EcoIV
1
Hello all,
i have a totally wrong reading on my simple thermometer, following the wires and results.
float temp;
int tempPin = 0;
temp = analogRead(tempPin);
temp = temp * 0.48828125;
Serial.print(temp);
delay(2000);
Images attached
My readings are all above 450+ instead of ~20°C
Is it wrong?
Thank You
Mattia
Please read and follow the directions in "how to use this forum". Few people will download from a site.
EcoIV
5
I'm using a Dallas DS18B20,
with A0 or 0 i get the same result
The code you have is not intended to read the DS18B20. You will need a library for that, or follow this Hacktronix tutorial.
EcoIV:
Your pic shows a TMP36 and your code reads an analog input, hence my suggestion
