Thermostat project
Good evening,
I am interested in building a home thermostat to control my conventional HVAC system. I wrote up some very brief plans below. My question is electronic, can you use transistors to bridge the 24VAC to appropriate lines, or will relays need to be used? I have many transistors and few relays on hand. My will to build this stems from an autistic child that will mess with a conventional panel and wish to have more control - even remote control (via a simple WWW server possibly).
components
 RTC – Real Time Clock Module
 WiFi card - ESP 8266
 16x2 LCD Display
 Capacitive touch board
 Temp / Humidity Sensor
 Four LEDs: Red, Orange, Yellow, Blue
 HVAC Interface
 24VAC Operation! Is it possible to avoid use of relays?
 Red – 24VAC
 Yellow – Cooling
 White – Heat
 Green - Fan
 Display
 LEDs
 Red: System Fault / Unlocked (slow flashing)
 Orange: Heating / Heating Standby (slow flashing).
 Yellow: Fan on. / Fan with H/C (slow flashing). / Fan Only (fast flashing).
 Blue: Cooling / Cooling Standby (slow flashing).
 Default Display
 TIME Set / Amb.
 22:30 70 / 72
 Menu Display
 * Schedule >
 Lock Settings >
 Function
 Unlocking
 Simultaneously touch both unlock areas.
 This is to prevent misuse by kids.
 The red LED flashes
 screen says “unlocked”.
 Menu
 Schedule
• Set time blocks
 Lock Settings
• Unlocked period
• Lock active / inactive
 Time Settings
• Set time
• Set timeout for fan mode changes
• Set timeout for temp setting changes
 Hysteresis
• Cool at x degrees above
• Heat at y degrees below
 Fan Modes
 On all time
 On with H/C (default)
 On with no H/C
 Buttons
 Capacitive Touch
 Unlock / Fan Mode
• In menu moves back
 Unlock / On/Off
• In menu moves forward
 Menu
 Up
 Down
Start simple and get familiar with all those components first, before you start to attach to and manipulate your HVAC.
I cannot answer your electronic questions due to the lack of a circuit diagram and/or data sheets. Dunno how 24V AC is related to your project.
The short answer is that normal transistors cannot switch AC. There is a type of transistor called a triac which can do this, but you don't often see them used in Arduino projects. Relays may be the simpler answer for you.
SSRs are triacs with opto couplers for electric insulation. Unlike relays they only can switch AC, not DC.
You may not need the RTC. With the ESP chip, you can easily get the time from a Network Time Server, at startup and then once per day. The ESP's internal clock can keep time accurately enough over a day.
PaulRB:
Thanks, that saves a few bucks.
