Hi!
Sorry, this should be in Interfacing Software Section!!
Is it possible to run Firmata on Arduino AND print on a Thermal Printer? Or would there be baud setting conflicts?
I have a Processing sketch handling a dialogue on a screen with relays, buttons, etc. and at some point I would like to print out on a Thermal Printer. The print is always the same though, so it could be in written the Arduino code and only triggered by the Processing Sketch (assuming I manage to merge the Thermal Printer library with the Firmata and Upload it both to an Arduino).
As far as I understand Firmata uses a different baud setting using the Serial than what I see in AdaThermal Printer Library Sketches, but since I'm newbish I'm not sure if thats a problem.
Because the Arduino code is uploaded beforehand, and then I just use the Serial in Processing and it doesnt matter, correct? Or would I need a second Arduino for it?
Thanks,
09
