Thermocouple Multiplexer Shield (K - MAX31855K) initialize SD card Problem
I have a Arduino Thermocouple Multiplexer Shield (K - MAX31855K) and a Logging Recorder Shield Data Logger Module Data Logging shield for Arduino UNO SD Card and a Arduino Uno R3 Microcontroller.
I can make the Multiplexer shield work and send it to the serial monitor, but as soon I uncomment the initialization part of the SD card, it interferes with thermocouple shield.
Please help me I am getting slowly frustratet.
#include <string.h> //Use the string Library
#include <ctype.h>
#include <EEPROM.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <RTClib.h>
const int chipSelect = 10;
RTC_DS3231 rtc;
char buf1[20];
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
//#define SHOWMEYOURBITS // Display the raw 32bit binary data from the MAX31855
#define PINEN 7 //Mux Enable pin
#define PINA0 4 //Mux Address 0 pin
#define PINA1 5 //Mux Address 1 pin
#define PINA2 6 //Mux Address 2 pin
#define PINSO 12 //TCAmp Slave Out pin (MISO)
#define PINSC 13 //TCAmp Serial Clock (SCK)
#define PINCS 9 //TCAmp Chip Select Change this to match the position of the Chip Select Link
int Temp[8], SensorFail[8];
float floatTemp, floatInternalTemp;
char failMode[8];
int internalTemp, intTempFrac;
unsigned int Mask;
//char data[16];
char i, j, NumSensors =8, UpdateDelay;
char Rxchar, Rxenable, Rxptr, Cmdcomplete, R;
char Rxbuf[32];
char adrbuf[3], cmdbuf[3], valbuf[12];
int val = 0, Param;
unsigned long time;
Serial.println("TCMUXV3");
// This here uncommented breaks the program
// while (!Serial) {
// ; // wait for serial port to connect. Needed for native USB port only
// Serial.print("Initializing SD card...");
// // see if the card is present and can be initialized:
// if (!SD.begin(chipSelect)) {
// Serial.println("Card failed, or not present");
// // don't do anything more:
// return;
// Serial.println(" card initialized.");
// if (! rtc.begin()) {
// Serial.println("Couldn't find RTC");
// while (1);
// delay(2000);
if (EEPROM.read(511)==1)
NumSensors = EEPROM.read(0);
UpdateDelay = EEPROM.read(1);
pinMode(PINEN, OUTPUT);
pinMode(PINA0, OUTPUT);
pinMode(PINA1, OUTPUT);
pinMode(PINA2, OUTPUT);
pinMode(PINSO, INPUT);
pinMode(PINCS, OUTPUT);
pinMode(PINSC, OUTPUT);
digitalWrite(PINEN, HIGH); // enable on
digitalWrite(PINA0, LOW); // low, low, low = channel 1
digitalWrite(PINA1, LOW);
digitalWrite(PINA2, LOW);
digitalWrite(PINSC, LOW); //put clock in low
delay(2000);
if (millis() > (time + ((unsigned int)UpdateDelay*1000)))
time = millis();
//for(j=0;j<NumSensors;j++)
if (j<(NumSensors-1)) j++;
else j=0;
switch (j) //select channel
case 0:
case 1:
digitalWrite(PINA0, HIGH);
case 2:
digitalWrite(PINA1, HIGH);
case 3:
case 4:
digitalWrite(PINA2, HIGH);
case 5:
case 6:
case 7:
delay(5);
digitalWrite(PINCS, LOW); //stop conversion
delay(5);
digitalWrite(PINCS, HIGH); //begin conversion
delay(100); //wait 100 ms for conversion to complete
digitalWrite(PINCS, LOW); //stop conversion, start serial interface
delay(1);
Temp[j] = 0;
failMode[j] = 0;
SensorFail[j] = 0;
internalTemp = 0;
for (i=31;i>=0;i--)
digitalWrite(PINSC, HIGH);
delay(1);
//print out bits
#ifdef SHOWMEYOURBITS
if (digitalRead(PINSO)==1)
Serial.print("1");
Serial.print("0");
#endif
if ((i<=31) && (i>=18))
// these 14 bits are the thermocouple temperature data
// bit 31 sign
// bit 30 MSB = 2^10
// bit 18 LSB = 2^-2 (0.25 degC)
Mask = 1<<(i-18);
if (i == 31)
Temp[j] += (0b11<<14);//pad the temp with the bit 31 value so we can read negative values correctly
Temp[j] += Mask;
//Serial.print("1");
// Serial.print("0");
//bit 17 is reserved
//bit 16 is sensor fault
if (i==16)
SensorFail[j] = digitalRead(PINSO);
if ((i<=15) && (i>=4))
//these 12 bits are the internal temp of the chip
//bit 15 sign
//bit 14 MSB = 2^6
//bit 4 LSB = 2^-4 (0.0625 degC)
Mask = 1<<(i-4);
if (i == 15)
internalTemp += (0b1111<<12);//pad the temp with the bit 31 value so we can read negative values correctly
internalTemp += Mask;//should probably pad the temp with the bit 15 value so we can read negative values correctly
//bit 3 is reserved
if (i==2)
failMode[j] += digitalRead(PINSO)<<2;//bit 2 is set if shorted to VCC
if (i==1)
failMode[j] += digitalRead(PINSO)<<1;//bit 1 is set if shorted to GND
if (i==0)
failMode[j] += digitalRead(PINSO)<<0;//bit 0 is set if open circuit
delay(1);
//delay(1);
//Serial.println();
//Serial.println(Temp,BIN);
Serial.print("#");
Serial.print(j+1,DEC);
Serial.print(": ");
Serial.print('\t');
if (SensorFail[j] == 1)
Serial.print("FAIL");
if ((failMode[j] & 0b0100) == 0b0100)
Serial.print(" SHORT TO VCC");
if ((failMode[j] & 0b0010) == 0b0010)
Serial.print(" SHORT TO GND");
if ((failMode[j] & 0b0001) == 0b0001)
Serial.print(" OPEN CIRCUIT");
floatTemp = (float)Temp[j] * 0.25;
Serial.print(floatTemp,2);
Serial.print('\t');
//This bit doesn't work for neg temps
/*Serial.print(Temp[j]>>2,DEC);
Serial.print(".");
if ((Temp[j] & 0b11) == 0b00)
Serial.print("00");
if ((Temp[j] & 0b11) == 0b01)
Serial.print("25");
if ((Temp[j] & 0b11) == 0b10)
Serial.print("50");
if ((Temp[j] & 0b11) == 0b11)
Serial.print("75");
//Serial.print(" degC");
//delay(1000);
}//end reading sensors
//Serial.println("");
Serial.print(" Int: ");
floatInternalTemp = (float)internalTemp * 0.0625;
Serial.print('\t');
Serial.print(floatInternalTemp,4);
//This doesn't work for negative values
Serial.print(internalTemp>>4);
Serial.print(".");
intTempFrac = (internalTemp & 0x0F)*625;
Serial.print(intTempFrac/1000);
intTempFrac = intTempFrac%1000;
Serial.print(intTempFrac/100);
intTempFrac = intTempFrac%100;
Serial.print(intTempFrac/10);
intTempFrac = intTempFrac%10;
Serial.print(intTempFrac/1);
Serial.println("");
}//end time
if (Serial.available() > 0) // Is a character waiting in the buffer?
Rxchar = Serial.read(); // Get the waiting character
if (Rxchar == '@') // Can start recording after @ symbol
if (Cmdcomplete != 1)
Rxenable = 1;
Rxptr = 1;
}//end cmdcomplete
}//end rxchar
if (Rxenable == 1) // its enabled so record the characters
if ((Rxchar != 32) && (Rxchar != '@')) //dont save the spaces or @ symbol
Rxbuf[Rxptr] = Rxchar;
//Serial.println(Rxchar);
Rxptr++;
if (Rxptr > 13)
Rxenable = 0;
}//end rxptr
}//end rxchar
if (Rxchar == 13)
Rxenable = 0;
Cmdcomplete = 1;
}//end rxchar
}//end rxenable
}// end serial available
if (Cmdcomplete == 1)
Cmdcomplete = 0;
cmdbuf[0] = toupper(Rxbuf[1]); //copy and convert to upper case
cmdbuf[1] = toupper(Rxbuf[2]); //copy and convert to upper case
cmdbuf[2] = 0; //null terminate Command = Chr(rxbuf(3)) + Chr(rxbuf(4))
// Command = Ucase(command)
//Serial.println(cmdbuf);
valbuf[0] = Rxbuf[3]; // Mystr = Chr(rxbuf(5))
R = Rxptr - 1;
for (i = 4 ; i <= R ; i++)//For I = 6 To R
valbuf[i-3] = Rxbuf*; //Mystr = Mystr + Chr(rxbuf(i))*
  • valbuf[R+1] = 0; //null terminate*
  • Param = atoi(valbuf);// Param = Val(mystr)*
  • //Serial.println(Param); // 'Print "Parameter: " ; Param*
  • if (strcmp(cmdbuf,"NS")==0) //NumSensors*
  • //'Print "command was ON"*
  • if ((Param <= 8) && (Param > 0))*
  • NumSensors = Param; *
  • if (strcmp(cmdbuf,"UD")==0) //UpdateDelay*
  • if ((Param <= 60) && (Param >= 0))*
  • UpdateDelay = Param; *
  • if (strcmp(cmdbuf,"SV")==0) //Save*
  • EEPROM.write(0,NumSensors);*
  • EEPROM.write(1,UpdateDelay);*
  • EEPROM.write(511,1);*
