I have the code that is kinda working. It is turning on the heating element and turning it off when I warn the thermistor but the screen is getting jumbled up. It't because the code I am using was originally written for the Uno and I have to use the MEGA2560.
I have attached photo
I am using a Mosfit in place of the LCD.
#include <LiquidCrystal.h>// include the library code
int tempPin = A0; // make variables// thermistor is at A0
int tup = 3; //Temp up button
int tdown = 4; //Temp down button
int tcf = 5; //F to C toggle
boolean far = true; //Default F to true
boolean cel = false; //Default C to false
boolean lightMe; //Light up LED
char abbrv; //Shortcut for C or F abbreviation
float temp; //Raw temp value
float settemp; //Desired temp
int defF = 65; //Default Far.
int defC = 19; //Default Cel.
int upstate = 0; //Temp up button state
int downstate = 0; //Temp down button state
int tcfstate = 0; //C to F button state
int ledPin = 13; //LED's pin
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // lcd is at 12,11,5,4,3,2 on the breadboard
Serial.begin (9600); // set the serial monitor tx and rx speed
lcd.begin(16, 2); // set up all the "blocks" on the display
lcd.setCursor(0, 0); // set the cursor to colum 0 row 0
lcd.print("hello, world!"); // display hello world for 1 second
lcd.clear(); // clear the lcd
pinMode(tup, INPUT); //Set temp up button to input
pinMode(tdown, INPUT); //Set temp down button to input
pinMode(tcf, INPUT); //Set C to F button to input
pinMode(ledPin, OUTPUT); //Set LED to output
upstate = digitalRead(tup); //Read state of temp up
downstate = digitalRead(tdown); //Read state of temp down
tcfstate = digitalRead(tcf); //Read state of C to F button
int tvalue = analogRead(tempPin); // make tvalue what ever we read on the tempPin
if (tcfstate == LOW) { //If the C to F button is pressed
if (far == true) { //And Farenheit is true already
far = false;
cel = true; //Enable Celsius
else if (far == false) { //Otherwise if Farenheit isn't true
far = true; //Enable Farenheit
cel = false;
if (far == true) { //If Farenheit is true
temp = farenheit(tvalue); //Caclulate temp in F
abbrv = 'F'; //Set label to F
if (cel == true) { //If Celsius is true
temp = celsius(tvalue); //Calculate temp in C
abbrv = 'C'; //Set label to C
if (upstate == LOW) { //if up button is pressed,
defF = defF + 1; //raise desired F by 1
defC = defC + 1; //Raise desired C by 1
if (downstate == LOW) { //if down button is pressed
defF = defF - 1; //lower desired F by 1
defC = defC - 1; //lower desired C by 1
lcd.print("Current ");
lcd.print (temp); // Print the current temp in f
lcd.print (abbrv);
delay(255);
if (cel == true) {
lcd.setCursor (0, 1); // set the cursor to 0,1
lcd.print ("Desired "); // Print set to and your ideal temperature in f
lcd.print (defC);
lcd.print (abbrv);
if (far == true) {
lcd.print (defF);
lcd.print (abbrv);
lightUp(temp, defC, defF); //run custom light up command
if (lightMe == true) { //if light up is true
digitalWrite(ledPin, HIGH); //turn on LED
} else if (lightMe == false) { //otherwise
digitalWrite(ledPin, LOW); //turn off LED
} // we're done
float farenheit(float raw) { //calculate far value
float f; //create temporary variable F
f = raw / 2.07; //calculate temperature from raw value
return f; //return temperature
float celsius(float raw) { //calculate cel value
float c; //create temp variable C
c = raw / 7.1; //calculate temperature from raw value
return c; //return temperature
boolean lightUp(float act, int desC, int desF) { //Decides if LED should light up, imports current temp, desired C, and desired F
if (act < desC || act < desF) { //if the actual is less than the desired F or C value
lightMe = true; //Turn on the LED
} else { //otherwise
lightMe = false; //Turn the LED off
return lightMe; //return that value
