Buongiorno a tutti, ho creato un theremin con una fotocellula con questo codice:
//pin definitions
#define PHONES 9 // headphones connected to digital pin 9
#define PHOTOCELL 0 //photocell analog in pin 0
//variable definitions
long val = 0; //stores raw value from photocell
long maxread = 0; //maximum value from calibration phase
long minread = 1000; // minimum value from calibration phase
double f = 0; // frequency of sound
double normf = 0; // normalized frequency
double logf = 0; // logarithm of normalized frequency
int ilogf = 0; // rounded logarithm
int i = 0; // loop dummy variable
double factor = 0; // scaling factor for calibration
double shift = 0; // shift for calibration
long maxfreq = 1048; // maximum desired frequency after calibration
long minfreq = 131; // minimum desired frequency after calibration
//magic numbers that make the intervals sound pleasing
double gap = 1.148698355; //ratio of consecutive notes (pentatonic)
// it's the 5th root of 2
//double gap = 1.059463094; //ratio of consecutive notes (chromatic)
// its the 12th root of 2
pinMode(PHONES, OUTPUT); // sets the digital pin as output
// calibration loop to determine a rasonable range of light levels (minread to maxread)
// and map that to frequencies between minfreq and maxfreq
for (i = 0; i< 500; i++) { // calibration loop runs for 5 seconds
val = analogRead(PHOTOCELL); // read photocell
tone(PHONES, val); // play raw tone to guide calibration
if (val > maxread) { // as the values climb, store the largest
maxread = val;
if (val < minread) { // as the values drop, store the smallest
minread = val;
delay(10); // reasonable delay
//Now we use the calibration to calculate scale and shift parameters
factor = (double)(maxfreq - minfreq) / (double)(maxread - minread); // scale parameter
//it's like a slope
shift = factor * minread - minfreq; //shift parameter: it's like an offset
f = factor * val - shift; // this linearly maps the frequency to
// a value between minfreq and maxfreq
// according to the calibration result
normf = f / (double) minfreq; // Dividing an exponential function by the min value
logf = log(normf) / log(gap); // allows us to take the log (base gap) and the result
ilogf = round(logf); // is the number of notes above the lowest, once we round it.
f = minfreq * pow(gap,ilogf); // we better "unlog" it.
tone(PHONES, f); // this produces the tone signal
Volevo poi aggiungere delle nuove fotocellule ma ho dei grossi problemi con il codice ho provato a farlo così ma da un sacco di errori. Scusate ma sono alle prime armi.
// Optical Theramin
//pin definitions
#define PHOTOCEL 1
long val1 = 0;
long maxread1 = 0;
long minread1 = 1000;
double f1 = 0;
double normf1 = 0;
double logf1 = 0;
int ilogf1 = 0;
int i1 = 0
double factor1 = 0;
double shift1 = 0;
long maxfreq1 = 1048
long minfreq1 = 131;
double gap1 = 1.148698355;
maxread = val;
minread = val;
val1 = analogRead(PHOTOCEL);
tone(PHONES, val1); // play raw tone to guide calibration
if (val1 > maxread1) { // as the values climb, store the largest
maxread1 = val1;
if (val1 < minread1) { // as the values drop, store the smallest
minread1 = val1;
//it's like a slope
factor1 = (double)(maxfreq1 - minfreq1) / (double)(maxread1 - minread1); // scale parameter
shift1 = factor1 * minread1 - minfreq1; //shift parameter: it's like an offset
normf1 = f1 / (double) minfreq1; // Dividing an exponential function by the min value
logf1 = log(normf1) / log(gap1); // allows us to take the log (base gap) and the result
ilogf1 = round(logf1); // is the number of notes above the lowest, once we round it.
f1 = minfreq1 * pow(gap1,ilogf1);
tone(PHONES, f,f1); // this produces the tone signal
Grazie mille, il problema è che funziona un solo sensore, nel codice ho aggiunto un'altra uscita per avere l'effetto stereo
//pin definitions
#define PHONES 9
#define PHONESB 8 // headphones connected to digital pin 9
#define PHOTOCELLA A0 //photocell analog in pin 0
#define PHOTOCELLB A1
long valA = 0; //stores raw value from photocell
long valB = 0;
long maxreadA = 0; //maximum value from calibration phase
long maxreadB = 0;
long minreadA = 1000; // minimum value from calibration phase
long minreadB = 1000;
double fA = 0; // frequency of sound
double fB = 0;
double normfA = 0; // normalized frequency
double normfB = 0;
double logfA = 0; // logarithm of normalized frequency
double logfB = 0;
int ilogfA = 0; // rounded logarithm
int ilogfB = 0;
double factorA = 0; // scaling factor for calibration
double factorB = 0;
double shiftA = 0; // shift for calibration
double shiftB = 0;
long maxfreqA = 1048; // maximum desired frequency after calibration
long maxfreqB = 1048;
long minfreqA = 131; // minimum desired frequency after calibration
long minfreqB = 131;
double gapA = 1.148698355; //ratio of consecutive notes (pentatonic)
double gapB = 1.148698355; //ratio of consecutive notes (chromatic)
pinMode(PHONESB, OUTPUT);
for (int i = 0; i < 500; i++) // calibration loop runs for 5 seconds
valA = analogRead(PHOTOCELLA); // read photocell
tone(PHONES, valA); // play raw tone to guide calibration
if (valA > maxreadA) // as the values climb, store the largest
maxreadA = valA;
if (valA < minreadA) // as the values drop, store the smallest
minreadA = valA;
delay(10);
valB = analogRead(PHOTOCELLB);
tone(PHONESB, valB); // play raw tone to guide calibration
if (valB > maxreadB) // as the values climb, store the largest
maxreadB = valB;
if (valB < minreadB) // as the values drop, store the smallest
minreadB = valB;
noTone(PHONES);
noTone(PHONESB);
factorA = (double)(maxfreqA - minfreqA) / (double)(maxreadA - minreadA); // scale parameter
//it's like a slope
factorB = (double)(maxfreqB - minfreqB) / (double)(maxreadB - minreadB); // scale parameter
shiftA = factorA * minreadA - minfreqA; //shift parameter: it's like an offset
shiftB = factorB * minreadB - minfreqB; //shift parameter: it's like an offset
valB = analogRead(PHOTOCELLB); // read photocell
fA = factorA * valA - shiftA; // this linearly maps the frequency to
normfA = fA / (double) minfreqA; // Dividing an exponential function by the min value
logfA = log(normfA) / log(gapA); // allows us to take the log (base gap) and the result
ilogfA = round(logfA); // is the number of notes above the lowest, once we round it.
fA = minfreqA * pow(gapA, ilogfA); // we better "unlog" it.
fB = factorB * valB - shiftB; // this linearly maps the frequency to
normfB = fB / (double) minfreqB; // Dividing an exponential function by the min value
logfB = log(normfB) / log(gapB); // allows us to take the log (base gap) and the result
ilogfB = round(logfB); // is the number of notes above the lowest, once we round it.
fB = minfreqB * pow(gapB, ilogfB);
tone(PHONES, fA);
tone(PHONESB,fB); }
Il problema è che funziona sempre un solo sensore quello collegato al pin 0 Non riesco a capire come fare per far funzionare tutti e due, se poi non è stereo non è importante mi interessa che funzionino tutti e due.
Grazie mille sei stato gentilissimo!! =)
fA è la frequenza del tono, mentre fB è la durata.
Il problema è che con quel tipo di sensori la risposta non è lineare. Inoltre dovresti aggiungere un LCD o il monitor seriale per verificare le operazioni di taratura.
Cosi alla cieca è difficile regolare lo strumento e attendersi dei buoni risultati, perché non sai che dati sta elaborando Arduino.
Grazie mille, io sono proprio all'inizio e mi incasino parecchio, non sapesti consigliarmi come fare? Magari con un altro tipo di codice. Grazie mille e scusa per le tante domande.
http://arduino.cc/en/reference/tone:
NOTE: if you want to play different pitches on multiple pins, you need to call noTone() on one pin before calling tone() on the next pin.
Sostanzialmente è difficile creare più toni perché devi fermare il precedente.
Ciao a tutti, volevo chiedere se c'era qualcuno che sapeva spiegarmi come fare, sono settimane che provo ma non so come fare =( Spero che qualcuno mi aiuti
Purtroppo l'autore non indica come ha fatto, ma probabilmente usa la tecnica di accendere il 1° tone, spegnerlo, accendere il secondo tone spegnerlo, accendere il terzo tone e ripartire da capo.
La velocità del loop da l'illusione che i 3 toni siano contemporanei.
Grazie, mille per la risposta. Non ho ancora avuto modo di provare. Volevo chiedere se in questo modo potevo fare lo stesso procedimento con altre fotocellule, magari in modo da creare un theremin con 5 sensori.
Grazie mille
Ciao a tutti, non avete dei consigli? Tutto quello fatto non funziona. Non riesco a creare un theremin con piú di una fotocellula. Non sapreste consigliarmi magari un progetto già fatto? Per me è importante riuscire a fare questa cosa. Grazie mille a tutti e buone feste
//pin definitions
#define PHONES 9
long valB = 0;
long maxreadB = 0;
double fB = 0;
double normfB = 0;
double logfB = 0;
int ilogfB = 0;
double factorB = 0;
double shiftB = 0;
maxreadA = valA;
minreadA = valA;
delay(10);
maxreadB = valB;
minreadB = valB;
noTone(PHONES);
noTone(PHONESB);
//it's like a slope
tone(PHONES, fA);
tone(PHONESB,fB); }
