This don't make sense I hook up 3 leds and use IR to read remote works good with
This don't make sense I hook up 3 leds and use IR to read remote works good with 2 buttons add 3 and it stops.
I Hooked up 3 leds code works fine as long as I'm using just 2 buttons or reading the remote buttons as soon as
I add over 3 the code stops.
Comment led3 out code works
int led1 = 8;
int led2 = 9;
int led3 = 7;
#include <IRLibAll.h>
IRrecv myReceiver(2);//receiver on pin 2
IRdecode myDecoder;//Decoder object
  pinMode (led1, OUTPUT);
  pinMode (led2, OUTPUT);
  pinMode (led3, OUTPUT);
  myReceiver.enableIRIn(); // Start the receiver
  if (myReceiver.getResults()) {
    myDecoder.decode();
    if (myDecoder.protocolNum == NEC) {
      switch(myDecoder.value) {
        case 0xFF50AF:  //Volume Down
        Serial.println(F("Volume Down"));
        digitalWrite(led1, !digitalRead(led1));
        case 0xFFA05F:  //Play/Pause
        Serial.println(F("CH UP"));
        digitalWrite(led2, !digitalRead(led2));
        case 0xFF7887:  //Volume Up
        Serial.println(F("Volume up"));
        //digitalWrite(led3, !digitalRead(led3)); comment this out code works
    myReceiver.enableIRIn(); //Restart the receiver
Uncomment led3 code doesn't run.
int led1 = 8;
int led2 = 9;
int led3 = 7;
    myDecoder.decode();
        digitalWrite(led3, !digitalRead(led3)); uncomment code doesn't run.
Pic shows it reading the 3 buttons.
Well I'm sorry I can't figure it out code was the same I added comments to post here and guess what.
I removed the led3 comment and got a error ' I back spaced all the way i guess there was a ' there somewhere and it didn't show till i added the comment. LOL
Well Im back the case statement is not working as should. It works sometimes good but then it hangs and don't change states
I think the line
should be outside the
clause.
If your receiver thinks it got something and it is not NEC, it will not be reenabled.
Whandall your right it was in the wrong loop.
I figured it out lol the problem is this
It's in the wrong loop lol dang this drove me nut's I read the whole pdf for IRLib2
At about the end I found it the dang thing works for maybe 5 minutes
Then quit's here the working code works great now
myReceiver.enableIRIn(); has to be (myReceiver.getResults()) { loop to keep it reading the remote or it stop's when
It feels like it
My dump truck code Fixed and working good. Thanks Whandall you was dead on it I moved it like 2 times but
wrong way lol.
What get's me is I started with code from Using an Infrared Library on Arduino they had it just like I did the code worked but i think it picks up noise and that shuts it down.
int enablePin = 5;
int in1Pin = 10;
int in2Pin = 11;
int enablePin1 = 6;
int in3Pin = 8;
int in4Pin = 9;
#include "IRLibDecodeBase.h"
#include "IRLibSendBase.h"
#include "IRLib_P01_NEC.h"
#include "IRLibCombo.h"
#include "IRLibRecv.h"
#include "IRLibRecvLoop.h"
#include "IRLibRecvPCI.h"
#include "IRLibFreq.h"
  pinMode(in1Pin, OUTPUT);
  pinMode(in2Pin, OUTPUT);
  pinMode(in3Pin, OUTPUT);
  pinMode(in4Pin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  pinMode(enablePin1, OUTPUT);
    if(myDecoder.decode()){
      switch (myDecoder.value) {
        case 0xFF50AF:  //up
          digitalWrite(in3Pin, LOW);
          digitalWrite(in4Pin, HIGH);
          digitalWrite(enablePin1, HIGH);
        case 0xFF7887:  //down
          digitalWrite(in3Pin, HIGH);
          digitalWrite(in4Pin, LOW);
       case 0xFFA05F:  //forward
        digitalWrite(in1Pin,LOW);
        digitalWrite(in2Pin, HIGH);
        digitalWrite(enablePin,HIGH);
       case 0xFF40BF:  //backward
        digitalWrite(in1Pin,HIGH);
        digitalWrite(in2Pin, LOW);
        case 0xFF02FD:  //backward
        digitalWrite(enablePin1, LOW);
        digitalWrite(enablePin,LOW);
