This application was configured to use a bundled Java Runtime Environment
Hi
i am getting this message :
Arduino
This application was configured to use a bundled Java Runtime Environment but the runtime is missing or corrupted.
Thanks & Regards
bahattab:
Thanks,
i found the solution :
i just put the installation file (arduino-1.x.x-windows.exe) in the c:\ root, and it works
also for the folder (Arduino-1.x.x) it will work if you locate it in the c:\ root.
Thanks & Regards
I also have that problem on PC that I recently bought.
Somehow, I open the same app downloaded via zip file on my old laptop which also has windows 10 and it works fine without mistakes and messages. I have both versions 1.6.5-r5 and 1.8.4 on my laptop and both working well.
Is it possible mistake that zip app does not work properly?
What are requirements? Should it be x32 or x64 or does not matter at all?
Please help me to solve the problem of Arduino, which is : This application was configured to use a bundled Java Runtime Environment but the runtime is missing or corrupted.
Please try to answer ASAP.
Best Regars!
