Theremine Arduino project with the sparkfun musical instrument shield?
Hello, I found this theremin project with arduino but I need to use this sparkfun shield, I need help to make this project with the sparkfun shield, Thanks.
Knowing what the shield costs is of no use but a link to the datasheet, or users manual, would be.
Could You extract the facts from that project? Reading novels to find a few key components... not today.
Hey, thx for your answer i recon i didn't gave much info, here's the datasheet of the musical instrument shield: https://www.sparkfun.com/datasheets/Components/SMD/vs1053.pdf
The sparkfun shield seem to use different libraries to make sounds and the theremino project i found just uses 2 sensors to create the frequency and amplitude of the sound, i'd like to know if i can use the sparkfun shield simmilarly so i can copy the Theremino project and still use the shield.
PS: I'm doing this for a high school project and using the shield is required but i didn't found any project online that uses the shield to make a theremine so i just want to exploit the theremino project because i have 0 coding skills.
This is an advaced project. What's Your electronics skills?
Having no coding experience it looks like a nightmare to me.
There is no plug and play in this case.
A usual mistake is looking for a ready project to copy. Mostly it doesn't exist. What exists might be parts of the project. Finding and combining parts found in different projects is a more likely the way too solve the matter.
Sorry for not having any ready pieces to hand over to You.
What part of the project do you need help with?
