This annoying AVR-Dude works on Mega but not on Uno, Nano, Leonardo - OSX 10.14
Another annoying AVR Dude here.
I always get these avrdude - programmer is not responding. I have read 100 forum entries about the problem. Here is my very own variant.
I have an Arduino Mega 2560 and several others working on a Mac with OSX 10.14.6 with the IDE 1.8.10 with a TeensyDuino Extension 1.48 that also works great. (Yes I also have some Teensies that work fine.)
I can perfectly transfer my programs to my Mega 2560. Everything works great, except ...
Then I have 2 very new Arduino Unos, right out of the box. Nothing attached. Nothing uploaded.
When I attach them to my Mac they are recognized on the USB. I can select them by name in the IDE "/dev/cu.usbmodem1401 (Arduino/Genuino Uno)" and of course I select the proper board in the IDE.
So apparently the cable works, the USB is somehow recognized correctly, the Mega 2560 works. Nevertheless, this annoying AVR Dude always prevents me from uploading the simple blink sketch that wonderfully works on the Mega 2560.
Same problem with an elder Nano and a Leonardo. I simply get no program onto the devices. They usually compile. They say that they need 7% of memory or whatever, but then this AVR Dude comes and annoys me.
I've also tried to load a new USB-Driver (http://www.ftdichip.com/Drivers/VCP.htm), and I have also tried to use elder IDEs (1.6.5-r5 and 1.8.12)
Currently, I'm back to the recent IDE 1.8.10
Here is the verbose output for the Uno:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/oliver/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem4101
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 258864443
         Firmware Version: -531304368.32766
         Topcard         : STK502
         Vtarget         : 3272.5 V
         Varef           : 3.2 V
         Oscillator      : 921.600 kHz
         SCK period      : 35553.4 us
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
I even tried to upload via ISP. Then the error message is somehow differen 'not in sync' but the effect is the same. No upload possible.
Any help is very welcome.
Please post the full output from uploading to the Nano and the Leonardo as well. Use the Arduino IDE's "Copy error messages" button to copy the error, since that will provide us with a little bit of extra information that might be useful.
Coming soon.
The Unos by the way work on a Windows7 PC of a friend of mine.
The error-message from the UNO:
Arduino: 1.8.10 (Mac OS X), TD: 1.48, Board: "Arduino/Genuino Uno"
Der Sketch verwendet 4572 Bytes (14%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 231 Bytes (11%) des dynamischen Speichers, 1817 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem4101 -b115200 -D -Uflash:w:/var/folders/yp/8bm4t9yn0hn6grrk2vpyd0g80000gp/T/arduino_build_725826/BatteryCharger_00.ino.hex:i
        PAGEL                         : PD7
        BS2                           : PC2
        RETRY pulse                   : SCK
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
        Topcard         : STK502
        Vtarget         : 3272.5 V
        Varef           : 3.2 V
        this check.
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
The error-message from the Nano.
It gets stuck before the AVR Dude even gets into action.
Appears in the IDEs USB-selection as: "/dev/cu.usbserial-620"
Arduino: 1.8.10 (Mac OS X), TD: 1.48, Board: "Arduino Nano, ATmega328P"
Der Sketch verwendet 4572 Bytes (14%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-620 -b115200 -D -Uflash:w:/var/folders/yp/8bm4t9yn0hn6grrk2vpyd0g80000gp/T/arduino_build_725826/BatteryCharger_00.ino.hex:i
Beim Hochladen des Sketches ist ein Fehler aufgetreten
         Using Port                    : /dev/cu.usbserial-620
The error-message from the Leonardo:
it appears in the IDEs USB-selection as: "/dev/cu.usbmodem6201 (Arduino Leonardo)"
Arduino: 1.8.10 (Mac OS X), TD: 1.48, Board: "Arduino Leonardo"
Der Sketch verwendet 6832 Bytes (23%) des Programmspeicherplatzes. Das Maximum sind 28672 Bytes.
Globale Variablen verwenden 194 Bytes (7%) des dynamischen Speichers, 2366 Bytes für lokale Variablen verbleiben. Das Maximum sind 2560 Bytes.
Erzwinge Reset durch öffnen/schließen mit 1200 bps auf dem Port /dev/cu.usbmodem6201
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem6201, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem6201, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.usbmodem6201, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.usbmodem6201, } => {}
Uploading using selected port: /dev/cu.usbmodem6201
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem6201 -b57600 -D -Uflash:w:/var/folders/yp/8bm4t9yn0hn6grrk2vpyd0g80000gp/T/arduino_build_725826/BatteryCharger_00.ino.hex:i
         Using Port                    : /dev/cu.usbmodem6201
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = ?
    Software Version = 1.0; No Hardware Version given.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
         this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
Der ausgewählte serielle Port
 ist nicht vorhanden oder das Board ist nicht angeschlossen
