Thermistor Connections
After months of googling I'm starting to make sense on this until I found this page
where they state
The ADC is optimized for analog signals with an output impedance of approximately 10 k or less.
I'm using the ET-73 probes and have it wired up like this
http://hruska.us/tempmon/
I measured my thermistor with my DMM at about 220k at room temperature and have a 22k dividing resistor as shown on the link. Do I need to do something else with my circuit or am I ok?
Thanks
John
It should be OK, however as the impedance is higher it might need longer to settle down when swapping inputs. To do this take a reading of one analogue input, delay a few milliseconds and then take the reading again. Disregard the first reading and use the second one.
Thanks Mike. I assume that means if I read analog 1 then read analog 2 when I switch to analog 2 or back to analog 1 put in the delay.
John
Always do:-
read channel - delay - read channel and use results
for what ever channel you want to use.
While playing with some code to directly control mux channel selection I found that a delay(50), 50millisec, was a good value to get a stable and accurate reading after selecting a different channel.
Lefty
Yes but it does depend on the impedance of the voltage source you are measuring.
Yes, fact. I was reading the internal bandgap voltage.
Lefty
