this is what im getting everytime i try to upload the code to my arduino uno
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 14898 bytes (46%) of program storage space. Maximum is 32256 bytes.
Global variables use 1846 bytes (90%) of dynamic memory, leaving 202 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Check windows device manager which port shows after connecting the device. That's the port to select in the IDE.
Do not connect anything to pins 0 and 1 while uploading.
If no port shows in device manager but an unknown device shows, you probably have a clone with the CH349 usb-to-ttl adapter chip and you need to install the driver.
