The sketch run the motor wired to L293d shield, doesn't run for 'forward' where the motor wired to pin18-21, why?
Thanks
Adam
////////////////////////////////// MDF FROM : [gps_robot_car_M1_waypoint] at: LINE 63 and 174 of 'CONFIG.h'
int LeftMotorForward = 18; // IN1 to the driver WAS 10 reverse the moving direction:
int LeftMotorBackward = 19; // IN2 to the driver WAS 11
int RightMotorForward = 20; // WAS 5 IN3 to the driver WAS 12
int RightMotorBackward = 21 ; // WAS 6 IN4 to the driver WAS 13
const int ENABLE_A = 8; /////WAS 6 mdfd 3 may conflict to NewPing
const int ENABLE_B = 9; /////WAS 8
#define BUZZER_PIN 15 // WAS 7Output pin for the buzzer
int speedAH=200;
int speedBH=200;
int speedAL=100;
int speedBL=100;
int LED =15;
#include <AFMotor.h>//made by hirusha nirmal
AF_DCMotor R2(1);
AF_DCMotor R1(2);
AF_DCMotor L2(3);
AF_DCMotor L1 (4);
char bt='s';
Serial3.begin(9600);
R1.setSpeed(255);
R2.setSpeed(255);
L1.setSpeed(255);
L2.setSpeed(255);
// Initialize control pins for the motor driver
pinMode (LeftMotorForward, OUTPUT);
pinMode (LeftMotorBackward, OUTPUT);
pinMode (RightMotorForward, OUTPUT);
pinMode (RightMotorBackward, OUTPUT);
pinMode(LED, OUTPUT);
Stop();
bt=Serial3.read();
if (bt=='F')
forward();
if (bt=='B')
backward();
if (bt=='R')
right();
if (bt=='L')
left();
if (bt=='S')
Stop();
void forward()
R1.run(FORWARD);
R2.run(FORWARD);
L1.run(FORWARD);
L2.run(FORWARD);
////////////////////////////////// MDF FROM : [gps_robot_car_M1_waypoint] at: LINE 368 'void Forward(unsigned char vel)'
digitalWrite (RightMotorForward, HIGH);
digitalWrite (RightMotorBackward, LOW);
digitalWrite (LeftMotorForward, HIGH);
digitalWrite (LeftMotorBackward, LOW);
void backward()
R1.run(BACKWARD);
R2.run(BACKWARD);
L1.run(BACKWARD);
L2.run(BACKWARD);
void right()
R1.run(BACKWARD);
R2.run(BACKWARD);
L1.run(FORWARD);
L2.run(FORWARD);
void left()
R1.run(FORWARD);
R2.run(FORWARD);
L1.run(BACKWARD);
L2.run(BACKWARD);
void Stop()
R1.run(RELEASE);
R2.run(RELEASE);
L1.run(RELEASE);
L2.run(RELEASE);
}//made by hirusha nirmall
