"" if (TestBulb = 49) {""
So I get in the habit of using < or >, but even so, every now and then you will just use = and get stung.
How can I alter the compiler to not allow = by itself in the if statement?
(deleted)
Personally, I dislike it, but there is this way of doing the same thing that the compiler will catch for you:
if ( 49=TestBulb)
If you set File > Preferences > Compiler warnings to "All" or "More" then you get a warning from that code, which is a bit vague, but would likely cause you to see the problem:
ifbug:4:14: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
if (TestBulb = 49) {}
I recommend always having your compiler warnings set to "More" and always paying attention to them. Unfortunately, sometimes that can be difficult when you're working with libraries or cores that generate a lot of warnings, which may make it difficult to notice the warnings in your own code. To take it a step further, you could upgrade the "suggest parentheses around assignment used as truth value" warning to an error using -Werror=parentheses. The way to accomplish this is to create a file named platform.local.txt in the same folder as the platform.txt file of each of the hardware packages you have installed that contains these lines:
compiler.c.extra_flags=-Werror=parentheses
compiler.cpp.extra_flags=-Werror=parentheses
Now that code will cause a compiler error:
ifbug:4:14: error: suggest parentheses around assignment used as truth value [-Werror=parentheses]
cc1plus.exe: some warnings being treated as errors
You will need to replace that file every time you update to a new version of any of those hardware packages.
If you need help locating the correct folders for your platform.local.txt, let me know.
I noticed earlier that you had another Thread aimed at Newbies.
IMHO it would be easier for Newbies to access your advices if you put them all in a single Thread.
...R
I will try that, thanks guys. As for the newbie thing, I'm just trying to save the some grief. put them all in one thread, well i can try i guess.
It does indeed give a warning, and I did have it set to all. And yes, it was buried in pragma warnings about bit banging. I googled pragma. Learned enough to not bother. So thanks again.
You might want to read through Arduino programming traps, tips and style guide.
that is a good tip sheet. on RAM availability tho, i just watch the numbers that the compiler issues and in some programs will easily have 4k of array and it seems to work, however that tip sheet says i have only 2k. How am i getting away with it?
Very simply, you're not.
sevenoutpinball:
Reference, please.
So anyway when the compiler burries messages under all this, they can be easy to miss. This is obviously only part of what it generates. I just have to be more careful and review all this stuff.
In file included from /Users/testlib/Documents/Arduino/TestWiFiGusher7/TestWiFiGusher7.ino:54:0:
/Users/testlib/Documents/Arduino/libraries/FastLED-master/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.006
In file included from /Users/testlib/Documents/Arduino/libraries/FastLED-master/FastLED.h:65:0,
/Users/testlib/Documents/Arduino/libraries/FastLED-master/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
Compiling libraries...
Compiling library "NTPClient"
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/NTPClient/NTPClient.cpp.o
Compiling library "ESP8266WiFi"
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFi.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiServer.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiUdp.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiClient.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/CertStoreBearSSL.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/BearSSLHelpers.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/ESP8266WiFi/ESP8266WiFi.a
Compiling library "FastLED-master"
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/FastLED.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/hsv2rgb.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/noise.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/wiring.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/bitswap.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/lib8tion.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/power_mgt.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/colorpalettes.cpp.o
Using previously compiled file: /var/folders/4b/sjd5y8t54zxdzx1q5vrk8lwm0000gn/T/arduino_build_688936/libraries/FastLED-master/colorutils.cpp.o
Compiling core...
