I am new on Arduino programming. As my first project, I would like to read the 16-bit number that directly measured from the MAX6675 thermocouple and then convert the number to a PWM output from the Arduino. Could anyone help me with this?
Is this your second post on the same topic,, using a slightly different alias?
Do not waste our time by cross posting.
It is easy but I do not want to wast my time on cross posting! This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
Code for Uno, Nano, Mini (MOSI-11, MISO-12, SCLK-13, CS-up to you, except pin no.10)
#include <SPI.h>
#include <MAX6675.h> //https://github.com/enjoyneering/MAX6675
uint16_t temperature = 0;
MAX6675 myMAX6675(4); //cs - chip select, pin 4
myMAX6675.begin(); //start MAX6675
while (myMAX6675.getChipID() != MAX6675_ID)
Serial.println(F("MAX6675 error"));
delay(5000);
Serial.println(F("MAX6675 OK"));
if (myMAX6675.detectThermocouple() == true)
Serial.println(F("K-Thermocouple is connected to MAX6675 terminals 'T+' & 'T-'"));
Serial.println(F("K-Thermocouple is broken, unplugged or 'T-' terminal is not grounded"));
pinMode(5, OUTPUT);
pinMode(13, OUTPUT);
temperature = myMAX6675.getTemperature();
if (temperature != MAX6675_ERROR)
Serial.println(temperature);
temperature = map(temperature, 0, 1024, 0, 255); //0°C...+1024°C to 0..255 PWM
analogWrite(5, temperature);
digitalWrite(13, LOW);
analogWrite(5, 0);
digitalWrite(13, HIGH);
