Hi there !
I have a scoui while trying to make a thermostat. The relay does not start despite the order sent to the pine. I have to add a button attached to Digital Pin 16 to work.
When I stand the button my ESP8266 restarts.
I can see in the serial that everything works on the side of the code.
Can anyone help me solve this problem?
Thanks
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
BlynkTimer timer;
WidgetTerminal terminal(V100);
char auth[] = "xx";
char ssid[] = "xx";
char pass[] = "xx";
WidgetLED ledV1(V2);
WidgetLED ledV2(V3);
int relaisOn = 16; //relaisD0 - On/Off
int relaisV = 5; //relaisD1 - Vitesse 1/2
int hysteresis = 2;
int TempSom;
float Thermostat = 0;
BLYNK_WRITE(V1) {
TempSom = param.asInt();
BLYNK_WRITE(V4) {
Thermostat = param.asFloat();
Blynk.begin(auth, ssid, pass, IPAddress(10, 3, 141, 1), 8080);
timer.setInterval(1000L, relaisAlim);
//BLYNK TERMINAL
terminal.clear();
terminal.print("Controleur Extracteur Allumé");
terminal.println("---------------------------");
terminal.flush();
Blynk.run();
timer.run();
void relaisAlim() //boucle temperature//relais 1
Serial.print("Temperature : ");
Serial.print(TempSom);
Serial.println("°C");
Serial.print("Thermostat : ");
Serial.println(Thermostat);
if (TempSom >= (Thermostat + hysteresis))
digitalWrite(relaisOn, HIGH);
Blynk.virtualWrite(V2, 255);
Serial.println("relais allumé ");
else if (TempSom <= (Thermostat - hysteresis))
digitalWrite(relaisOn, LOW);
Blynk.virtualWrite(V2, 0);
Serial.println("relais eteind ");
