This sketch causes the Web Editor to crash (is it my fault or a bug?)
I don't know why this R&D sketch I made from example code causes the Web Editor to crash but it does. The sketch has two files. This is the main file:
#include <SPI.h>
#include <MPU6050.h>
#include <Wire.h>
#include <U8g2lib.h>
#include "lib_test.c"
MPU6050 mpu;
int16_t ax, ay, az, gx, gy, gz;
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
const int buttonPin = 4;
int counter = 0;
int buttonState;
int lastButtonState = LOW;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
  pinMode(buttonPin, INPUT);
  u8g2.begin();
  mpu.initialize();
  if (!mpu.testConnection()) {
    while (1);
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != buttonState) {
      buttonState = reading;
      if (buttonState == LOW && counter >= 0 && counter < 10) {
        counter++;
      else if (buttonState == LOW && counter >= 2) {
        counter = 0;
  lastButtonState = reading;
  switch (counter) {
    case 1:
      printInt(10, 10, counter);
    case 2:
      printInt(10, 10, ax);
    default:
      printInt(10, 10, 0);
This is the second file, which contains the printInt() function:
void printInt(int _cursorX, int _cursorY, int _varToPass) {
  u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_t0_11_tf);
  u8g2.setCursor(_cursorX, _cursorY);
  u8g2.print(_varToPass);
  u8g2.sendBuffer();
The crash happened upon creation of the function file and seems to be caused by the #include up top. Except that it doesn't work if I remove it.
Is this a problem with me or the Web IDE?
EDIT - The name of the second file is "lib_test.c".
Just rename lib_test.c "lib_test.ino" and remove the #include from the first file. It will all compile together just fine. You don't need the #include in the new lib_test.ino file either
It worked. Thanks!
