I am trying to get an esp-wroom-32ue to read the analog output of a circuit based on LTC1049 datasheet But it is just not working. I am using GPIO2 on the esp datasheet
The circuit design looks like this:
When I connect my thermocouple and power the board I am just reading near 0 analog numbers on the serial monitor. The readings I am getting are basically 0C and not responding when I put the sensor in a cup of hot water. I have verified that the connections on the PCB layout below are as intended and I am seeing 5V power to the IC chips and ground connections are there. Here is a screenshot of the PCB. I am
I havent personally used GPIO2 as an analog input - I believe its connected to the on-board LED on some devkits.
With the thermistor disconnected you can apply a small positive voltage to Kthermo+ and use a meter to measure GPIO_Temp.
I made a divider box with a chain of 91k/9k1/910/91/9.1/1 ohm resistors to give me an easy way to produce small voltages. Not hugely accurate but useful.
Thanks for the responses. While I was checking the voltage I realized IC202 was in the wrong orientation which was a huge mistake. Not sure whether or not this damaged the IC chip but here is a before and after:
Before
Now to answer @TomGeorge question pin 6 is showing a steady 0.27V and the GPIO pad is reading 0.106V from the multimeter. But I am just getting analog 0 readings on the gpio2 after the rework. So not sure why I am not reading 0.106V in the serial monitor... Also I do have the breakout board you mentioned but I am going for something on a PCB and it has to output an analog voltage because I have other sensors that need the SPI pins.
“ The same happens for very low voltage values: for 0 V and 0.1 V you’ll get the same value: 0. You need to keep this in mind when using the ESP32 ADC pins.”
Do you have the Arduino 0v and amplifier 0v connected together ?
yes the grounds are connected through a ground plane on my PCB.
Disconnect everything from the Arduino and run the sketch , you should get random values from an open circuit analog input .
Not an option for me here as everything is on a PCB. But I have seen this happen, so I understand your point. Analog range is 4096 ?
I think you might be on to something here.. When I search it does say 12bit 4096 resolution.
I see your point about low voltages reading 0. So let me do a quick calculation on the voltage to expect. Room is at 27C with the range of the circuit being 0 degrees is 0 volts and 400 degrees is 4 volts than I should expect to see 0.27V. If 3.3V is 4096 then 0.27V is 335 analog reading.. So much higher than I am seeing.
Why have you loaded down the LT1049 output with < 1k? Its not specced for anything like that low an impedance. 10k load is the smallest mentioned in the datasheet, as is 100k. Perhaps use 100k load.
Something may be up here. Looking back I think R203 and 204 may have been a mistake. This is altering my measurement, but I was worried about having more than 3.3V on the GPIO. Should I just remove the voltage divider? I know I won't see 330C which corresponds to 3.3V.
Don't remove the divider if you need it, just don't use impedances well below the datasheet's recommendations. Normally to reduce 5V to 3.3V you can use 10k upper resistor and 22k lower resistor, which actually maxes at 3.4V or so, but that's no problem. The LT1049 then sees about 28k net impedance which is far nicer than 840 ohms.
I had no idea this mattered, and this is probably the issue. But don't really understand, if you could explain why the impedance matters...
Took off R203 and R204 and shorted R203's pads together getting much better readings now. But they are still off, I am going to post a temperature curve shortly.
Not looked at your circuit in detail , but do you have cold junction compensation .
IMO as the output of thermocouples is so low , they are are not good for low temperatures , you also need that second , different technology sensor for the cold junction, further increasing error routes .
