#include <SPI.h>
#include <SD.h>
#include <DS3231.h>
#include <DHT.h>
#include <Wire.h>
#include <RTClib.h>
#define I2C_ADDR 0x27
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define BACKLIGHT 3
#define DHT22_PIN 4
unsigned long prevDispCycle = 0;
unsigned long currDispCycle;
const long intDispCycle = 500;
unsigned long prevReadPV = 0;
unsigned long currReadPV;
const long intReadPV = 50;
unsigned long prevDisp = 0;
unsigned long currDisp;
const long intDisp = 250;
unsigned long prevRel = 0;
unsigned long currRel;
const long intRel = 250;
unsigned long prevHold = 0;
unsigned long currHold;
const long intHold = 250;
unsigned long prevDHT = 0;
unsigned long currDHT;
const long intDHT = 2000;
unsigned long prevSave = 0;
unsigned long currSave;
long intSave = 1000;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 1000;
int display = 1;
int btnDisplay = 4;
int btnRelay = 5;
int btnHold = 9;
int relay1 = 7;
int relay2 = 8;
int relaySelect = 0;
int logInterval = 1;
int pinInterrupt = 2;
int Count = 0;
int samples = 0;
int humidity = 0;
double reading_vol = 0;
double reading_cur = 0;
double initial_vol = 0;
double initial_cur = 0;
double voltage = 0.0;
double current = 0.0;
double power = 0;
double windSpeed = 0;
double temperature = 0;
bool hold = false;
RTC_DS3231 rtc;
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
dht DHT;
int CS_PIN = 10;
File file;
rtc.begin();
lcd.begin (20,4);
lcd.setBacklightPin (BACKLIGHT, POSITIVE);
lcd.setBacklight (HIGH);
pinMode(pinInterrupt, INPUT_PULLUP);
pinMode (btnDisplay, INPUT_PULLUP);
pinMode (btnRelay, INPUT_PULLUP);
pinMode (btnHold, INPUT_PULLUP);
pinMode (relay1, OUTPUT);
pinMode (relay2, OUTPUT);
pinMode (CS_PIN, OUTPUT);
digitalWrite(relay1, LOW);
digitalWrite(relay2, HIGH);
attachInterrupt(digitalPinToInterrupt (pinInterrupt), onChange, FALLING);
updateDHT();
displayIntro();
//Introduction.
delay(10000);
displayInit();
//Initializing...
delay(800);
// Serial.println("Sd start");
// SD.begin(CS_PIN);
if (!SD.begin()) {
Serial.println("initialization failed!");
file = SD.open("PVlogs.txt", FILE_WRITE);
if (file) {
Serial.println("Device Started...");
//Every start ng Device
file.println("Device Started...");
file.close();
// Serial.println("Sd end");
void onChange (){
if (digitalRead(pinInterrupt) == LOW)
Count++;
void dataLog(){
//saving at SD Card
currSave = millis();
if (currSave - prevSave >= intSave) {
prevSave = currSave;
Serial.println("SAVE!");
if (file) {
Serial.println("Writing");
file.print("|");
file.print(rtc.getDateStr());
file.print("|");
file.print(rtc.getTimeStr());
file.print("|");
file.print(windSpeed);
file.print("|");
file.print(temperature);
file.print("|");
file.print(humidity);
file.print("|");
if (relaySelect == 0){
file.print("PV Open CKT");
if (relaySelect == 1){
file.print("PV Short CKT");
if (relaySelect == 2){
file.print("15 Ohm Load");
file.print("|");
file.print(voltage);
file.print("|");
file.print(current);
file.print("|");
file.print(power);
file.println("|");
file.close();
// Serial.println("Writing Done!");
void updateDHT () {
//DHT22 Humidity &Temp Sensor.
currDHT = millis();
if (currDHT - prevDHT >= intDHT){
prevDHT = currDHT;
DHT.read22(DHT22_PIN);
temperature = DHT.temperature;
humidity = DHT.humidity;
Serial.println(temperature);
Serial.println(humidity);
void readAnemometer(){
//Wind Speed
if ((millis() - lastDebounceTime) > debounceDelay){
lastDebounceTime = millis();
windSpeed = (Count * 8.75)/100;
// Serial.println(windSpeed);
Count = 0;
void readPV() {
currReadPV= millis();
if (currReadPV - prevReadPV = intReadPV) {
prevReadPV = currReadPV;
reading_vol = ((analogRead(A0)/1023.0)*23.92);
// Voltage Reading. 1023 arduino max 12 102423-321.52 rom calibration with tester.
int adc = analogRead(A1):
float volt = (adc * 5.0)/1023.0;
//adc 5/1023
reading_cur = (volt-2.5)/0.66;
//from anemometer spreadsheet
initial_vol += reading_vol;
initial_cur += reading_cur;
samples++;
if (samples >-20) {
voltage = (initial_vol/20);
//20 samples/20 = Average Voltage & Current
if ((initial_cur/20) < 0) {
current = 0;
if ((initial_cur/20) >= 0){
current = (initial_cur/20);
power = voltage * current;
samples = 0;
initial_vol = 0;
initial_cur = 0;
void relayControl() {
//3Relay switches
if (relaySelect == 0) {
digitalWrite(relay1, LOW); //off
digitalWrite(relay2, HIGH); //off
digitalWrite(relay1, HIGH); //on
digitalWrite(relay2 , HIGH); //off
digitalWrite(relay2, LOW); //on
void btnDisp() {
currDisp = millis();
if (digitalRead(btnDisplay) == LOW) {
if (currDisp - prevDisp >= intDisp) {
prevDisp = currDisp;
display++;
if (display > 2){
display = 1;
void btnRel() {
currRel = millis();
if (digitalRead(btnRelay) == LOW) {
if (currRel - prevRel >= intRel) {
prevRel = currRel;
if (display == 1){
relaySelect;
if (relaySelect > 2){
relaySelect = 0;
if (display == 2) {
if (logInterval <= 995) logInterval = logInterval - 5;
if (logInterval == 999) logInterval = logInterval - 4;
if (logInterval <= 0) {
logInterval = 1;
intSave = logInterval * 1000;
void btnHld() {
currHold = millis();
if (digitalRead(btnHold) == LOW) {
if (currHold - prevHold >= intHold) {
prevHold = currHold;
if (display == 1) {
hold =! hold;
if (display == 2){
if (logInterval >= 5) logInterval = logInterval + 5;
if (logInterval == 1) logInterval = loginterval + 4;
if (logInterval > 999) {
logInterval = 999;
void displayIntro () {
//Intro Display
lcd.clear();
lcd.setCursor(1,0);
lcd.print("PV DATA LOGGER");
lcd.setCursor(9,1);
lcd.print("by");
lcd.setCursor(0,2);
lcd.print("JA BLANCAFLOR, RJ CUNANAN "):
lcd.setCursor (5,3);
lcd.print("J MALAYANG JR.");
void displayInit(){
lcd.clear();
lcd.setCursor(2, 2);
lcd.print("Initializing");
delay (800);
lcd.setCursor(2,2);
lcd.print("Initializing.");
delay (800);
lcd.setCursor(2,2);
lcd.print("Initializing..");
delay (800);
lcd.setCursor(2,2);
lcd.print("Initializing...");
delay (800);
lcd.clear();
lcd.setCursor(4,2);
lcd.print("LINK START!!");
delay (2000);
void displayCycle() {
//DISPLAYS; POSITIONING SA SCREEN
currDispCycle = millis();
if (currDispCycle - prevDispCycle >= intDispCycle) {
prevDispCycle = currDispCycle;
if (display == 1) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(rtc.getTimeStr());
lcd.setCursor(11,0);
lcd.print (windSpeed);
lcd.setCursor(16,0);
lcd.print("m/s");
lcd.setCursor(0,1);
lcd.print("RELAY:");
lcd.setCursor(6,1);
lcd.print("PV Open CKT");
lcd.setCursor(6,1);
lcd.print("PV Short CKT");
if (relaySelect == 2) {
lcd.setCursor(6,1);
lcd.print("15 Ohm Load");
lcd.setCursor(0,2);
lcd.print(temperature);
lcd.setCursor(5,2);
lcd.print("C");
lcd.setCursor(7,2);
lcd.print(humidity);
lcd.setCursor(10,2);
lcd.print("%");
lcd.setCursor(12,2);
lcd.print("P:");
lcd.setCursor (14,2);
lcd.print (power);
lcd.setCursor(19,2);
lcd.print("W");
lcd.setCursor(0,3);
lcd.print("VOLT:");
lcd.print (voltage);
lcd.setCursor (11,3);
lcd.print("AMP:");
lcd.setCursor(15,3);
lcd.print(current);
if (display == 2) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("DATE: ");
lcd.setCursor(6,0);
lcd.print(rtc.getDateStr());
lcd.setCursor (1,2);
lcd.print("DATA LOG INTERVAL");
lcd.setCursor(4,3);
lcd.print(logInterval);
lcd.setCursor(7,3);
lcd.print("second(s)");
if (!hold) {
readPV();
readAnemometer();
updateDHT();
dataLog();
displayCycle();
relayControl();
btnDisp();
btnRel();
btnHld();
In file included from C:\Users\user\Documents\THESIS\THESIS.ino:6:0:
c:\Users\user\Documents\Arduino\libraries\RTClib\src/RTClib.h:143:7: error: redefinition of 'class DateTime'
class DateTime {
In file included from C:\Users\user\Documents\THESIS\THESIS.ino:3:0:
c:\Users\user\Documents\Arduino\libraries\DS3231/DS3231.h:33:7: note: previous definition of 'class DateTime'
class DateTime {
C:\Users\user\Documents\THESIS\THESIS.ino:70:87: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
In file included from C:\Users\user\Documents\THESIS\THESIS.ino:7:0:
c:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
c:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate expects 3 arguments, 8 provided
c:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
class LiquidCrystal_I2C : public Print {
c:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate expects 1 argument, 8 provided
c:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
C:\Users\user\Documents\THESIS\THESIS.ino:71:1: error: 'dht' does not name a type
dht DHT;
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void setup()':
C:\Users\user\Documents\THESIS\THESIS.ino:83:7: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
setBacklight
C:\Users\user\Documents\THESIS\THESIS.ino:83:35: error: 'POSITIVE' was not declared in this scope
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void dataLog()':
C:\Users\user\Documents\THESIS\THESIS.ino:145:22: error: 'class RTC_DS3231' has no member named 'getDateStr'
C:\Users\user\Documents\THESIS\THESIS.ino:147:22: error: 'class RTC_DS3231' has no member named 'getTimeStr'; did you mean 'getTemperature'?
getTemperature
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void updateDHT()':
C:\Users\user\Documents\THESIS\THESIS.ino:191:12: error: expected unqualified-id before '.' token
C:\Users\user\Documents\THESIS\THESIS.ino:192:26: error: expected primary-expression before '.' token
C:\Users\user\Documents\THESIS\THESIS.ino:193:23: error: expected primary-expression before '.' token
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void readPV()':
C:\Users\user\Documents\THESIS\THESIS.ino:213:39: error: lvalue required as left operand of assignment
C:\Users\user\Documents\THESIS\THESIS.ino:220:35: error: expected ',' or ';' before ':' token
C:\Users\user\Documents\THESIS\THESIS.ino:225:26: error: 'volt' was not declared in this scope
C:\Users\user\Documents\THESIS\THESIS.ino:225:26: note: suggested alternative: 'hold'
hold
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void btnHld()':
C:\Users\user\Documents\THESIS\THESIS.ino:323:55: error: 'loginterval' was not declared in this scope
C:\Users\user\Documents\THESIS\THESIS.ino:323:55: note: suggested alternative: 'logInterval'
logInterval
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void displayIntro()':
C:\Users\user\Documents\THESIS\THESIS.ino:340:44: error: expected ';' before ':' token
C:\Users\user\Documents\THESIS\THESIS.ino: In function 'void displayCycle()':
C:\Users\user\Documents\THESIS\THESIS.ino:373:31: error: 'class RTC_DS3231' has no member named 'getTimeStr'; did you mean 'getTemperature'?
getTemperature
C:\Users\user\Documents\THESIS\THESIS.ino:420:31: error: 'class RTC_DS3231' has no member named 'getDateStr'
Multiple libraries were found for "Wire.h"
Used: C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Not used: C:\Users\user\Documents\Arduino\libraries\Wire-master
Multiple libraries were found for "LiquidCrystal_I2C.h"
Used: C:\Users\user\Documents\Arduino\libraries\LiquidCrystal_I2C-1.1.2
Not used: C:\Users\user\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master
exit status 1
Compilation error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
