#include <IRremote.h>
#include <Adafruit_MotorShield.h>
#include <Wire.h>
#include <Servo.h>
// Define the IR remote codes
#define IR_ON_OFF 0xE11E7F80
#define IR_FORWARD 0xFA057F80
#define IR_LEFT 0xF8077F80
#define IR_RIGHT 0xF6097F80
#define IR_BACKWARD 0x58F8BCB2
#define IR_CAMERA_LEFT 0xF30C7F80
#define IR_CAMERA_RIGHT 0xFF007F80
// Initialize the Adafruit Motor Shield
Adafruit_MotorShield motorShield = Adafruit_MotorShield();
Adafruit_DCMotor *leftMotor = motorShield.getMotor(1);
Adafruit_DCMotor *rightMotor = motorShield.getMotor(2);
// Initialize the IR remote
IRrecv irrecv(11);
decode_results results;
// Initialize the servos
Servo horizontalServo;
int horizontalAngle = 90;
// Initialize the robot on/off state
boolean robotOn = false;
// Initialize the serial port for debugging
// Initialize the motor shield
motorShield.begin();
// Set the motor speeds to 0 initially
leftMotor->setSpeed(0);
rightMotor->setSpeed(0);
// Start the IR remote receiver
irrecv.enableIRIn();
// Attach the servo to its pin
horizontalServo.attach(9);
// Set the initial angle for the servo
horizontalServo.write(horizontalAngle);
// Check if there is a new IR signal
if (irrecv.decode(&results)) {
// Print the received code for debugging
Serial.println(results.value, HEX);
// Check the received code and perform the appropriate action
switch (results.value) {
case IR_ON_OFF:
// Turn the robot on or off
if (robotOn) {
// Turn off the robot
robotOn = false;
// Turn on the robot
leftMotor->setSpeed(200);
rightMotor->setSpeed(200);
leftMotor->run(FORWARD);
rightMotor->run(FORWARD);
robotOn = true;
case IR_FORWARD:
// Move the robot forward
if (robotOn) {
case IR_LEFT:
// Turn the robot left
if (robotOn) {
leftMotor->setSpeed(100);
rightMotor->setSpeed(100);
leftMotor->run(BACKWARD);
case IR_RIGHT:
// Turn the robot right
if (robotOn) {
rightMotor->run(BACKWARD);
case IR_BACKWARD:
// Move the robot backward
if (robotOn) {
case IR_CAMERA_LEFT:
// Move the horizontal servo to the left
if (robotOn && horizontalAngle > 0) {
horizontalAngle--;
case IR_CAMERA_RIGHT:
// Move the horizontal servo to the right
if (robotOn && horizontalAngle < 180) {
horizontalAngle++;
default:
// Do nothing
// Wait a moment and then clear the IR signal buffer
delay(200);
irrecv.resume();
And this is the error that appears, knowing that I installed all libraries from within the application, and when it appeared that this library needs to install other libraries, he agreed to install them
/sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /libraries/Servo/src/avr/Servo.cpp -o /librariesBuild/Servo/avr_Servo.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /libraries/Servo/src/sam/Servo.cpp -o /librariesBuild/Servo/sam_Servo.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /libraries/Servo/src/stm32f4/Servo.cpp -o /librariesBuild/Servo/stm32f4_Servo.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /libraries/Servo/src/nrf52/Servo.cpp -o /librariesBuild/Servo/nrf52_Servo.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /libraries/Servo/src/samd/Servo.cpp -o /librariesBuild/Servo/samd_Servo.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /Adafruit_BusIO/Adafruit_BusIO_Register.cpp -o /librariesBuild/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /Adafruit_BusIO/Adafruit_I2CDevice.cpp -o /librariesBuild/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /Adafruit_BusIO/Adafruit_SPIDevice.cpp -o /librariesBuild/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o /sdk/hardware/tools/avr/bin/avr-g++ -no-canonical-prefixes -std=gnu++11 -c -g -Os -w -mmcu=atmega328p -DF_CPU=16000000L -DUSB_VID=null -DUSB_PID=null -DARDUINO=10812 -DIDE="ArduinoDroid" -DARDUINO_ARCH_AVR -DARDUINO_AVR_UNO /Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp -o /librariesBuild/Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp.o /Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp:33:40: fatal error: Adafruit_MS_PWMServoDriver.h: No such file or directory
#include <Adafruit_MS_PWMServoDriver.h>
compilation terminated.
Return code is not 0
