thermocouple problem with arduino
hello my friends
I use a thermocouple with a map arduino
the problem I receive Forever 0 (c=0)
help me
thank you in advance
i use this programme arduino :
#include <Adafruit_MAX31855.h>
int thermoDO = 2;
int thermoCS = 4;
int thermoCLK = 7;
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
Serial.println(“MAX31855 test”);
Serial.print("Internal Temp = ");
Serial.println(thermocouple.readInternal());
double c = thermocouple.readCelsius();
if (isnan(c)) {
Serial.println(“Something does not work with the thermocouple!”);
Serial.print("C = ");
Serial.println(c);
Is that the Adafruit example program?
Why have you not put your code in code tags as requested in the "How to use this forum" ?
...R
Do you have a thermocouple hooked up (and are sure its not open)?
Do you have the polarity correct on the thermocouple?
Do you have a scope, can you tell is SPI communications is working?
Jacob
