x07, 0xfb, 0xe3, 0x00, 0xff, 0x7f, 0xbc, 0x7f, 0x00, 0x0f, 0xe3, 0xf8, 0x0c,
0x00, 0x00, 0x00, 0x03, 0xf1, 0xe3, 0x00, 0x7d, 0x3f, 0x1c, 0x3e, 0x00, 0x07, 0xc1, 0xf0, 0x0c,
const unsigned char ThreeZeroFive [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x07, 0xf0, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x07, 0xc1, 0xf1, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x0f, 0xe3, 0xf9, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x06, 0x1c, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x1c, 0x77, 0x1d, 0x80,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x80,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x36, 0x0d, 0x80,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x78, 0xc1, 0xb0, 0x3c, 0x5e, 0x00, 0x00, 0x36, 0x0d, 0x80,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0xfc, 0xc1, 0xb0, 0x7e, 0x7f, 0x00, 0x00, 0x36, 0x0d, 0x80,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0xce, 0xc1, 0xb0, 0xe7, 0x73, 0x80, 0x00, 0x76, 0x0d, 0xf8,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf9, 0x86, 0xe3, 0xbc, 0xc3, 0x61, 0x80, 0x03, 0xe6, 0x0d, 0xfc,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf9, 0x86, 0x77, 0x3c, 0xc3, 0x61, 0x80, 0x03, 0xe6, 0x0c, 0x0e,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0xfe, 0x1c, 0x30, 0xc3, 0x61, 0x80, 0x00, 0x76, 0x0c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0xfc, 0x08, 0x30, 0xc3, 0x61, 0x80, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x80, 0x1c, 0x30, 0xc3, 0x61, 0x80, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x80, 0x77, 0x30, 0xc3, 0x61, 0x80, 0x00, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x86, 0xe3, 0xb0, 0xc3, 0x61, 0x80, 0x18, 0x36, 0x0d, 0x86,
0x00, 0x00, 0x00, 0x00, 0x06, 0x1d, 0xce, 0xc1, 0xb0, 0xe7, 0x61, 0x80, 0x1c, 0x77, 0x1d, 0xce,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0xfc, 0xc1, 0xbe, 0x7e, 0x61, 0x80, 0x0f, 0xe3, 0xf8, 0xfc,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf0, 0x78, 0xc1, 0x9e, 0x3c, 0x61, 0x80, 0x07, 0xc1, 0xf0, 0x78,
const unsigned char ThreeZeroEight [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc1, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe3, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x77, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x83, 0x3f, 0x80, 0x00, 0x00, 0x36, 0x0d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf9, 0x83, 0x7f, 0xc0, 0x00, 0x00, 0x76, 0x0c, 0xee,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf9, 0x83, 0x71, 0xc0, 0x00, 0x03, 0xe6, 0x0c, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x61, 0x83, 0x60, 0xc0, 0x00, 0x03, 0xe6, 0x0c, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x61, 0x83, 0x60, 0xc0, 0x00, 0x00, 0x76, 0x0c, 0xee,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x31, 0x83, 0x7f, 0xc0, 0x00, 0x00, 0x36, 0x0d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x31, 0x83, 0x7f, 0x80, 0x00, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x19, 0x83, 0x60, 0x00, 0x00, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x19, 0xc7, 0x60, 0xc0, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0xff, 0x71, 0xc0, 0x00, 0x1c, 0x77, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0xff, 0x7f, 0xc0, 0x00, 0x0f, 0xe3, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x3f, 0x80, 0x00, 0x07, 0xc1, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char ThreeOneZero [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x30, 0x61, 0x8c, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x30, 0x61, 0x8c, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x03, 0xe0, 0xe0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x30, 0x61, 0x8c, 0x00, 0x60, 0x00, 0x00, 0x00, 0x07, 0xf1, 0xe0, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x60, 0x00, 0x00, 0x00, 0x0e, 0x3b, 0xe1, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x60, 0x00, 0x00, 0x00, 0x0c, 0x1b, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x61, 0x8c, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x60, 0xfe, 0x7f, 0x80, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x3f, 0xed, 0x8c, 0x00, 0x61, 0xff, 0x7f, 0xc0, 0x00, 0x38, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x3f, 0xed, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x01, 0xf0, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x01, 0xf0, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x00, 0x38, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x0c, 0x18, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0x8c, 0x00, 0x61, 0x83, 0x60, 0xc0, 0x0e, 0x38, 0x61, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6d, 0xef, 0x00, 0x61, 0xff, 0x7f, 0xc0, 0x07, 0xf3, 0xfc, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x30, 0x6c, 0xe7, 0x00, 0x60, 0xfe, 0x7f, 0x80, 0x03, 0xe3, 0xfc, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char ThreeZeroOneA [] PROGMEM = {
0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0xfc, 0xc0, 0x01, 0x80, 0x00, 0x00, 0x03, 0xe0, 0xe0, 0x7c,
0x00, 0x00, 0x7f, 0x80, 0x00, 0x01, 0xfe, 0xc0, 0x01, 0x86, 0x00, 0x00, 0x07, 0xf1, 0xe0, 0xfe,
0x00, 0x00, 0x61, 0xc0, 0x00, 0x01, 0x86, 0xc0, 0x01, 0x86, 0x00, 0x00, 0x0e, 0x3b, 0xe1, 0xc7,
0x00, 0x00, 0x60, 0xc0, 0x00, 0x01, 0x80, 0xc0, 0x01, 0x80, 0x00, 0x00, 0x0c, 0x1b, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x67, 0xc1, 0x80, 0xc0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x6f, 0xe1, 0x80, 0xc1, 0xf9, 0x86, 0x7e, 0x3f, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x6c, 0x61, 0x80, 0xc3, 0xfd, 0x86, 0xff, 0x7f, 0x80, 0x18, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x6c, 0x01, 0x80, 0xc3, 0x0d, 0x86, 0xc3, 0x61, 0x80, 0x38, 0x61, 0x83,
0x00, 0x00, 0x7f, 0x98, 0x6c, 0x01, 0xfc, 0xf0, 0x0d, 0xe6, 0xc3, 0x61, 0x81, 0xf0, 0x61, 0x83,
0x00, 0x00, 0x7f, 0x98, 0x6c, 0x00, 0xfe, 0xf0, 0x0d, 0xe6, 0xc3, 0x61, 0x81, 0xf0, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x6f, 0xc0, 0x06, 0xc1, 0xfd, 0x86, 0xc3, 0x61, 0x80, 0x38, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x67, 0xe0, 0x06, 0xc3, 0xfd, 0x86, 0xc3, 0x61, 0x80, 0x18, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x60, 0x60, 0x06, 0xc3, 0x0d, 0x86, 0xc3, 0x61, 0x80, 0x18, 0x61, 0x83,
0x00, 0x00, 0x60, 0xd8, 0x60, 0x60, 0x06, 0xc3, 0x0d, 0x86, 0xc3, 0x61, 0x8c, 0x18, 0x61, 0x83,
0x00, 0x00, 0x61, 0xdc, 0xec, 0x61, 0x86, 0xc3, 0x0d, 0x86, 0xc3, 0x61, 0x8e, 0x38, 0x61, 0xc7,
0x00, 0x00, 0x7f, 0x8f, 0xcf, 0xe1, 0xfe, 0xfb, 0xfd, 0xf6, 0xff, 0x61, 0x87, 0xf3, 0xfc, 0xfe,
0x00, 0x00, 0x7f, 0x07, 0x87, 0xc0, 0xfc, 0x79, 0xf4, 0xf6, 0x7e, 0x61, 0x83, 0xe3, 0xfc, 0x7c,
const unsigned char SchoolService [] PROGMEM = {
0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0xc0, 0x0f, 0x00, 0x30, 0x00, 0x00, 0xc0, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0x00, 0x80, 0x1f, 0x80, 0x30, 0x00, 0x00, 0xc0, 0xfc, 0x00, 0x00, 0x06, 0x00, 0x00,
0x00, 0x03, 0x83, 0xe0, 0x39, 0xc0, 0x30, 0x00, 0x00, 0xc1, 0xce, 0x00, 0x00, 0x06, 0x00, 0x00,
0x00, 0x01, 0x07, 0xf0, 0x30, 0xc0, 0x30, 0x00, 0x00, 0xc1, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0xc5, 0xd8, 0x38, 0x0f, 0x36, 0x1e, 0x3c, 0xc1, 0xc0, 0x79, 0xb3, 0x36, 0x78, 0xf0,
0x00, 0x0b, 0xad, 0xcc, 0x1e, 0x1f, 0xbf, 0x3f, 0x7e, 0xc0, 0xf0, 0xfd, 0xfb, 0x36, 0xfd, 0xf8,
0x00, 0x0b, 0x95, 0xc0, 0x0f, 0x19, 0xb9, 0xb3, 0x66, 0xc0, 0x78, 0xcd, 0xcb, 0x36, 0xcd, 0x98,
0x00, 0x03, 0x81, 0xc0, 0x01, 0x98, 0x31, 0xb3, 0x66, 0xc0, 0x0c, 0xfd, 0x81, 0x26, 0xc1, 0xf8,
0x00, 0x02, 0x81, 0x40, 0x00, 0xd8, 0x31, 0xb3, 0x66, 0xc0, 0x06, 0xfd, 0x81, 0xe6, 0xc1, 0xf8,
0x00, 0x0e, 0x81, 0x40, 0x30, 0xd8, 0x31, 0xb3, 0x66, 0xc1, 0x86, 0xc1, 0x81, 0xe6, 0xc1, 0x80,
0x00, 0x08, 0x87, 0x40, 0x39, 0xd9, 0xb1, 0xb3, 0x66, 0xc1, 0xce, 0xcd, 0x80, 0xc6, 0xcd, 0x98,
0x00, 0x00, 0xc4, 0x40, 0x1f, 0x9f, 0xb1, 0xbf, 0x7e, 0xf0, 0xfc, 0xfd, 0x80, 0xc6, 0xfd, 0xf8,
0x00, 0x00, 0x00, 0x60, 0x0f, 0x0f, 0x31, 0x9e, 0x3c, 0x70, 0x78, 0x79, 0x80, 0xc6, 0x78, 0xf0,
const unsigned char Pic [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0xe6, 0x00, 0x00, 0x00, 0x6d, 0x8c, 0x00, 0x00, 0x00, 0x7f, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0xf6, 0x00, 0x00, 0x00, 0x6d, 0x8c, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x00, 0x00, 0x06, 0x30, 0x00, 0x00, 0x00, 0x61, 0x8c, 0x00, 0x00, 0x01, 0xe0, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x06, 0x30, 0x00, 0x00, 0x00, 0x61, 0x8c, 0x00, 0x00, 0x03, 0xc0, 0x78, 0x00,
0x00, 0x00, 0x00, 0x06, 0x36, 0x78, 0xf1, 0xe3, 0xed, 0x8c, 0x00, 0x00, 0x03, 0x80, 0x38, 0x00,
0x00, 0x00, 0x00, 0x06, 0x36, 0xfd, 0xfb, 0xf7, 0xed, 0x8c, 0x66, 0x00, 0x07, 0x00, 0x1c, 0x00,
0x00, 0x00, 0x00, 0x07, 0xe6, 0xcd, 0x98, 0x36, 0x6d, 0x8c, 0x66, 0x00, 0x0f, 0xff, 0xfe, 0x00,
0x00, 0x00, 0x00, 0x07, 0xc6, 0xc1, 0x81, 0xf6, 0x6d, 0x8c, 0x66, 0x00, 0x0f, 0xff, 0xfe, 0x00,
0x00, 0x00, 0x00, 0x06, 0x06, 0xc1, 0x83, 0xf6, 0x6d, 0x8c, 0x66, 0x00, 0x0f, 0xff, 0xfe, 0x00,
0x00, 0x00, 0x00, 0x06, 0x06, 0xc1, 0x83, 0x36, 0x6d, 0x8c, 0x66, 0x00, 0x07, 0x00, 0x1c, 0x00,
0x00, 0x00, 0x00, 0x06, 0x06, 0xcd, 0x9b, 0x36, 0x6d, 0x8c, 0x66, 0x00, 0x03, 0x80, 0x38, 0x00,
0x00, 0x00, 0x00, 0x06, 0x06, 0xfd, 0xfb, 0xf7, 0xed, 0xef, 0x7e, 0x00, 0x03, 0xc0, 0x78, 0x00,
0x00, 0x00, 0x00, 0x06, 0x06, 0x78, 0xf1, 0xe3, 0xac, 0xe7, 0x3e, 0x00, 0x01, 0xe0, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0xff, 0xe0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x7f, 0xc0, 0x00,
0x00, 0x00, 0x03, 0xf0, 0x06, 0xc0, 0x3f, 0x00, 0x00, 0xc0, 0x7e, 0x00, 0x00, 0x1f, 0x00, 0x0c,
0x00, 0x00, 0x03, 0xf8, 0x06, 0xc0, 0x3f, 0x80, 0x00, 0xc0, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x03, 0x18, 0x00, 0xc0, 0x31, 0x80, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x03, 0x19, 0xe6, 0xc0, 0x31, 0x9e, 0x7c, 0xc3, 0xc7, 0x8f, 0x36, 0xc3, 0xcd, 0x8f,
0x00, 0x00, 0x03, 0x1b, 0xf6, 0xc0, 0x31, 0xbf, 0x7e, 0xc7, 0xef, 0xdf, 0xbf, 0xe7, 0xef, 0xcf,
0x00, 0x00, 0x03, 0xf0, 0x36, 0xc0, 0x3f, 0x33, 0x66, 0xc0, 0x6c, 0xd9, 0xbb, 0x76, 0x6e, 0x6c,
0x00, 0x00, 0x03, 0xe1, 0xf6, 0xc0, 0x3e, 0x3f, 0x66, 0xc3, 0xec, 0x1f, 0xb3, 0x37, 0xec, 0x6c,
0x00, 0x00, 0x03, 0x33, 0xf6, 0xc0, 0x33, 0x3f, 0x66, 0xc7, 0xec, 0x1f, 0xb3, 0x37, 0xec, 0x6c,
0x00, 0x00, 0x03, 0x33, 0x36, 0xc0, 0x33, 0x30, 0x66, 0xc6, 0x6c, 0x18, 0x33, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x03, 0x1b, 0x36, 0xc0, 0x31, 0xb3, 0x66, 0xc6, 0x6c, 0xd9, 0xb3, 0x36, 0x6c, 0x6c,
0x00, 0x00, 0x03, 0x1b, 0xf6, 0xf0, 0x31, 0xbf, 0x7e, 0xf7, 0xef, 0xdf, 0xb3, 0x37, 0xec, 0x6f,
0x00, 0x00, 0x03, 0x19, 0xe6, 0x70, 0x31, 0x9e, 0x7c, 0x73, 0xc7, 0x8f, 0x33, 0x33, 0xcc, 0x67,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char RR [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x06, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xc0, 0x33, 0xf9, 0xf8, 0x03, 0xf8, 0x06, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xe0, 0x33, 0xf9, 0x04, 0x03, 0x18, 0x00, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xf0, 0x33, 0x01, 0x04, 0x03, 0x18, 0x00, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xf8, 0x33, 0x01, 0x04, 0x03, 0x19, 0xe6, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xdc, 0x33, 0x01, 0x04, 0x03, 0x1b, 0xf6, 0xc0,
0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x02, 0x00, 0xce, 0x33, 0xf9, 0x04, 0x03, 0xf0, 0x36, 0xc0,
0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x02, 0x00, 0xc7, 0x33, 0xf9, 0xf8, 0x03, 0xe1, 0xf6, 0xc0,
0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x02, 0x00, 0xc3, 0xb3, 0x01, 0x40, 0x03, 0x33, 0xf6, 0xc0,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x02, 0x00, 0xc1, 0xf3, 0x01, 0x20, 0x03, 0x33, 0x36, 0xc0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x02, 0x00, 0xc0, 0xf3, 0x01, 0x10, 0x03, 0x1b, 0x36, 0xc0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x02, 0x00, 0xc0, 0x73, 0xf9, 0x08, 0x03, 0x1b, 0xf6, 0xf0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x03, 0xfc, 0xc0, 0x33, 0xf9, 0x04, 0x03, 0x19, 0xe6, 0x70,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x3f, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x3f, 0x80, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x31, 0x80, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x31, 0x9e, 0x7c, 0xc3, 0xc7, 0x8f, 0x36, 0xc3, 0xcd, 0x8f,
0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x31, 0xbf, 0x7e, 0xc7, 0xef, 0xdf, 0xbf, 0xe7, 0xef, 0xcf,
0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x3f, 0x33, 0x66, 0xc0, 0x6c, 0xd9, 0xbb, 0x76, 0x6e, 0x6c,
0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x3e, 0x3f, 0x66, 0xc3, 0xec, 0x1f, 0xb3, 0x37, 0xec, 0x6c,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x33, 0x3f, 0x66, 0xc7, 0xec, 0x1f, 0xb3, 0x37, 0xec, 0x6c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x33, 0x30, 0x66, 0xc6, 0x6c, 0x18, 0x33, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x31, 0xb3, 0x66, 0xc6, 0x6c, 0xd9, 0xb3, 0x36, 0x6c, 0x6c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x31, 0xbf, 0x7e, 0xf7, 0xef, 0xdf, 0xb3, 0x37, 0xec, 0x6f,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x31, 0x9e, 0x7c, 0x73, 0xc7, 0x8f, 0x33, 0x33, 0xcc, 0x67,
const unsigned char GWRRR [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x40, 0x60, 0x00, 0x03, 0xf0, 0x06, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7c, 0x60, 0xe0, 0xcf, 0xe0, 0x03, 0xf8, 0x06, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x60, 0xe0, 0xcf, 0xf0, 0x03, 0x18, 0x00, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc2, 0x31, 0xb1, 0x8c, 0x30, 0x03, 0x18, 0x00, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x31, 0xb1, 0x8c, 0x30, 0x03, 0x19, 0xe6, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x31, 0xb1, 0x8c, 0x30, 0x03, 0x1b, 0xf6, 0xc0,
0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x03, 0x1f, 0x1b, 0x1b, 0x0f, 0xe0, 0x03, 0xf0, 0x36, 0xc0,
0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x03, 0x1f, 0x1b, 0x1b, 0x0f, 0xc0, 0x03, 0xe1, 0xf6, 0xc0,
0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x01, 0x83, 0x1b, 0x1b, 0x0c, 0xe0, 0x03, 0x33, 0xf6, 0xc0,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x01, 0xc7, 0x0e, 0x0e, 0x0c, 0x60, 0x03, 0x33, 0x36, 0xc0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x00, 0xfe, 0x0e, 0x0e, 0x0c, 0x70, 0x03, 0x1b, 0x36, 0xc0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x7c, 0x04, 0x04, 0x0c, 0x30, 0x03, 0x1b, 0xf6, 0xf0,
0x00, 0x01, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x04, 0x04, 0x00, 0x00, 0x03, 0x19, 0xe6, 0x70,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x3e, 0x3f, 0x66, 0xc3, 0xec, 0x19, 0xb3, 0x36, 0x6c, 0x6c,
const unsigned char ChooChoo [] PROGMEM = {
0x00, 0x00, 0x00, 0x07, 0xc0, 0x1b, 0x07, 0xc0, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x00, 0x07, 0xe0, 0x1b, 0x07, 0xe0, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x00, 0x06, 0x60, 0x03, 0x06, 0x60, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x7f, 0xe6, 0x67, 0x9b, 0x06, 0x67, 0x9f, 0x31, 0xe3, 0xc7, 0x9b, 0x61, 0xe6, 0xcf,
0x00, 0x00, 0x7f, 0xe6, 0x6f, 0xdb, 0x06, 0x6f, 0xdf, 0xb3, 0xf7, 0xef, 0xdf, 0xf3, 0xf7, 0xef,
0x03, 0xe0, 0x3f, 0xc7, 0xc0, 0xdb, 0x07, 0xcc, 0xd9, 0xb0, 0x36, 0x6c, 0xdd, 0xbb, 0x36, 0x6c,
0x01, 0xc0, 0x3f, 0xc7, 0x87, 0xdb, 0x07, 0x8f, 0xd9, 0xb1, 0xf6, 0x0c, 0xd9, 0x9b, 0x36, 0x6c,
0x01, 0xc4, 0x3f, 0xc6, 0xcf, 0xdb, 0x06, 0xcf, 0xd9, 0xb3, 0xf6, 0x0f, 0xd9, 0x9b, 0xf6, 0x6c,
0x01, 0xce, 0x3f, 0xc6, 0xcc, 0xdb, 0x06, 0xcc, 0x19, 0xb3, 0x36, 0x0c, 0x19, 0x9b, 0x06, 0x6c,
0x01, 0xce, 0x3f, 0xc6, 0x6c, 0xdb, 0x06, 0x6c, 0xd9, 0xb3, 0x36, 0x6c, 0xd9, 0x9b, 0x36, 0x6c,
0x03, 0xff, 0xff, 0xc6, 0x6f, 0xdb, 0xc6, 0x6f, 0xdf, 0xbb, 0xf7, 0xef, 0xd9, 0x9b, 0xf6, 0x6f,
0x07, 0xff, 0xff, 0xc6, 0x67, 0x99, 0xc6, 0x67, 0x9f, 0x19, 0xe3, 0xc7, 0x99, 0x99, 0xe6, 0x67,
0x07, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x07, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xcc, 0xf1, 0xe0,
0x07, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e, 0xcd, 0xfb, 0xf0,
0x03, 0xff, 0xff, 0xe7, 0xec, 0x00, 0x0f, 0x83, 0xf0, 0x00, 0x60, 0x00, 0x66, 0xfd, 0x9b, 0x30,
0x00, 0x00, 0x00, 0x07, 0xe4, 0x00, 0x1f, 0xc3, 0xf0, 0x00, 0x60, 0x00, 0x60, 0xfd, 0x9b, 0x30,
0x00, 0x00, 0x71, 0xc1, 0x88, 0x00, 0x18, 0xc0, 0xc0, 0x00, 0x00, 0x00, 0x66, 0xcd, 0x9b, 0x30,
0x01, 0x8c, 0xfb, 0xe1, 0x80, 0x00, 0x18, 0xc0, 0xc0, 0x00, 0x00, 0x00, 0x7e, 0xcd, 0xfb, 0xf0,
0x03, 0xde, 0xfb, 0xe1, 0x86, 0xd8, 0x18, 0xc0, 0xcd, 0x9e, 0x6d, 0x80, 0x3c, 0xcc, 0xf1, 0xe0,
0x03, 0xde, 0xfb, 0xe1, 0x87, 0xfc, 0x18, 0xc0, 0xcf, 0xbf, 0x6f, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x01, 0x8c, 0x71, 0xc1, 0x87, 0x6e, 0x1f, 0xc0, 0xce, 0x03, 0x6e, 0x60, 0x3c, 0xcc, 0xf1, 0xe0,
0x00, 0x00, 0x00, 0x01, 0x86, 0x66, 0x1f, 0xc0, 0xcc, 0x1f, 0x6c, 0x60, 0x7e, 0xcd, 0xfb, 0xf0,
0x00, 0x00, 0x00, 0x01, 0x86, 0x66, 0x18, 0xc0, 0xcc, 0x3f, 0x6c, 0x60, 0x66, 0xfd, 0x9b, 0x30,
0x00, 0x00, 0x00, 0x01, 0x86, 0x66, 0x18, 0xc0, 0xcc, 0x33, 0x6c, 0x60, 0x60, 0xfd, 0x9b, 0x30,
0x00, 0x00, 0x00, 0x01, 0x86, 0x66, 0x18, 0xc0, 0xcc, 0x33, 0x6c, 0x60, 0x66, 0xcd, 0x9b, 0x30,
0x00, 0x00, 0x00, 0x07, 0xe6, 0x66, 0x18, 0xc0, 0xcc, 0x3f, 0x6c, 0x60, 0x7e, 0xcd, 0xfb, 0xf0,
0x00, 0x00, 0x00, 0x07, 0xe6, 0x66, 0x18, 0xc0, 0xcc, 0x1e, 0x6c, 0x60, 0x3c, 0xcc, 0xf1, 0xe0
const unsigned char MikeBuick [] PROGMEM = {
0x00, 0x00, 0x00, 0x30, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x06, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0x0d, 0x80, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0x8c, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x18, 0x31, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x0d, 0xd9, 0xb6, 0x1e, 0x3c, 0xf3, 0xcd, 0x80, 0x00, 0x18, 0x33, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x0d, 0xd9, 0xbf, 0x3f, 0x7e, 0xf7, 0xef, 0xc0, 0x00, 0x18, 0x37, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x0d, 0xd9, 0xb9, 0xb3, 0x06, 0xc6, 0x6e, 0x60, 0x20, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x0d, 0xd9, 0xb1, 0xb0, 0x3e, 0xc6, 0x6c, 0x60, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x0f, 0xf9, 0xb1, 0xb0, 0x7e, 0xc6, 0x6c, 0x62, 0xac, 0x18, 0x36, 0x01, 0x83,
0x00, 0x00, 0x00, 0x0f, 0x79, 0xb1, 0xb0, 0x66, 0xc6, 0x6c, 0x62, 0xa2, 0x18, 0x36, 0x01, 0x83,
0x00, 0x00, 0x00, 0x06, 0x31, 0xb1, 0xb3, 0x66, 0xc6, 0x6c, 0x62, 0xa6, 0x18, 0x36, 0x01, 0x83,
0x00, 0x00, 0x00, 0x06, 0x31, 0xb1, 0xbf, 0x7e, 0xf7, 0xec, 0x61, 0x2a, 0x1c, 0x76, 0x01, 0x83,
0x00, 0x00, 0x00, 0x06, 0x31, 0xb1, 0x9e, 0x3c, 0x73, 0xcc, 0x61, 0x26, 0x0e, 0xe6, 0x01, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc7, 0xf1, 0x83,
0x00, 0x00, 0x03, 0x00, 0x06, 0x31, 0x80, 0x01, 0xf8, 0x00, 0x00, 0x00, 0x03, 0x87, 0xf9, 0xc7,
0x00, 0x00, 0x03, 0x00, 0x06, 0x31, 0x80, 0x03, 0xfc, 0x00, 0x00, 0x00, 0x07, 0xc7, 0x1c, 0xff,
0x00, 0x00, 0x03, 0x00, 0x06, 0x31, 0x80, 0x03, 0x0c, 0x00, 0x00, 0x00, 0x0e, 0xe6, 0x0c, 0x7f,
0x00, 0x00, 0x03, 0x00, 0x06, 0x31, 0x80, 0x03, 0x0c, 0x00, 0x00, 0x00, 0x1c, 0x76, 0x0c, 0x03,
0x00, 0x00, 0x03, 0x03, 0x37, 0xbd, 0x87, 0x83, 0x00, 0xf3, 0x6c, 0xc0, 0x18, 0x36, 0x0c, 0x03,
0x00, 0x00, 0x03, 0x03, 0x37, 0xbd, 0x8f, 0xc3, 0x01, 0xfb, 0xec, 0xc0, 0x18, 0x36, 0x0c, 0x03,
0x00, 0x00, 0x03, 0x03, 0x36, 0x31, 0x8c, 0xc3, 0x00, 0x1b, 0x8c, 0xc0, 0x18, 0x36, 0x0c, 0x03,
0x00, 0x00, 0x03, 0x03, 0x36, 0x31, 0x8f, 0xc3, 0x00, 0xfb, 0x0c, 0xc0, 0x18, 0x36, 0x0c, 0x03,
0x00, 0x00, 0x03, 0x03, 0x36, 0x31, 0x8f, 0xc3, 0x01, 0xfb, 0x0c, 0xc0, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x03, 0x03, 0x36, 0x31, 0x8c, 0x03, 0x0d, 0x9b, 0x0c, 0xc0, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x03, 0x03, 0x36, 0x31, 0x8c, 0xc3, 0x0d, 0x9b, 0x0c, 0xc0, 0x18, 0x37, 0x1d, 0xc7,
0x00, 0x00, 0x03, 0xfb, 0xf7, 0xbd, 0xef, 0xc3, 0xfd, 0xfb, 0x0f, 0xc0, 0x18, 0x33, 0xf8, 0xfe,
0x00, 0x00, 0x03, 0xf9, 0xf3, 0x9c, 0xe7, 0x81, 0xf8, 0xf3, 0x07, 0xc0, 0x18, 0x31, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00
const unsigned char ThreeZeroZero [] PROGMEM = {
0x00, 0x18, 0x30, 0x00, 0x00, 0x30, 0x00, 0x00, 0x60, 0x00, 0x00, 0x60, 0x07, 0xc1, 0xf0, 0x7c,
0x00, 0x18, 0x30, 0x00, 0x00, 0x30, 0x00, 0x00, 0x60, 0x00, 0x00, 0x60, 0x0f, 0xe3, 0xf8, 0xfe,
0x00, 0x1c, 0x70, 0x00, 0x00, 0x30, 0x00, 0x00, 0x60, 0x00, 0x00, 0x60, 0x1c, 0x77, 0x1d, 0xc7,
0x00, 0x1c, 0x70, 0x00, 0x00, 0x30, 0x00, 0x00, 0x60, 0x00, 0x00, 0x60, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x1e, 0xf0, 0x00, 0x00, 0x30, 0x00, 0x00, 0x60, 0x00, 0x00, 0x60, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x1e, 0xf3, 0xe3, 0xe3, 0xf3, 0xe6, 0x03, 0x7e, 0x3e, 0x5c, 0x61, 0x80, 0x36, 0x0d, 0x83,
0x00, 0x1b, 0xb7, 0xf7, 0xf7, 0xf7, 0xf6, 0x03, 0x7f, 0x7f, 0x7e, 0x63, 0x80, 0x36, 0x0d, 0x83,
0x00, 0x1b, 0xb6, 0x36, 0x36, 0x36, 0x36, 0x03, 0x63, 0x63, 0x77, 0x67, 0x00, 0x76, 0x0d, 0x83,
0x00, 0x19, 0x36, 0x30, 0x36, 0x36, 0x36, 0x23, 0x63, 0x03, 0x63, 0x6e, 0x03, 0xe6, 0x0d, 0x83,
0x00, 0x19, 0x36, 0x30, 0x36, 0x36, 0x33, 0x76, 0x63, 0x03, 0x63, 0x7c, 0x03, 0xe6, 0x0d, 0x83,
0x00, 0x18, 0x37, 0xf3, 0xf6, 0x36, 0x33, 0x76, 0x63, 0x3f, 0x63, 0x78, 0x00, 0x76, 0x0d, 0x83,
0x00, 0x18, 0x37, 0xf7, 0xf6, 0x36, 0x33, 0x76, 0x63, 0x7f, 0x63, 0x70, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x18, 0x36, 0x06, 0x36, 0x36, 0x33, 0x76, 0x63, 0x63, 0x63, 0x78, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x18, 0x36, 0x06, 0x36, 0x36, 0x33, 0xfe, 0x63, 0x63, 0x63, 0x7c, 0x00, 0x36, 0x0d, 0x83,
0x00, 0x18, 0x36, 0x36, 0x36, 0x36, 0x33, 0xde, 0x63, 0x63, 0x63, 0x6e, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x18, 0x36, 0x36, 0x36, 0x36, 0x31, 0xdc, 0x63, 0x63, 0x63, 0x67, 0x1c, 0x77, 0x1d, 0xc7,
0x00, 0x18, 0x37, 0xf7, 0xf7, 0xf7, 0xf1, 0x8c, 0x7f, 0x7f, 0x63, 0x63, 0x8f, 0xe3, 0xf8, 0xfe,
0x00, 0x18, 0x33, 0xe3, 0xd3, 0xf3, 0xe1, 0x8c, 0x7e, 0x3d, 0x63, 0x61, 0x87, 0xc1, 0xf0, 0x7c,
const unsigned char ThreeZeroSeven [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x30, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc1, 0xf1, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x70, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe3, 0xf9, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x76, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x77, 0x1c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0xf6, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0c, 0x06,
0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0xf0, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x0c, 0x0c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x6d, 0xb6, 0xc3, 0x03, 0xc5, 0xe0, 0x00, 0x00, 0x36, 0x0c, 0x0c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x6d, 0xb6, 0xc3, 0x07, 0xe7, 0xf0, 0x00, 0x00, 0x36, 0x0c, 0x0c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x67, 0x36, 0xc3, 0x0e, 0x77, 0x38, 0x00, 0x00, 0x76, 0x0c, 0x18,
0x00, 0x00, 0x00, 0x00, 0x00, 0x67, 0x36, 0xc3, 0xcc, 0x36, 0x18, 0x00, 0x03, 0xe6, 0x0c, 0x18,
0x00, 0x00, 0x00, 0x00, 0x00, 0x62, 0x36, 0xc3, 0xcc, 0x36, 0x18, 0x00, 0x03, 0xe6, 0x0c, 0x18,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xc3, 0x0c, 0x36, 0x18, 0x00, 0x00, 0x76, 0x0c, 0x30,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xc3, 0x0c, 0x36, 0x18, 0x00, 0x00, 0x36, 0x0c, 0x30,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xc3, 0x0c, 0x36, 0x18, 0x00, 0x00, 0x36, 0x0c, 0x60,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xc3, 0x0c, 0x36, 0x18, 0x00, 0x18, 0x36, 0x0c, 0x60,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xc3, 0x0e, 0x76, 0x18, 0x00, 0x1c, 0x77, 0x1c, 0x60,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0xfb, 0xe7, 0xe6, 0x18, 0x00, 0x0f, 0xe3, 0xf8, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x36, 0x79, 0xe3, 0xc6, 0x18, 0x00, 0x07, 0xc1, 0xf0, 0xc0,
const unsigned char ThreeOneFiveA [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x01, 0xfc, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xe0, 0xe1, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x60, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x07, 0xf1, 0xe1, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x01, 0x87, 0x60, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x0e, 0x3b, 0xe1, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x1b, 0x61, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x61, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x60, 0xfc, 0xd7, 0x83, 0xc0, 0x00, 0x00, 0x18, 0x61, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x61, 0xfe, 0xdf, 0xc7, 0xe0, 0x00, 0x00, 0x18, 0x61, 0x80,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x61, 0x86, 0xdc, 0xee, 0x70, 0x00, 0x00, 0x38, 0x61, 0xf8,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x60, 0x06, 0xd8, 0x6c, 0x30, 0x00, 0x01, 0xf0, 0x61, 0xfc,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x60, 0x06, 0xd8, 0x6c, 0x30, 0x00, 0x01, 0xf0, 0x60, 0x0e,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x60, 0xfe, 0xd8, 0x6f, 0xf0, 0x00, 0x00, 0x38, 0x60, 0x06,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x61, 0xfe, 0xd8, 0x6f, 0xf0, 0x00, 0x00, 0x18, 0x60, 0x06,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x61, 0x86, 0xd8, 0x6c, 0x00, 0x00, 0x00, 0x18, 0x60, 0x06,
0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0x61, 0x86, 0xd8, 0x6c, 0x30, 0x00, 0x0c, 0x18, 0x61, 0x86,
0x00, 0x00, 0x00, 0x00, 0x01, 0x87, 0x61, 0x86, 0xd8, 0x6e, 0x70, 0x00, 0x0e, 0x38, 0x61, 0xce,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x7d, 0xfe, 0xd8, 0x67, 0xe0, 0x00, 0x07, 0xf3, 0xfc, 0xfc,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfc, 0x3c, 0xfa, 0xd8, 0x63, 0xc0, 0x00, 0x03, 0xe3, 0xfc, 0x78,
const unsigned char ThreeOneSix [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x03, 0xe0, 0xe0, 0x7c,
0x00, 0x00, 0x00, 0x01, 0xc0, 0x3f, 0x98, 0x00, 0x00, 0x00, 0x03, 0x00, 0x07, 0xf1, 0xe0, 0xfe,
0x00, 0x00, 0x00, 0x03, 0xc0, 0x71, 0xd8, 0x00, 0x00, 0x00, 0x03, 0x00, 0x0e, 0x3b, 0xe1, 0xc7,
0x00, 0x00, 0x00, 0x07, 0xc0, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x0c, 0x1b, 0x61, 0x83,
0x00, 0x00, 0x00, 0x0f, 0x80, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x1f, 0xff, 0x00, 0x60, 0xdb, 0x77, 0xf1, 0xf9, 0xbb, 0xc0, 0x00, 0x18, 0x61, 0x80,
0x00, 0x00, 0x1f, 0xfe, 0x00, 0x60, 0xdb, 0xf7, 0xfb, 0xfd, 0xfb, 0xc0, 0x00, 0x18, 0x61, 0x80,
0x00, 0x00, 0x00, 0x7c, 0x00, 0x60, 0xdb, 0x86, 0x1b, 0x0d, 0xc3, 0x00, 0x00, 0x38, 0x61, 0xfc,
0x00, 0x00, 0x00, 0xfc, 0x00, 0x7f, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x01, 0xf0, 0x61, 0xfe,
0x00, 0x00, 0x01, 0xfc, 0x00, 0x7f, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x01, 0xf0, 0x61, 0xc7,
0x00, 0x00, 0x03, 0xec, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x00, 0x38, 0x61, 0x83,
0x00, 0x00, 0x07, 0xcc, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x3f, 0x8c, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x3f, 0x0c, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x00, 0x18, 0x61, 0x83,
0x00, 0x00, 0x06, 0x0c, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x0c, 0x18, 0x61, 0x83,
0x00, 0x00, 0x06, 0x0c, 0x00, 0x60, 0xdb, 0x06, 0x1b, 0x0d, 0x83, 0x00, 0x0e, 0x38, 0x61, 0xc7,
0x00, 0x00, 0x06, 0x00, 0x00, 0x60, 0xdb, 0x07, 0xfb, 0xfd, 0x83, 0xe0, 0x07, 0xf3, 0xfc, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xdb, 0x07, 0xf1, 0xf9, 0x81, 0xe0, 0x03, 0xe3, 0xfc, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char NISa [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1d, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0xcf, 0x36, 0x6c, 0xcc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x1f, 0xbf, 0x7e, 0xcc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x99, 0xb9, 0x72, 0xcc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xd9, 0xb0, 0x60, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd9, 0xb0, 0x60, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0xd9, 0xb0, 0x60, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1d, 0xd9, 0xb0, 0x60, 0xcc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x9f, 0xb0, 0x60, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0f, 0x30, 0x60, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0x06, 0x01, 0x80, 0x3f, 0xc0, 0x00, 0x1e, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00,
0x00, 0x00, 0x03, 0x06, 0x01, 0x80, 0x3f, 0xc0, 0x00, 0x3f, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00,
0x00, 0x00, 0x03, 0x86, 0x01, 0x80, 0x06, 0x00, 0x00, 0x73, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xc6, 0x79, 0x80, 0x06, 0x1b, 0x80, 0x61, 0x9e, 0x6c, 0xcd, 0x9e, 0x3c, 0x00,
0x00, 0x00, 0x03, 0xe6, 0xfd, 0xe0, 0x06, 0x1f, 0xc0, 0x70, 0x3f, 0x7e, 0xcd, 0xbf, 0x7e, 0x00,
0x00, 0x00, 0x03, 0x76, 0xcd, 0xe0, 0x06, 0x1c, 0xc0, 0x3c, 0x33, 0x72, 0xcd, 0xb3, 0x66, 0x00,
0x00, 0x00, 0x03, 0x3e, 0xcd, 0x80, 0x06, 0x18, 0xc0, 0x1e, 0x33, 0x60, 0x49, 0xb0, 0x66, 0x00,
0x00, 0x00, 0x03, 0x1e, 0xcd, 0x80, 0x06, 0x18, 0xc0, 0x03, 0x3f, 0x60, 0x79, 0xb0, 0x7e, 0x00,
0x00, 0x00, 0x03, 0x0e, 0xcd, 0x80, 0x06, 0x18, 0xc0, 0x61, 0xb0, 0x60, 0x79, 0xb0, 0x60, 0x00,
0x00, 0x00, 0x03, 0x06, 0xcd, 0x80, 0x06, 0x18, 0xc0, 0x73, 0xb3, 0x60, 0x31, 0xb3, 0x66, 0x00,
0x00, 0x00, 0x03, 0x06, 0xfd, 0xe0, 0x3f, 0xd8, 0xc0, 0x3f, 0x3f, 0x60, 0x31, 0xbf, 0x7e, 0x00,
0x00, 0x00, 0x03, 0x06, 0x78, 0xe0, 0x3f, 0xd8, 0xc0, 0x1e, 0x1e, 0x60, 0x31, 0x9e, 0x3c, 0x00
const unsigned char SCVOne [] PROGMEM = {
0x00, 0x01, 0xfe, 0x00, 0x7f, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0,
0x00, 0x03, 0xff, 0x80, 0xff, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0,
0x00, 0x00, 0x1f, 0xc1, 0xff, 0x9c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0,
0x00, 0x07, 0xe3, 0xe1, 0xe3, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0,
0x00, 0x1f, 0xfb, 0xf1, 0xc0, 0x1c, 0x1f, 0x47, 0xd1, 0xf0, 0x7c, 0x1f, 0x07, 0xd1, 0xf1, 0xdc,
0x00, 0x3f, 0xfd, 0xf1, 0xc0, 0x3e, 0x3f, 0xcf, 0xf3, 0xf8, 0xfe, 0x3f, 0x8f, 0xf3, 0xf9, 0xfe,
0x00, 0x7f, 0x01, 0xf9, 0xc0, 0x3e, 0x7f, 0xdf, 0xf7, 0xfd, 0xff, 0x7f, 0xdf, 0xf7, 0xfd, 0xff,
0x00, 0x7e, 0x00, 0xf9, 0xfe, 0x3e, 0x71, 0xdc, 0x77, 0x1d, 0xc7, 0x71, 0xdc, 0x77, 0x1d, 0xef,
0x00, 0xfc, 0x00, 0xf8, 0xff, 0x1c, 0x71, 0xdc, 0x77, 0x1d, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf8, 0x00, 0xf8, 0x7f, 0x9c, 0x71, 0xdc, 0x77, 0x1d, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf0, 0x00, 0xf4, 0x07, 0x9c, 0x71, 0xdc, 0x77, 0xfd, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf4, 0x00, 0xf4, 0x03, 0x9c, 0x71, 0xdc, 0x77, 0xfd, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf4, 0x00, 0xec, 0x03, 0x9c, 0x71, 0xdc, 0x77, 0x01, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf4, 0x01, 0xdc, 0x83, 0x9c, 0x71, 0xdc, 0x77, 0x01, 0xc0, 0x71, 0xdc, 0x77, 0x01, 0xc7,
0x00, 0xf6, 0x03, 0xbd, 0xc7, 0x9c, 0x71, 0xdc, 0x77, 0x1d, 0xc7, 0x71, 0xdc, 0x77, 0x1d, 0xc7,
0x00, 0xf7, 0x87, 0x79, 0xff, 0x9f, 0x7f, 0xdf, 0xf7, 0xfd, 0xff, 0x7f, 0xdf, 0xf7, 0xfd, 0xc7,
0x00, 0x77, 0xf0, 0x79, 0xff, 0x0f, 0x3f, 0xcf, 0xf3, 0xf8, 0xfe, 0x3f, 0x8f, 0xf3, 0xf9, 0xc7,
0x00, 0x3b, 0xff, 0xf0, 0xfe, 0x07, 0x1f, 0x47, 0xf1, 0xf0, 0x7c, 0x1f, 0x07, 0xd1, 0xf1, 0xc7,
0x00, 0x1d, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x0e, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0xdf, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char SCVTwo [] PROGMEM = {
0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7f, 0xf8, 0x0f, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x00, 0xc0, 0x7e, 0x1f, 0xc6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x01, 0x3f, 0xbe, 0x38, 0xe6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x02, 0xf8, 0x5f, 0x30, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x01, 0xf0, 0x1f, 0x30, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x07, 0xe0, 0x1e, 0x30, 0x0e, 0x0e, 0xc3, 0xb0, 0xf0, 0x3c, 0x0f, 0x01, 0xd8, 0x78, 0xdc,
0x00, 0x07, 0xc0, 0x0e, 0xb8, 0x1f, 0x9f, 0xc7, 0xf1, 0xf8, 0x7e, 0x1f, 0x83, 0xf8, 0xfc, 0xfe,
0x00, 0x07, 0xc0, 0x0e, 0x9f, 0x86, 0x39, 0xce, 0x73, 0x9c, 0xe7, 0x39, 0xc7, 0x39, 0xce, 0xe3,
0x00, 0x07, 0x80, 0x0e, 0x8f, 0xc6, 0x70, 0xdc, 0x37, 0x0d, 0xc3, 0x70, 0xee, 0x1b, 0x86, 0xc3,
0x00, 0x07, 0xa0, 0x0d, 0x80, 0xe6, 0x60, 0xd8, 0x37, 0xfd, 0x80, 0x60, 0x6c, 0x1b, 0x00, 0xc3,
0x00, 0x07, 0xa0, 0x1b, 0x80, 0x66, 0x60, 0xd8, 0x37, 0xfd, 0x80, 0x60, 0x6c, 0x1b, 0x00, 0xc3,
0x00, 0x03, 0xb0, 0x37, 0x00, 0x66, 0x60, 0xd8, 0x36, 0x01, 0x80, 0x60, 0x6c, 0x1b, 0x00, 0xc3,
0x00, 0x03, 0xb8, 0x67, 0x30, 0x66, 0x70, 0xdc, 0x37, 0x0d, 0xc3, 0x70, 0xee, 0x1b, 0x86, 0xc3,
0x00, 0x01, 0xbd, 0xde, 0x38, 0xe7, 0x39, 0xce, 0x73, 0x9c, 0xe7, 0x39, 0xc7, 0x39, 0xce, 0xc3,
0x00, 0x01, 0xde, 0x3e, 0x1f, 0xc3, 0x9f, 0xc7, 0xf1, 0xf8, 0x7e, 0x1f, 0x83, 0xf8, 0xfc, 0xc3,
0x00, 0x00, 0xef, 0xfc, 0x0f, 0x81, 0x8e, 0xc3, 0xb0, 0xf0, 0x3c, 0x0f, 0x01, 0xd8, 0x78, 0xc3,
0x00, 0x00, 0x27, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x17, 0xc0, 0x00, 0x00, 0x00, 0x18, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char XEightEight [] PROGMEM = {
0x00, 0x03, 0xf6, 0x03, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x31, 0xf0, 0x7c,
0x00, 0x03, 0xf6, 0x03, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x18, 0x33, 0xf8, 0xfe,
0x00, 0x03, 0x06, 0x03, 0x00, 0x00, 0x19, 0x80, 0x00, 0x00, 0x00, 0x00, 0x18, 0x37, 0x1d, 0xc7,
0x00, 0x03, 0x06, 0x03, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0x06, 0x3f, 0x3e, 0x5c, 0x18, 0x1f, 0xb1, 0x9e, 0xb7, 0x3e, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0x06, 0x7f, 0x7f, 0x7e, 0x18, 0x3f, 0xb1, 0xbf, 0xbf, 0x7f, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0xe6, 0x63, 0x63, 0x77, 0x1f, 0x31, 0xb1, 0xb1, 0xb8, 0x63, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0xe6, 0x63, 0x63, 0x63, 0x0f, 0xb1, 0xb1, 0xb1, 0xb0, 0x63, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0x06, 0x63, 0x63, 0x63, 0x01, 0xb1, 0xb1, 0xb1, 0xb0, 0x7f, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x03, 0x06, 0x63, 0x63, 0x63, 0x01, 0xb1, 0xb1, 0xb1, 0xb0, 0x7f, 0x1c, 0x76, 0x0d, 0x83,
0x00, 0x03, 0x06, 0x63, 0x63, 0x63, 0x01, 0xb1, 0xb1, 0xb1, 0xb0, 0x60, 0x0e, 0xe7, 0x1d, 0xc7,
0x00, 0x03, 0x06, 0x63, 0x63, 0x63, 0x19, 0xb1, 0xb1, 0xb1, 0xb0, 0x63, 0x07, 0xc3, 0xf8, 0xfe,
0x00, 0x03, 0xf7, 0x7f, 0x7f, 0x63, 0x1f, 0xbf, 0xbf, 0xbf, 0xb0, 0x7f, 0x03, 0x83, 0xf8, 0xfe,
0x00, 0x03, 0xf3, 0x3f, 0x3e, 0x63, 0x0f, 0x1f, 0x9f, 0x1e, 0xb0, 0x3e, 0x07, 0xc7, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x0e, 0xe6, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x1c, 0x76, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0x20, 0x20, 0x08, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xa0, 0x24, 0x08, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x01, 0x52, 0x08, 0xa3, 0x28, 0xc8, 0xca, 0x80, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x01, 0x45, 0x0f, 0x24, 0xb1, 0x29, 0x2a, 0x80, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x01, 0x55, 0x08, 0xa4, 0xa9, 0xe9, 0x2a, 0x80, 0x00, 0x18, 0x37, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x95, 0x08, 0xa4, 0xa5, 0x09, 0x25, 0x00, 0x00, 0x18, 0x33, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x93, 0x0f, 0x13, 0xa4, 0xc4, 0xe5, 0x00, 0x00, 0x18, 0x31, 0xf0, 0x7c,
const unsigned char SixThree [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x1d, 0xc7,
0x00, 0x00, 0x1f, 0x30, 0x00, 0x00, 0x00, 0x30, 0x31, 0x80, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x83,
0x00, 0x00, 0x3f, 0xb0, 0x00, 0x00, 0x00, 0x30, 0x31, 0x80, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x03,
0x00, 0x00, 0x31, 0xb0, 0x00, 0x00, 0x00, 0x30, 0x31, 0x80, 0x00, 0x00, 0x00, 0x06, 0x00, 0x03,
0x00, 0x00, 0x30, 0x30, 0x00, 0x00, 0x00, 0x30, 0x31, 0x80, 0x00, 0x00, 0x00, 0x06, 0x00, 0x03,
0x00, 0x00, 0x30, 0x37, 0x1e, 0xaf, 0x1f, 0x30, 0x31, 0x9f, 0x31, 0x9f, 0x1f, 0x06, 0x00, 0x03,
0x00, 0x00, 0x30, 0x3f, 0xbf, 0xbf, 0xbf, 0xb0, 0x31, 0xbf, 0xb1, 0xbf, 0xbf, 0x86, 0x00, 0x03,
0x00, 0x00, 0x30, 0x39, 0xb1, 0xb1, 0xb1, 0xb0, 0x3f, 0xb1, 0xb1, 0xb1, 0xb1, 0x86, 0x00, 0x03,
0x00, 0x00, 0x30, 0x31, 0xb1, 0xb1, 0xb1, 0xb0, 0x3f, 0xb1, 0xb1, 0xb0, 0x31, 0x87, 0xf0, 0x07,
0x00, 0x00, 0x30, 0x31, 0xb1, 0xb1, 0xbf, 0xb0, 0x31, 0xb1, 0xb1, 0xbf, 0x3f, 0x87, 0xf8, 0x1e,
0x00, 0x00, 0x30, 0x31, 0xb1, 0xb1, 0xbf, 0xb0, 0x31, 0xb1, 0xb1, 0x9f, 0xbf, 0x87, 0x1c, 0x1e,
0x00, 0x00, 0x30, 0x31, 0xb1, 0xb1, 0xb0, 0x30, 0x31, 0xb1, 0xb1, 0x81, 0xb0, 0x06, 0x0c, 0x07,
0x00, 0x00, 0x31, 0xb1, 0xb1, 0xb1, 0xb1, 0xb0, 0x31, 0xb1, 0xb1, 0xb1, 0xb1, 0x86, 0x0c, 0x03,
0x00, 0x00, 0x3f, 0xb1, 0xbf, 0xbf, 0xbf, 0xbc, 0x31, 0xbf, 0xbf, 0xbf, 0xbf, 0x86, 0x0c, 0x03,
0x00, 0x00, 0x1f, 0x31, 0x9e, 0xbf, 0x1f, 0x1c, 0x31, 0x9f, 0x1f, 0x1f, 0x1f, 0x06, 0x0c, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x1d, 0xc7,
const unsigned char XSevenEight [] PROGMEM = {
0x00, 0x00, 0x01, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x01, 0x86, 0x00, 0xcc, 0x18, 0x37, 0xfc, 0x7c,
0x00, 0x00, 0x01, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0x86, 0x00, 0xcc, 0x18, 0x37, 0xfc, 0xfe,
0x00, 0x00, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x01, 0x86, 0x00, 0xcc, 0x18, 0x30, 0x0d, 0xc7,
0x00, 0x00, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x01, 0x86, 0x00, 0xcc, 0x18, 0x30, 0x0d, 0x83,
0x00, 0x00, 0x01, 0x86, 0x7a, 0xdd, 0xb9, 0xe9, 0xe1, 0x86, 0x7a, 0xcc, 0x18, 0x30, 0x19, 0x83,
0x00, 0x00, 0x01, 0x86, 0xfe, 0xfd, 0xfb, 0xfb, 0xf1, 0x86, 0xfe, 0xcc, 0x18, 0x30, 0x19, 0x83,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xe1, 0xc3, 0x1b, 0x31, 0xfe, 0xc6, 0xcc, 0x18, 0x30, 0x19, 0x83,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xc1, 0x83, 0x1b, 0x01, 0xfe, 0xc6, 0xcc, 0x18, 0x30, 0x19, 0x83,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xc1, 0x83, 0x1b, 0xe1, 0x86, 0xc6, 0xcc, 0x18, 0x30, 0x31, 0x83,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xc1, 0x83, 0x19, 0xf1, 0x86, 0xc6, 0xcc, 0x1c, 0x70, 0x31, 0x83,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xc1, 0x83, 0x18, 0x31, 0x86, 0xc6, 0xcc, 0x0e, 0xe0, 0x31, 0xc7,
0x00, 0x00, 0x01, 0x86, 0xc6, 0xc1, 0x83, 0x1b, 0x31, 0x86, 0xc6, 0xcc, 0x07, 0xc0, 0x30, 0xfe,
0x00, 0x00, 0x01, 0xfe, 0xfe, 0xc1, 0x83, 0xfb, 0xf1, 0x86, 0xfe, 0xee, 0x03, 0x80, 0x60, 0xfe,
0x00, 0x00, 0x01, 0xfc, 0x7a, 0xc1, 0x81, 0xe9, 0xe1, 0x86, 0x7a, 0x66, 0x07, 0xc0, 0x61, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0xe0, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x61, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x30, 0xc1, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x02, 0x02, 0x00, 0x02, 0x00, 0x18, 0x30, 0xc1, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x20, 0x02, 0x02, 0x00, 0x02, 0x00, 0x18, 0x30, 0xc1, 0x83,
0x00, 0x00, 0x00, 0x00, 0xa9, 0x02, 0x26, 0x53, 0x32, 0x32, 0x8e, 0x00, 0x18, 0x30, 0xc1, 0x83,
0x00, 0x00, 0x00, 0x00, 0xa2, 0x83, 0xc9, 0x6a, 0x4a, 0x4b, 0x52, 0x00, 0x18, 0x31, 0x81, 0x83,
0x00, 0x00, 0x00, 0x00, 0xaa, 0x82, 0x09, 0x4a, 0x7a, 0x4a, 0x52, 0x00, 0x18, 0x31, 0x81, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x4a, 0x82, 0x09, 0x4a, 0x42, 0x4a, 0x52, 0x00, 0x18, 0x31, 0x80, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x49, 0x82, 0x06, 0x49, 0x31, 0x3a, 0x4e, 0x00, 0x18, 0x31, 0x80, 0x7c,
const unsigned char XEightEightvTwo [] PROGMEM = {
0x00, 0x0c, 0x60, 0x00, 0x03, 0x06, 0x00, 0x03, 0x00, 0x0c, 0x60, 0x19, 0x98, 0x31, 0xf0, 0x7c,
0x00, 0x0e, 0x60, 0x00, 0x03, 0x06, 0x00, 0x03, 0x00, 0x0c, 0x60, 0x19, 0x98, 0x33, 0xf8, 0xfe,
0x00, 0x0e, 0x60, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x60, 0x19, 0x98, 0x37, 0x1d, 0xc7,
0x00, 0x0e, 0x67, 0x98, 0x1b, 0xe6, 0x78, 0xf3, 0x5c, 0x0c, 0x67, 0x59, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0f, 0x6f, 0xd8, 0x1b, 0xf6, 0xfd, 0xfb, 0x7e, 0x0c, 0x6f, 0xd9, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0f, 0x6c, 0xd8, 0x1b, 0x36, 0xcd, 0x9b, 0x77, 0x0f, 0xec, 0xd9, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0d, 0xec, 0xcd, 0xb3, 0x36, 0xcd, 0x9b, 0x63, 0x0f, 0xec, 0xd9, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0d, 0xef, 0xcd, 0xb3, 0x36, 0xcd, 0x9b, 0x63, 0x0c, 0x6c, 0xd9, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0c, 0xef, 0xcd, 0xb3, 0x36, 0xcd, 0x9b, 0x63, 0x0c, 0x6c, 0xd9, 0x98, 0x36, 0x0d, 0x83,
0x00, 0x0c, 0xec, 0x07, 0xe3, 0x36, 0xcd, 0x9b, 0x63, 0x0c, 0x6c, 0xd9, 0x9c, 0x76, 0x0d, 0x83,
0x00, 0x0c, 0xec, 0xc6, 0x63, 0x36, 0xcd, 0x9b, 0x63, 0x0c, 0x6c, 0xd9, 0x8e, 0xe7, 0x1d, 0xc7,
0x00, 0x0c, 0x6f, 0xc6, 0x63, 0xf6, 0xfd, 0xfb, 0x63, 0x0c, 0x6f, 0xdd, 0xc7, 0xc3, 0xf8, 0xfe,
0x00, 0x0c, 0x67, 0x86, 0x63, 0xe6, 0x7c, 0xfb, 0x63, 0x0c, 0x67, 0x4c, 0xc3, 0x83, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x18, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc7, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcd, 0x98, 0x00, 0x00, 0x00, 0x00, 0x0e, 0xe6, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfd, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x76, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc8, 0x08, 0x02, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x28, 0x09, 0x02, 0x00, 0x00, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x54, 0x82, 0x28, 0xca, 0x32, 0x32, 0xa0, 0x00, 0x18, 0x36, 0x0d, 0x83,
0x00, 0x00, 0x00, 0x00, 0x51, 0x43, 0xc9, 0x2c, 0x4a, 0x4a, 0xa0, 0x00, 0x18, 0x37, 0x1d, 0xc7,
0x00, 0x00, 0x00, 0x00, 0x55, 0x42, 0x29, 0x2a, 0x7a, 0x4a, 0xa0, 0x00, 0x18, 0x33, 0xf8, 0xfe,
0x00, 0x00, 0x00, 0x00, 0x25, 0x42, 0x29, 0x29, 0x42, 0x49, 0x40, 0x00, 0x18, 0x31, 0xf0, 0x7c,
0x00, 0x00, 0x00, 0x00, 0x24, 0xc3, 0xc4, 0xe9, 0x31, 0x39, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char MetroRR [] PROGMEM = {
0x00, 0x00, 0x3f, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x01, 0xf8, 0x03, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3c, 0x7f, 0xe3, 0xc0, 0x00, 0x00, 0x00, 0x01, 0xfc, 0x03, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3c, 0x3f, 0xc3, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8c, 0x00, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x3f, 0xc7, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8c, 0xf3, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x1f, 0x87, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8d, 0xfb, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x1f, 0x87, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8c, 0x1b, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x4f, 0x27, 0xc0, 0x00, 0x00, 0x00, 0x01, 0xf8, 0xfb, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x4f, 0x27, 0xc0, 0x00, 0x00, 0x00, 0x01, 0xf1, 0xfb, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x66, 0x67, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x99, 0x9b, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x70, 0xe7, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8d, 0xfb, 0x78, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x70, 0xe7, 0xc0, 0x00, 0x00, 0x00, 0x01, 0x8c, 0xf3, 0x38, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3e, 0x79, 0xe7, 0xc0, 0x3f, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x3c, 0x79, 0xe3, 0xc0, 0x3f, 0x80, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c,
0x00, 0x00, 0x3c, 0x79, 0xe3, 0xc0, 0x31, 0x9e, 0x7c, 0xc3, 0xc7, 0x8f, 0x36, 0xc3, 0xcd, 0x8c,
0x00, 0x00, 0x3f, 0xff, 0xff, 0xc0, 0x31, 0xbf, 0x7e, 0xc7, 0xef, 0xdf, 0xbf, 0xe7, 0xef, 0xcf,
0x00, 0x00, 0x3f, 0xff, 0xff, 0xc0, 0x31, 0xb3, 0x66, 0xc0, 0x6c, 0xd9, 0xbb, 0x76, 0x6e, 0x6f,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x3f, 0x66, 0xc3, 0xec, 0x19, 0xb3, 0x36, 0x6c, 0x6c,
0x00, 0x00, 0x11, 0x77, 0x71, 0x80, 0x3e, 0x3f, 0x66, 0xc7, 0xec, 0x1f, 0xb3, 0x37, 0xec, 0x6c,
0x00, 0x00, 0x1b, 0x42, 0x4a, 0x40, 0x33, 0x30, 0x66, 0xc6, 0x6c, 0x18, 0x33, 0x36, 0x0c, 0x6c,
0x00, 0x00, 0x15, 0x72, 0x72, 0x40, 0x33, 0x33, 0x66, 0xc6, 0x6c, 0xd9, 0xb3, 0x36, 0x6c, 0x6c,
0x00, 0x00, 0x11, 0x42, 0x52, 0x40, 0x31, 0xbf, 0x7e, 0xf7, 0xef, 0xdf, 0xb3, 0x37, 0xec, 0x6f,
0x00, 0x00, 0x11, 0x72, 0x49, 0x80, 0x31, 0x9e, 0x7c, 0x73, 0xc7, 0x8f, 0x33, 0x33, 0xcc, 0x67,
const unsigned char Hornby [] PROGMEM = {
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc0, 0xf0, 0x3f, 0xf0, 0x7c, 0x1f, 0xdf, 0xfc, 0x7f, 0x7f, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc3, 0xfc, 0x3f, 0xf8, 0x7e, 0x1f, 0xdf, 0xfe, 0x7f, 0x7f, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc7, 0xfe, 0x3f, 0xfc, 0x7e, 0x1f, 0xdf, 0xff, 0x7f, 0x7f, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x0f, 0xff, 0x0f, 0x1e, 0x1f, 0x07, 0x07, 0x0f, 0x1c, 0x1c, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1f, 0x0f, 0x8f, 0x0e, 0x1f, 0x07, 0x07, 0x07, 0x1c, 0x1c, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1e, 0x07, 0x8f, 0x0e, 0x1f, 0x87, 0x07, 0x07, 0x0e, 0x38, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1c, 0x03, 0xcf, 0x0e, 0x1d, 0x87, 0x07, 0x07, 0x0e, 0x38, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x3c, 0x03, 0xcf, 0x1e, 0x1d, 0xc7, 0x07, 0x0f, 0x07, 0x70, 0x00,
0x00, 0x00, 0x00, 0x07, 0xff, 0x3c, 0x03, 0xcf, 0xfe, 0x1c, 0xc7, 0x07, 0xfe, 0x07, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x07, 0xff, 0x3c, 0x03, 0xcf, 0xfc, 0x1c, 0xe7, 0x07, 0xfc, 0x03, 0xe0, 0x00,
0x00, 0x00, 0x00, 0x07, 0xff, 0x3c, 0x03, 0xcf, 0xf8, 0x1c, 0x67, 0x07, 0xfe, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x3c, 0x03, 0xce, 0xf0, 0x1c, 0x77, 0x07, 0x0f, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1c, 0x03, 0xce, 0x70, 0x1c, 0x37, 0x07, 0x07, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1e, 0x07, 0x8e, 0x38, 0x1c, 0x3f, 0x07, 0x07, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x1f, 0x0f, 0x8e, 0x38, 0x1c, 0x1f, 0x07, 0x07, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x07, 0x07, 0x0f, 0xff, 0x0e, 0x1c, 0x1c, 0x1f, 0x07, 0x0f, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc7, 0xfe, 0x3f, 0x9f, 0x7f, 0x0f, 0x1f, 0xff, 0x07, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc3, 0xfc, 0x3f, 0x8f, 0x7f, 0x0f, 0x1f, 0xfe, 0x07, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x1f, 0xdf, 0xc0, 0xf0, 0x3f, 0x8f, 0x7f, 0x07, 0x1f, 0xfc, 0x07, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9a, 0x84, 0x3c, 0x8f, 0x26, 0x86, 0x3f,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8d, 0x4a, 0x49, 0x49, 0x23, 0x49, 0x3f,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x89, 0x46, 0x48, 0xc2, 0x22, 0x4f, 0x3f,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x88, 0x4a, 0x49, 0x45, 0x22, 0x48, 0x3f,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8c, 0x67, 0x38, 0xef, 0x77, 0x66, 0x3f,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
switchMillis = millis();
display.begin(0, 0);
display.clearDisplay(); // Make sure the display is cleared
// Draw the bitmap:
// drawBitmap(x position, y position, bitmap data, bitmap width, bitmap height, color)
display.drawBitmap(5, -4, NISa, 128, 32, WHITE);
display.display();
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
if (buttonState == HIGH)
// if the current state is HIGH then the button
// went from off to on:
buttonPushCounter++; // add one to counter
if (buttonPushCounter > 10)
buttonPushCounter = 1;
Serial.println(buttonPushCounter);
switch (buttonPushCounter) // choose what to display based on buttonPushCounter value
case 0:
// Draw the bitmap:
display.display();
case 1: {
if (millis() - switchMillis > interval)
count++;
if (count == 1)
firstScreenFlag = true;
if (count == 2)
secondScreenFlag = true;
count = 0;
switchMillis += interval; //millis();
if (firstScreenFlag)
doLcdMsg();
if (secondScreenFlag)
doLcdMsg2();
case 2:
// Draw the bitmap:
display.drawBitmap(0, 3, XSevenEight, 128, 32, WHITE);
display.display();
case 3:
// Draw the bitmap:
display.drawBitmap(0, 3, XEightEight, 128, 32, WHITE);
display.display();
case 4:
// Draw the bitmap:
display.drawBitmap(0, 3, XEightEightvTwo, 128, 32, WHITE);
display.display();
case 5:
// Draw the bitmap:
display.drawBitmap(0, 2, SCVTwo, 128, 32, WHITE);
display.display();
case 6:
// Draw the bitmap:
display.drawBitmap(0, 4, MetroRR, 128, 32, WHITE);
display.display();
case 7:
// Draw the bitmap:
display.drawBitmap(0, 0, ChooChoo, 128, 32, WHITE);
display.display();
case 8:
// Draw the bitmap:
display.drawBitmap(0, 1, RR, 128, 32, WHITE);
display.display();
case 9:
// Draw the bitmap:
display.drawBitmap(3, 3, SchoolService, 128, 32, WHITE);
display.display();
case 10:
// Draw the bitmap:
display.drawBitmap(0, 4, Hornby, 128, 32, WHITE);
display.display();
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
void doLcdMsg() {
// Draw the bitmap:
display.display();
void doLcdMsg2() {
// Draw the bitmap:
display.drawBitmap(0, 0, MikeBuick, 128, 32, WHITE);
display.display();
