The sketch from:
doesn't has output after I added two lines. why?
Serial.print("state=");
Serial.println(state);
I didn't connect any but a HC-05 Bluetooth.
Thanks
Adam
#include <SoftwareSerial.h>
#include "DHT.h"
#define echopin A0 // echo pin
#define trigpin A1 // Trigger pin
SoftwareSerial BT(2, 3);
#define dht_pin A5 // Pin sensor is connected to
// DHT DHT1;
int motor2Pin1 = 6; // pin 6 on L293D IC
int motor2Pin2 = 7; // pin 7 on L293D IC
int motor2EnablePin = 10; // pin 10 on L293D IC
int motor1Pin1 = 4; // pin 4 on L293D IC
int motor1Pin2 = 5; // pin 5 on L293D IC
int motor1EnablePin = 9; // pin 9 on L293D IC
int state;
int Speed = 130;
int temp;
int hum;
int timer = 0;
int distanceFwd;
long duration;
int chk = 0;
int set = 35;
pinMode (trigpin, OUTPUT);
pinMode (echopin, INPUT );
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
pinMode(motor1EnablePin, OUTPUT);
pinMode(motor2Pin1, OUTPUT);
pinMode(motor2Pin2, OUTPUT);
pinMode(motor2EnablePin, OUTPUT);
// initialize serial communication at 9600 bits per second:
Serial.println("xxx_setup!");
Serial.print("File : "), Serial.println(__FILE__);
const char compile_date[] = __DATE__ " " __TIME__;
Serial.print("Compile timestamp: ");
Serial.println(compile_date);
BT.begin(9600); // Setting the baud rate of Software Serial Library
//if some date is sent, reads it and saves in state
if (BT.available() > 0) {
state = BT.read();
if (state > 10) {
Speed = state;
distanceFwd = data();
analogWrite(motor1EnablePin, Speed);
analogWrite(motor2EnablePin, Speed);
if ((distanceFwd < set) && (chk == 1)) {
chk = 2;
Stop();
if (distanceFwd > set) {
chk = 0;
// if the state is '1' the DC motor will go forward
if ((state == 1) && (chk == 0)) {
chk = 1;
forword();
Serial.println("Go Forward!");
// if the state is '2' the motor will Reverse
else if (state == 2) {
backword();
Serial.println("Reverse!");
// if the state is '3' the motor will turn left
else if (state == 3) {
turnLeft();
Serial.println("Turn LEFT");
// if the state is '4' the motor will turn right
else if (state == 4) {
turnRight();
Serial.println("Turn RIGHT");
// if the state is '5' the motor will Stop
else if (state == 5) {
Stop();
Serial.println("STOP!");
timer = timer + 1;
if (distanceFwd > 200) {
distanceFwd = 200;
if (timer > 400) {
// DHT1.read11(dht_pin);
// hum = DHT1.humidity;
// temp = DHT1.temperature;
BT.print(temp); //send distance to MIT App
BT.print(";");
BT.print(hum); //send distance to MIT App
BT.print(";");
BT.print(distanceFwd); //send distance to MIT App
BT.println(";");
timer = 0;
delay(1);
void forword() {
digitalWrite(motor1Pin1, HIGH);
digitalWrite(motor1Pin2, LOW);
digitalWrite(motor2Pin1, LOW);
digitalWrite(motor2Pin2, HIGH);
void backword() {
digitalWrite(motor1Pin1, LOW);
digitalWrite(motor1Pin2, HIGH);
digitalWrite(motor2Pin1, HIGH);
digitalWrite(motor2Pin2, LOW);
void turnRight() {
void turnLeft() {
void Stop() {
long data()
digitalWrite(trigpin, LOW);
delayMicroseconds(2);
digitalWrite(trigpin, HIGH);
delayMicroseconds(10);
duration = pulseIn (echopin, HIGH);
return duration / 29 / 2;
