Thermistor & Servo Circuit Code
I am creating a thermistor, servo circuit where IF the temperature goes ABOVE 65-70C, the servo sweeps. The servo will click on a mouse. Then once it reaches back down to 48-52C, the servo sweeps again. But when the temperature goes above 65-70C, it sweeps, then it hits that range again and it sweeps. When the temperature is decreasing, I can't have the servo sweep or else it defeats the purpose. I need it to NOT sweep when the temperature is increasing. There should only be 2 sweeps in the system, but as of right now there are 3. Also, when it is in that range of temperature, it sweeps multiple times. I need it to sweep ONCE. It is supposed to imitate a click of a mouse for a mac. Below are the code and the circuit diagram. I have multiple attempts of an if statement, but they all have a 3rd sweep.
Any ideas would be amazing!
//library code:
#include <LiquidCrystal.h>
#include <Servo.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//Servo
Servo servo;
int pos = 0;
//Temp
double temp;
int ThermistorPin;
 //LCD Message
 lcd.begin(16, 2);
  lcd.setCursor(0, 0);
 lcd.println("Temperature: ");
 //Servo
 servo.attach(10);
 servo.write(0);
 //Led
 pinMode(7, OUTPUT);
 digitalWrite(7, LOW);
 ThermistorPin = analogRead(A0);
 temp = (double)ThermistorPin / 1024;
 temp = temp * 5;
 temp = temp - 0.5;
 temp = temp * 100;
 lcd.setCursor(0,1);
 Serial.println(temp);
 lcd.setCursor(0, 2);
 lcd.println(temp);
 //Servo
 if(temp <= 65 && temp >= 45){
   digitalWrite(7, HIGH);
  servo.write(0);
   delay(400);
   servo.write(50);
   delay(400);
   servo.write(0);
 //65 - 70 C, Hit
 if((int)temp == 65 ||(int)temp == 66 ||(int)temp == 67 || (int)temp == 68 ||(int)temp == 69||(int)temp == 70){
   servo.write(0);
   delay(400);
  servo.write(50);
   delay(400);
   servo.write(0);
 //65 - 70 C, No hit
 else if((int)temp == 65 ||(int)temp == 66 ||(int)temp == 67 || (int)temp == 68 ||(int)temp == 69||(int)temp == 70){
  servo.write(0);
   delay(400);
 //50 - 55 C, Hit
 else if((int)temp == 48||(int)temp == 49 ||(int)temp == 50 || (int)temp == 51 ||(int)temp == 52||(int)temp == 53){
   servo.write(0);
   delay(400);
  servo.write(50);
   delay(400);
   servo.write(0);
 //Repeat
 if(temp >= 65){
 for(pos = 0; pos <= 50; pos +=1){
   servo.write(pos);
delay(15);
   for(pos = 50; pos >= 50; pos-=1){
    servo.write(pos);
     delay(15);
else if(temp <= 51){
   servo.write(pos);
   delay(50);
    servo.write(pos);
     delay(15);
Don’t connect servo +5 to controller +5. Connect it dirctly to the power supply.
No power supply showed in Fritz.
