Thermal sensors
Hi, i have a academic project that consist to build a automatic anti-incendiary turret.
i am looking for a thermal sensor that can detect high temperature, i dont much care about FOV and anbient temperature. But the range, alots. I can seem to find something that can exceed 200cm. do you have any suggestion ? thank you!
Define "high"
(Melting ice is around 273K)
And define "range, alots"
If "anti-incendary" means "flame detection followed by fire suppression," then try searching on uv/ir flame detector.
Would 61 meters be enough? US$3000.
https://www.jjstech.com/fs24x-911-21-5.html?gclid=EAIaIQobChMI1se6qqTi9gIVMQV9Ch00nw74EAQYASABEgL18fD_BwE
How about a PIR sensor? Range is easily > 200cm with the necessary signal conditioning.
If your goal is to be able to sense an incoming "hot" device and shoot at it I would think you would need an FLIR "camera" sensor.
You should, because single-element sensors report the average temperature of the FOV.
How fast is this thing moving and what direction from the sensor's point of view?
You will also need Nomex underware :slight_smile:
