Thermistor and Piezo Element
Hello all! I need some help with a project I'm trying to improve upon! I've set up a 10k thermistor and LCD screen to my Arduino Uno and programed it to where the temperature that the thermistor is reading is shown on the LCD in degrees Fahrenheit. I used the attached schematic and the flowing code and it works perfectly! I was wondering if there is any way I could attach a Piezo Element to my board and program it to where when the thermistor reads a range of specified temperatures the Piezo Element will buzz? If so, what do I need to add to my current code? Please be as detailed as possible I'm still pretty new at this and still learning!
Thanks in advance!
LCD Thermistor Reading code:
Sketch that reads temperature from a thermistor and displays
the result on an LCD screen
LCD Connections:
  • LCD RS pin to digital pin 2
  • LCD Enable pin to digital pin 3
  • LCD D4 pin to digital pin 4
  • LCD D5 pin to digital pin 5
  • LCD D6 pin to digital pin 6
  • LCD D7 pin to digital pin 7
  • LCD R/W pin to ground
//include the LCD library
#include <LiquidCrystal.h>
// analog input pin used for thermistor input
#define TEMPINPUT A0
// thermistor resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// thermistor temperature at nominal resistance
#define TEMPERATURENOMINAL 25
// beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the 'other' voltage divider resistor
#define SERIESRESISTOR 10000
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 20
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(2,3,4,5,6,7);
void setup(void) {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Current Temp:");
void loop(void) {
int i=0; //used for average
float temp_adc; //latest temperature input ADC value
float temp_avg = 0; //average temperature input ADC value
float temp_resistance; //resistance calculated from avg ADC value
//read analog voltage on temp input pin - will be between 0 and 1023
//take NUMSAMPLES and average values
for (i=0;i<NUMSAMPLES;i++)
temp_adc = analogRead(TEMPINPUT);
temp_avg = temp_avg + temp_adc / NUMSAMPLES;
//convert ACDC value to resistance
temp_resistance = THERMISTORNOMINAL / (1023.0/temp_avg-1.0);
//the following equations convert the thermistor resistance
//to a temperature in degrees Fahrenheit
float steinhart;
steinhart = temp_resistance / THERMISTORNOMINAL; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to C
steinhart = (steinhart + 40)*9.0/5.0 - 40; // convert to F
//Move cursor to the first position in the second row
lcd.setCursor(0,1);
//Print temperature
lcd.print(steinhart);
//lcd.print(" ");
lcd.print((char)223); //Print degree symbol
lcd.print("F");
delay(100);
Well do youself a favour and read the how to use this forum sticky post hidden at the start of every section of this board.
It will tell you about how to correctly post code.
A schematic would be good. You posted a physical layout diagram which is TOTALLY useless for assessing what a circuit actually does.
