Good day guys, i really need your help, I want to use MLX90640 D55 thermal camera and ESP8266, the live feed should be displayed on web , so that I can view the feed on a remote device, help guys, if I can even get the full code it will be useful
What have you tried? Where are you stuck? Do you have the camera and the ESP8266 working together?
Have you been able to find any published 'full code' ?
There is a code i will show you that usually works with the camera and the output is displayed on the lcd
Nothing yet
hy guys i managed to get the code that displays the thermal image as an array of numbers on a serial monitor and thee other one on a LCD , but how can I modify it to send the image to web so that I can display the thermal feed on a dashboard
#include "Arduino.h"
#include "SPI.h"
#include "tft.h"
#include
#include "MLX90640_API.h"
#include "MLX90640_I2C_Driver.h"
#define EMMISIVITY 0.95
#define INTERPOLATE false
#define min(a,b) ((a)<(b)?(a):(b))
#define max(a,b) ((a)>(b)?(a):(b))
#define TA_SHIFT 8 //Default shift for MLX90640 in open air
// Output size
#define O_WIDTH 224
#define O_HEIGHT 168
#define O_RATIO O_WIDTH/32
paramsMLX90640 mlx90640;
const byte MLX90640_address = 0x33; //Default 7-bit unshifted address of the MLX90640
// Added for measure Temp
boolean measure = true;
float centerTemp;
unsigned long tempTime = millis();
unsigned long tempTime2 = 0;
// start with some initial colors
float minTemp = 20.0;
float maxTemp = 40.0;
// variables for interpolated colors
byte red, green, blue;
// variables for row/column interpolation
float intPoint, val, a, b, c, d, ii;
int x, y, i, j;
// array for the 32 x 24 measured tempValues
static float tempValues[32 * 24];
float **interpolated = NULL;
uint16_t *imageData = NULL;
TFT tft;
Serial.println("Hello.");
// Connect thermal sensor.
Wire.begin();
Wire.setClock(400000); // Increase I2C clock speed to 400kHz
Wire.beginTransmission((uint8_t)MLX90640_address);
if (Wire.endTransmission() != 0) {
Serial.println("MLX90640 not detected at default I2C address. Please check wiring.");
else {
Serial.println("MLX90640 online!");
// Get device parameters - We only have to do this once
int status;
uint16_t eeMLX90640[832];
status = MLX90640_DumpEE(MLX90640_address, eeMLX90640);
if (status != 0) Serial.println("Failed to load system parameters");
status = MLX90640_ExtractParameters(eeMLX90640, &mlx90640);
if (status != 0) Serial.println("Parameter extraction failed");
// Set refresh rate
MLX90640_SetRefreshRate(MLX90640_address, 0x05); // Set rate to 8Hz effective - Works at 800kHz
// Once EEPROM has been read at 400kHz we can increase
Wire.setClock(800000);
SPI.begin();
tft.begin();
tft.setRotation(0); // Use landscape format
tft.fillScreen(TFT_BLACK);
tft.setCursor(55, 228);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(4);
tft.print("WaveShare");
// Prepare interpolated array
interpolated = (float **)malloc(O_HEIGHT * sizeof(float *));
for (int i = 0; i < O_HEIGHT; i++) {
interpolated[i] = (float *)malloc(O_WIDTH * sizeof(float));
// Prepare imageData array
imageData = (uint16_t *)malloc(O_WIDTH * O_HEIGHT * sizeof(uint16_t));
// get the cutoff points for the color interpolation routines
// note this function called when the temp scale is changed
setAbcd();
drawLegend();
void loop(void) {
readTempValues();
setTempScale();
drawPicture();
drawMeasurement();
// Read pixel data from MLX90640.
void readTempValues() {
for (byte x = 0 ; x < 2 ; x++) // Read both subpages
uint16_t mlx90640Frame[834];
int status = MLX90640_GetFrameData(MLX90640_address, mlx90640Frame);
if (status < 0)
Serial.print("GetFrame Error: ");
Serial.println(status);
float vdd = MLX90640_GetVdd(mlx90640Frame, &mlx90640);
float Ta = MLX90640_GetTa(mlx90640Frame, &mlx90640);
float tr = Ta - TA_SHIFT; //Reflected temperature based on the sensor ambient temperature
MLX90640_CalculateTo(mlx90640Frame, &mlx90640, EMMISIVITY, tr, tempValues);
int row;
float temp, temp2;
void interpolate() {
for (row = 0; row < 24; row++) {
for (x = 0; x < O_WIDTH; x++) {
temp = tempValues[(31 - (x / 7)) + (row * 32) + 1];
temp2 = tempValues[(31 - (x / 7)) + (row * 32)];
interpolated[row * 7][x] = lerp(temp, temp2, x % 7 / 7.0);
for (y = 0; y < O_HEIGHT; y++) {
temp = interpolated[y - y % 7][x];
temp2 = interpolated[min((y - y % 7) + 7, O_HEIGHT - 7)][x];
interpolated[y][x] = lerp(temp, temp2, 1);//y%7/7.0);
// Linear interpolation
float lerp(float v0, float v1, float t) {
return v0 + t * (v1 - v0);
void drawPicture() {
if (INTERPOLATE) {
interpolate();
imageData[(y * O_WIDTH) + x] = getColor(interpolated[y][x]);
//tft.pushImage(8, 8, O_WIDTH, O_HEIGHT, imageData);
else {
for (y = 0; y < 24; y++) {
for (x = 0; x < 32; x++) {
tft.fillRect(8 + x * 7, 8 + y * 7, 7, 7, getColor(tempValues[(31 - x) + (y * 32)]));
// Get color for temp value.
uint16_t getColor(float val) {
pass in value and figure out R G B
several published ways to do this I basically graphed R G B and developed simple linear equations
again a 5-6-5 color display will not need accurate temp to R G B color calculation
equations based on
http://web-tech.ga-usa.com/2012/05/creating-a-custom-hot-to-cold-temperature-color-gradient-for-use-with-rrdtool/index.html
red = constrain(255.0 / (c - b) * val - ((b * 255.0) / (c - b)), 0, 255);
if ((val > minTemp) & (val < a)) {
green = constrain(255.0 / (a - minTemp) * val - (255.0 * minTemp) / (a - minTemp), 0, 255);
else if ((val >= a) & (val <= c)) {
green = 255;
else if (val > c) {
green = constrain(255.0 / (c - d) * val - (d * 255.0) / (c - d), 0, 255);
else if ((val > d) | (val < a)) {
green = 0;
if (val <= b) {
blue = constrain(255.0 / (a - b) * val - (255.0 * b) / (a - b), 0, 255);
else if ((val > b) & (val <= d)) {
blue = 0;
else if (val > d) {
blue = constrain(240.0 / (maxTemp - d) * val - (d * 240.0) / (maxTemp - d), 0, 240);
// use the displays color mapping function to get 5-6-5 color palet (R=5 bits, G=6 bits, B-5 bits)
//Serial.println(String(val) + " -> " + String(red) + "|" + String(green) + "|" + String(blue));
return tft.color565(red, green, blue);
void setTempScale() {
minTemp = 255;
maxTemp = 0;
for (i = 0; i < 768; i++) {
minTemp = min(minTemp, tempValues[i]);
maxTemp = max(maxTemp, tempValues[i]);
setAbcd();
drawLegend();
// Function to get the cutoff points in the temp vs RGB graph.
void setAbcd() {
a = minTemp + (maxTemp - minTemp) * 0.2121;
b = minTemp + (maxTemp - minTemp) * 0.3182;
c = minTemp + (maxTemp - minTemp) * 0.4242;
d = minTemp + (maxTemp - minTemp) * 0.8182;
// Draw a legend.
void drawLegend() {
float inc = (maxTemp - minTemp) / 224.0;
j = 0;
for (ii = minTemp; ii < maxTemp; ii += inc) {
tft.drawFastVLine(8 + + j++, 292, 20, getColor(ii));
tft.setTextSize(2);
tft.setCursor(8, 272);
tft.fillRect(8, 272, 45, 20, TFT_BLACK);
tft.print(String(minTemp).substring(0, 5));
tft.setCursor(192, 272);
tft.fillRect(192, 272, 45, 20, TFT_BLACK);
tft.print(String(maxTemp).substring(0, 5));
// Draw a circle + measured value.
void drawMeasurement() {
// Mark center measurement
tft.drawCircle(120, 8 + 84, 3, TFT_WHITE);
// Measure and print center temperature
centerTemp = (tempValues[383 - 16] + tempValues[383 - 15] + tempValues[384 + 15] + tempValues[384 + 16]) / 4;
tft.setCursor(86, 190);
tft.setTextSize(4);
tft.fillRect(86, 190, 80, 40, TFT_BLACK);
tft.print(String(centerTemp).substring(0, 5) + "C");
I really need your help guys
