thermal camera display
I have an AMG8833 thermal sensor with an arduino mega and a ILI9341 TFT 2.8" shield.
I have installed all the correct libraries and have adapted the Sheild screen for Mega by soldering closed the ICSP and splitting the 11 - 13.
I have tested the screen with some examples and it works fine and I tested the pixel array of the sensor in the serial monitor and both work fine independently.
However, when I run the Thermal_cam example, nothing is displayed on the screen. What could be the problem here? I am a newbie so am not totally confident with reading the code within the example and understanding everything it is doing. I am frantically undertaking tutorials to try to get better at this.
ode: [Select]
  This is a library for the AMG88xx GridEYE 8x8 IR camera
  This sketch makes a 64 pixel thermal camera with the GridEYE sensor
  and a 128x128 tft screen https://www.adafruit.com/product/2088
  Designed specifically to work with the Adafruit AMG88 breakout
  ----> http://www.adafruit.com/products/3538
  These sensors use I2C to communicate. The device's I2C address is 0x69
  Adafruit invests time and resources providing this open source code,
  please support Adafruit andopen-source hardware by purchasing products
  from Adafruit!
  Written by Dean Miller for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_AMG88xx.h>
#define TFT_CS     10 //chip select pin for the TFT screen
#define TFT_RST    9  // you can also connect this to the Arduino reset
                      // in which case, set this #define pin to 0!
#define TFT_DC     8
//low range of the sensor (this will be blue on the screen)
#define MINTEMP 22
//high range of the sensor (this will be red on the screen)
#define MAXTEMP 34
//the colors we will be using
const uint16_t camColors[] = {0x480F,
0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
0xF080,0xF060,0xF040,0xF020,0xF800,};
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
Adafruit_AMG88xx amg;
unsigned long delayTime;
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
uint16_t displayPixelWidth, displayPixelHeight;
    Serial.println(F("AMG88xx thermal camera!"));
    tft.initR(INITR_144GREENTAB);   // initialize a ST7735S chip, black tab
    tft.fillScreen(ST7735_BLACK);
    displayPixelWidth = tft.width() / 8;
    displayPixelHeight = tft.height() / 8;
    //tft.setRotation(3);
    bool status;
    // default settings
    status = amg.begin();
    if (!status) {
        Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
        while (1);
    Serial.println("-- Thermal Camera Test --");
    delay(100); // let sensor boot up
  //read all the pixels
  amg.readPixels(pixels);
  for(int i=0; i<AMG88xx_PIXEL_ARRAY_SIZE; i++){
    uint8_t colorIndex = map(pixels[i], MINTEMP, MAXTEMP, 0, 255);
    colorIndex = constrain(colorIndex, 0, 255);
    //draw the pixels!
    tft.fillRect(displayPixelHeight * floor(i / 8), displayPixelWidth * (i % 8),
        displayPixelHeight, displayPixelWidth, camColors[colorIndex]);
Duplicate post reported.
Duplicate here.
Do not repeat topics.
Thread locked.
