I have connected moisture sensor to MKR WIFI 1010. It works perfectly. I see moisture reading in Serial monitor (high or low).
I have created on Arduino IOT CLoud a thing (the moisture sensor), with the appropriatte property (using
the variable "estadoDeHumedad" defined in the sketch for reading the sensor status) and associated to the MKR WIFI 1010 device.
I attach the sketch loaded in the device.
When I run the sketch and I see Thing, device and dashboard in Arduino Create IoT Cloud, I see the device connected to cloud but the sensor status is not received to the dashboard.
Sketch generated by the Arduino IoT Cloud Thing HUMEDAD.doc (25.5 KB)
