Hello,
I am new to arduinoand had a friend help me set up my printers firmware with thermocouples but I believe that It has not worked well given that I am having more problems than the advantage of printing more materials.
to begin, thermos read 5 degrees higher than thermistors. fluctuations are abrupt by only giving them body heat while thermos maintain a smooth temp curve.
Im not able to reach my temp and maintain it, needles to say it takes a very long time to reach. have done PID tunes but no help there, could it be fans are too high?
I am running marlin, using an azteeg X3 pro with 24V heaters. I would like to know if anyone has any info as to where do I change the TC1 pin to my pin11 used for thermistors I thought it would be on pins.h but no data is there. also he turned off my max temp safety and I dont know where to turn it back on. already changed the -1 sensor to 5 which is the value for thermistors.
any help would be appreciated, I have attached my firmware if that helps I know they are 2 different issues Heating problems and thermal sensors but I thought it would be easier to consolidate both problems in one post.
Thank you
Marlin2 (2).zip (326 KB)
