This code is unable to verify
type or paste code#include "thingProperties.h"
#include <Servo.h>
Servo myservo;
int pos = 0;
String password = "Eduvate@123";
String msg1 = "Please Enter the password";
String msg2 = "Please Enter the password again";
  myservo.attach(15);
  status = false;
  myservo.write(0);
  messenger = msg1;
  delay(1500);
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  if (messenger == password) {
    status = true;
    myservo.write(90);
  else {
    messenger = msg2;
    status = false;
    myservo.write(0);
} here
these are the codes and error showing is
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:esp32doit-devkit1:DebugLevel=none,EraseFlash=none,FlashFreq=80,UploadSpeed=921600 --build-cache-path /tmp --output-dir /tmp/1905636055/build --build-path /tmp/arduino-build-5B15740DBB43943E43497556A5939BF8 /tmp/1905636055/Smart_Lock_apr13a
/home/builder/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /tmp/arduino-build-5B15740DBB43943E43497556A5939BF8/sketch/objs.a(Smart_Lock_apr13a.ino.cpp.o):(.literal._Z14initPropertiesv+0x18): undefined reference to `onMessengerChange()'
collect2: error: ld returned 1 exit status
Multiple libraries were found for "WiFiClientSecure.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFiClientSecure
Not used: /home/builder/opt/libraries/seeed_arduino_rpcwifi_1_0_7
Multiple libraries were found for "WiFi.h"
Not used: /home/builder/opt/libraries/wifiespat_1_4_3
Not used: /home/builder/opt/libraries/nina_wi_fi_1_0_1
Not used: /home/builder/opt/libraries/indhilib_3_0_5
Not used: /home/builder/opt/libraries/wifinina_1_8_14
Not used: /home/builder/opt/libraries/da16200_wi_fi_library_for_arduino_1_1_0
Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
Not used: /home/builder/opt/libraries/wifi_1_2_7
Multiple libraries were found for "Servo.h"
Used: /home/builder/opt/libraries/servoesp32fix_1_1_2
Not used: /home/builder/opt/libraries/evive_2_0_3
Not used: /home/builder/opt/libraries/servo_1_2_1
Not used: /home/builder/opt/libraries/servoesp32_1_1_1
Not used: /home/builder/opt/libraries/vovagorodok_servo_1_0_0
Not used: /home/builder/opt/libraries/rokitsmart_1_0_9
Not used: /home/builder/opt/libraries/printoo_library_1_0_2
Not used: /home/builder/opt/libraries/esp32_esp32s2_analogwrite_5_0_2
Not used: /home/builder/opt/libraries/xmc_servo_1_0_1
Not used: /home/builder/opt/libraries/microbitv2_hhs_0_1_6
Error during build: exit status 1
Hi @harshwakle123456789. When you configure the permissions of an Arduino Cloud Variable as "read & write", the generated Thing sketch code is written to call a function whenever the value of the Variable is changed via the Arduino Cloud dashboard.
The cause of this error is that you removed this "callback" function for the messenger Variable from the sketch code.
You can fix it by adding the missing function definition to your sketch:
void onMessengerChange()  {
  // Add your code here to act upon messenger change
If you don't have any use for this "callback" feature in your sketch, you can simply leave the function empty.
If you don't plan to change the value of the messenger Variable from the Arduino Cloud dashboard, then you can change the Variable permissions in the Thing configuration from "read & write" to "Read only".
