Third Learning Exercice Help!
Hi!
I decided to learn Arduino. First, I did the LED exercise. Second, I wire up a photocell according to that tutorial How to use photocells, LDRs, CdS cells, photoresistors! and I used that code:
/* Photocell simple testing sketch.
Connect one end of the photocell to 5V, the other end to Analog 0.
Then connect one end of a 10K resistor from Analog 0 to ground
For more information see www.ladyada.net/learn/sensors/cds.html */
int photocellPin = 0;     // the cell and 10K pulldown are connected to a0
int photocellReading;     // the analog reading from the analog resistor divider
void setup(void) {
  // We'll send debugging information via the Serial monitor
void loop(void) {
  photocellReading = analogRead(photocellPin);
  Serial.print("Analog reading = ");
  Serial.print(photocellReading);     // the raw analog reading
  // We'll have a few threshholds, qualitatively determined
  if (photocellReading < 10) {
    Serial.println(" - Dark");
  } else if (photocellReading < 200) {
    Serial.println(" - Dim");
  } else if (photocellReading < 500) {
    Serial.println(" - Light");
  } else if (photocellReading < 800) {
    Serial.println(" - Bright");
    Serial.println(" - Very bright");
Now for my third exercise, I’d like to wire up 6 photocells but I really don’t understand how to write the code for 6. How does it works, what should I do to add 6 photocells to the code?
Thanks!
Micheline
  1. Create a function
    http://www.arduino.cc/en/Reference/FunctionDeclaration
Make it have the pin number as an argument.
  1. Call the function using values from an array
    http://arduino.cc/en/Reference/Array
[edit]This is what it could look like:
For more information see How to use photocells, LDRs, CdS cells, photoresistors! */
const byte NUMBER_OF_PHOTOCELLS = 5;
byte photocellPins[NUMBER_OF_PHOTOCELLS] = {0,1,2,3,4}; // the cell and 10K pulldown are connected to a0
int photocellReadings[NUMBER_OF_PHOTOCELLS] = {0}; // the analog reading from the analog resistor divider
void setup(void) {
// We’ll send debugging information via the Serial monitor
void loop(void){
for (byte currentIndex=0; currentIndex<NUMBER_OF_PHOTOCELLS; currentIndex++){
readPhotocell(currentIndex);
void readPhotocell(byte index) {
photocellReadings[index] = analogRead(photocellPins[index]);
Serial.print(photocellReadings[index]); // the raw analog reading
// We’ll have a few threshholds, qualitatively determined
if (photocellReadings[index] < 10) {
} else if (photocellReadings[index] < 200) {
} else if (photocellReadings[index] < 500) {
} else if (photocellReadings[index] < 800) {
[/edit]
Oh! Thanks a lot AlphaBeta! I really appreciated it! ... but I'm a bit discouraged, it looks so hard ...
Using functions actually makes things much easier. You only have to write the code once, and you can use it in a variety of ways. For instance, I have a Buzz(int freq, int length) function - you pass it the frequency and the length, and it buzzes as you specify. So you can just call the function a bunch of times, instead of writing out those 10+ lines of code each time you want to buzz.
If you're worried about the programming aspects, look up some tutorials on coding in C/C++ - it's essentially the same for Arduino.
