Thermal printer and Arduino
Hello friends!
I have an interesting project that I'm trying to finish. My project is associated with an attempt to print an image on a thermal printer by Arduino.
I connected the printer to the Arduino board, wrote my sketch and brought to print easy image. Its just line or pionts. But when I decided to print text or an image, it did not work out.
Please tell me how can I fix my sketch for printing text or images on the Arduino?
#define STP 2
#define DIR 3
#define DSTL 8
#define DSTR 9
#define LATCH 10
#define CLK 11
#define DAT 12
  int v = 0;
  pinMode(STP, OUTPUT);
  pinMode(DIR, OUTPUT);
  pinMode(DSTL,  OUTPUT);
  pinMode(DSTR,  OUTPUT);
  pinMode(LATCH,  OUTPUT);
  pinMode(CLK,  OUTPUT);
  pinMode(DAT, OUTPUT);
  digitalWrite(STP,  LOW);
  digitalWrite(DIR,  HIGH);
  digitalWrite(DSTL,  LOW);
  digitalWrite(DSTR,  LOW);
  digitalWrite(LATCH,  HIGH);
  digitalWrite(CLK,  LOW);
  digitalWrite(DAT, LOW);
void stepper(unsigned int Step, int Speed, boolean Set) {
  digitalWrite(DIR, Set);
  for (int i = 0; i < Step; i++) {
    digitalWrite(STP, HIGH);
    delayMicroseconds(Speed);
  byte masks[130] = {B00110000, B01001010, B01001010, B01001010, B01111100, B01111111, B01001000, B01001000, B01001000, B00110000, B00111100, B01000010, B01000010, B01000010, B00100100, B00111000, B01000100, B01000100, B01000100, B01111111, B00111100, B01001010, B01001010, B01001010, B00101100, B00001000, B01111100, B00001010, B00001010, B00000010, B00111100, B01000010, B01010010, B01010010, B00110100, B01111110, B01001000, B01001000, B01001000, B00110000, B00000000, B00001000, B01111010, B00000000, B00000000, B00000000, B01000000, B01001000, B00111010, B00000000, B01111110, B00010000, B00101000, B01000100, B00000000, B00000000, B00000010, B00111110, B01000000, B00000000, B01111100, B00000100, B01111000, B00000100, B01111000, B01111110, B01001000, B01001000, B01001000, B00110000, B00111100, B01000010, B01000010, B01000010, B00111100, B01111110, B00010010, B00010010, B00010010, B00001100, B01111110, B01001000, B01001000, B01001000, B00110000, B00110000, B01001000, B01001000, B01001000, B01111110, B01001100, B01001010, B01010010, B01010010, B00110010, B00000100, B00111111, B01000100, B01000100, B00000100, B00111100, B01000000, B01000000, B01000000, B01111100, B00001100, B00110000, B01000000, B00110000, B00001100, B00011110, B01100000, B00011000, B01100000, B00011110, B01000010, B00100100, B00011000, B00100100, B01000010, B00100110, B01001000, B01001000, B01001000, B00111110, B01000010, B01100010, B01010010, B01001010, B01000110};
  for (int d = 0; d < 8; ++d)
    for (int d1 = 0; d1<10; ++d1)
    Serial.print("Burning: ");
    for (int i = 0; i < 130; ++i)
      int v;
      for (int j = 0; j < 5; ++j)
        digitalWrite(DAT, bitRead(masks[i], d) != 0 ? HIGH : LOW);
        // digitalWrite(DAT, HIGH);
        digitalWrite(CLK, HIGH);
    Serial.println("Byte reat +1 ");
    Serial.println("Close LATCH: ");
    digitalWrite(LATCH, LOW);
    digitalWrite(DSTL, HIGH);
    delay(8);
    digitalWrite(DSTR, HIGH);
    delay(8);
    Serial.println(' ');
    stepper (10, 400, 0);
Is
your
enter
key
broken?
Get it fixed.
There is no reason for this to be in loop() or in SRAM.
I have n idea what that code is doing, or what you expect it to do.
Magic numbers suck. Replace then with named constants that describe what the value means.
