This code works with Arduino Uno, but not with MKR 1010 Wifi
Hello,
This is a sample code to extract a RFID tag with Arduino Uno. With Uno board works fine, but when I try to use the same code with Arduino MKR 1010 Wifi, doesn't run... :confused: can anyone help me to solve it, or have an explanation why that happens? Thanks a lot!!
Error message:
Arduino:1.8.8 (Windows 10), Tarjeta:"Arduino MKR WiFi 1010"
C:\Users\usuario\Desktop\Coloms_alfa\Coloms_alfa.ino: In function 'unsigned int extract_tag()':
Coloms_alfa:54:59: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'char*' [-fpermissive]
     long tag = hexstr_to_value(msg_data_tag, DATA_TAG_SIZE);
Coloms_alfa:64:6: error: initializing argument 1 of 'long int hexstr_to_value(char*, unsigned int)' [-fpermissive]
 long hexstr_to_value(char *str, unsigned int length) { // converts a hexadecimal value (encoded as ASCII string) to a numeric value
Coloms_alfa:59:43: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'char*' [-fpermissive]
       long val = hexstr_to_value(msg_data + i, CHECKSUM_SIZE);
C:\Users\usuario\Desktop\Coloms_alfa\Coloms_alfa.ino: In function 'long int hexstr_to_value(char*, unsigned int)':
Coloms_alfa:65:50: error: invalid conversion from 'void*' to 'char*' [-fpermissive]
   char* copy = malloc((sizeof(char) * length) + 1);
exit status 1
Code:
const int BUFFER_SIZE = 14; // RFID DATA FRAME FORMAT: 1byte head (value: 2), 10byte data (2byte version + 8byte tag), 2byte checksum, 1byte tail (value: 3)
const int DATA_SIZE = 10; // 10byte data (2byte version + 8byte tag)
const int DATA_TAG_SIZE = 8; // 8byte tag
const int CHECKSUM_SIZE = 2; // 2byte checksum
uint8_t buffer[BUFFER_SIZE]; // used to store an incoming data frame
int buffer_index = 0;
 Serial1.begin(9600);
 Serial.println("INIT DONE");
  if (Serial1.available() > 0){
    bool call_extract_tag = false;
    int ssvalue = Serial1.read(); // read
    if (ssvalue == -1) { // no data was read
      return;
    if (ssvalue == 2) { // RDM630/RDM6300 found a tag => tag incoming
      buffer_index = 0;
    } else if (ssvalue == 3) { // tag has been fully transmitted
      call_extract_tag = true; // extract tag at the end of the function call
    if (buffer_index >= BUFFER_SIZE) {
      Serial.println("Error: Buffer overflow detected!");
      return;
    buffer[buffer_index++] = ssvalue; // everything is alright => copy current value to buffer
    if (call_extract_tag == true) {
      if (buffer_index == BUFFER_SIZE) {
        unsigned tag = extract_tag();
      } else { // something is wrong... start again looking for preamble (value: 2)
        buffer_index = 0;
        return;
unsigned extract_tag() {
    uint8_t msg_head = buffer[0];
    uint8_t *msg_data = buffer + 1; // 10 byte => data contains 2byte version + 8byte tag
    uint8_t *msg_data_version = msg_data;
    uint8_t *msg_data_tag = msg_data + 2;
    uint8_t *msg_checksum = buffer + 11; // 2 byte
    uint8_t msg_tail = buffer[13];
    Serial.print("Extracted Tag: ");
    Serial.println(tag);
    long checksum = 0;
    for (int i = 0; i < DATA_SIZE; i+= CHECKSUM_SIZE) {
      checksum ^= val;
    return tag;
  memcpy(copy, str, sizeof(char) * length);
  copy[length] = '\0';
  // the variable "copy" is a copy of the parameter "str". "copy" has an additional '\0' element to make sure that "str" is null-terminated.
  long value = strtol(copy, NULL, 16);  // strtol converts a null-terminated string to a long value
  free(copy); // clean up
  return value;
use char not uint8_t for char arrays
Thanks for your help Juraj, but I replaced all variables and the error is located at following lines. In any case, I can't explain why is working on Uno and not over MKR 1010 :frowning:
Code line:
char* copy = malloc((sizeof(char) * CHECKSUM_SIZE) + 1);
Error:
At global scope:
81:1: error: expected declaration before '}' token
exit status 1
It seems like different board packages invoke the compiler with different setting with regard how picky they are about sloppy type conversions. Try casting the return value from 'malloc' as a 'char *'.
