This was not declared in this scope
I have spent tens of hour trying to solve this problem. here is the code
```Preformatted textPreformatted textPreformatted text`// Tutorial 6a. Colour finder w. ams TCS34725 and HD-1900A
// Main parts: Adafruit Metro Mini, Adafruit TCS34725 sensor breakout-
// board, Pololu HD-1900A servo, ultra-matt black sensor shroud
// Libraries required to use the I2C communication protocol, drive the
// servo and interface with the sensor; use the latest version
#include <Wire.h>
#include "Servo.h"
#include "Adafruit_TCS34725.h"
// Variables that remain constant
const byte interruptPin = 2; // Signal input pin from TCS34725 interrupt
// Two-dimensional array containing averaged RGB values from "colour
// training"; matching servo rotation angles for the 10° colour wheel
// segments. No particular order or sorting of samples is necessary
const int SAMPLES[][4] = {
{2062, 1469, 861, 665},
{1735, 758, 502, 755},
{1148, 440, 415, 850},
{1226, 478, 520, 950},
{ 907, 580, 620, 1050},
{1837, 1529, 1437, 1155},
{ 825, 821, 971, 1265},
{ 452, 404, 397, 1370},
{ 888, 1192, 1220, 1475},
{ 477, 614, 655, 1585},
{ 537, 640, 464, 1685},
{1241, 1326, 785, 1790},
{1390, 1204, 648, 1890},
{1402, 973, 567, 1990},
// Determines the number of samples stored in the array
const byte samplesCount = sizeof(SAMPLES) / sizeof(SAMPLES[0]);
// Instances a Servo object from the library and sets the sensing duration
// (integration time) and sensitivity (gain); see library options. Longer
// integration time plus lower gain = higher accuracy
Adafruit_TCS34725 SENSOR = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X);
Servo SERVOHD1900A;
// Variables that can change
unsigned long timeNow = 0; // Timestamp that updates each loop() iteration
const byte timeInterval = 5; // Time to pass until the next servo rotation
int angleCurrent; // Angle in microseconds = finer rotation resolution
int angleTarget; // Angle in microseconds = finer rotation resolution
uint16_t redSensor, greenSensor, blueSensor, clearSensor; // Raw readings
volatile boolean state = false; // Flag to toggle interrupt on and off
// For the compiler: isr() = function called when an interrupt occurs
void isr()
state = true;
// TCS34725 interrupt output is active-LOW and open-drain
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), isr, FALLING);
// Initialises the sensor; the LED is on, but could be switched via pin
// A0 programmatically, or via connection to GND (LED off)
SENSOR.begin();
// Set persistence filter = generates an interrupt for every cycle,
// regardless of the integration time limits
SENSOR.write8(TCS34725_PERS, TCS34725_PERS_NONE);
// Activate the sensor's interrupt function
SENSOR.setInterrupt(true);
// Uncomment for "colour training" and checking purposes
//Serial.begin(19200);
// Initialises the servo; connect its signal wire to pin 3
SERVOHD1900A.attach(3);
// Rotates the servo to initial position (angle 0° in microseconds)
SERVOHD1900A.writeMicroseconds(600);
// Seed both with an initial value to start with something. All samples
// are related to an angle expressed in microseconds, stored in the
// array. At the start, the current angle must be lower than the target
// angle = the servo starts from the 0° position
angleCurrent = 0;
angleTarget = 600;
// A call to this function reads from the TCS34725 sensor. Unlike reading
// from the sensor in the basic way, listening to the sensor's external
// interrupt, the long integration time of 700ms - necessary to obtain
// more accurate colour readings - does no longer block loop() from
// executing other code
readSensor();
// A call to this function iterates through the array to retrieve a
// matching colour sample
identifySample();
// A call to this function rotates the servo based on the angle in
// microseconds, also retrieved from the array
rotateServo();
void readSensor()
if (state)
// A call to this function reads the RGB values into the matching
// variables (& points to the memory address of a variable). The clear
// value is not needed, but must be read as per the library code
getRawData_noDelay(&redSensor, &greenSensor, &blueSensor, &clearSensor);
// Uncomment for initial "colour training"
/*Serial.print("R: "); Serial.print(redSensor, DEC); Serial.print(" ");
  Serial.print("G: "); Serial.print(greenSensor, DEC); Serial.print(" ");
  Serial.print("B: "); Serial.print(blueSensor, DEC); Serial.print(" ");
  Serial.print("C: "); Serial.print(clearSensor, DEC); Serial.print(" ");
  Serial.println(" ");*/
// Dectivate the sensor's interrupt function after taking a reading
SENSOR.clearInterrupt();
state = false;
void identifySample()
int colourDistance;
// Iterate through the array to find a matching colour sample
for (byte i = 0; i < samplesCount; i++)
colourDistance = getColourDistance(redSensor, greenSensor, blueSensor, SAMPLES[i][0], SAMPLES[i][1], SAMPLES[i][2]);
// The more constant the illumination conditions during "colour training"
// and when using the sensor, the lower the colour distance comparator
// can be chosen, and even more different colours can be reliably
// identified; hence the need for an ultra-matt black sensor shroud
if (colourDistance < 50)
// Retrieve a matching angle value (in microseconds) from the array
angleTarget = SAMPLES[i][3] + 150;
// Uncomment after "colour training", also to check if the colour
// distance is as low as possible
/Serial.print("Distance: "); Serial.println(colourDistance);
Serial.print("Sample no.: "); Serial.println(++i);
void rotateServo()
// Check if it is time to rotate the servo another step towards the
// target angle retrieved from the array. Depending on timeInterval,
// the servo can be slowed down from its regular speed
if (millis() - timeNow >= timeInterval)
// Create a new timestamp for the next step = loop() execution
timeNow = millis();
// Don't write to the servo after the target angle was reached
if (angleCurrent != angleTarget)
if (angleCurrent <= angleTarget)
angleCurrent += 5;
SERVOHD1900A.writeMicroseconds(angleCurrent);
if (angleCurrent >= angleTarget)
angleCurrent -= 5;
void getRawData_noDelay(uint16_t *redSensor, uint16_t *greenSensor, uint16_t *blueSensor, uint16_t clearSensor)
// getRawData() would cause a delay of the duration of the selected
// integration time, thus blocking loop() like a delay() in the code;
// but using the ISR (= interrupt) method, there is no more delay,
// because one receives an interrupt once the integration is done and
// loop() is no longer waiting for the sensor (
creates a pointer to
// the memory address of a variable)
*clearSensor = SENSOR.read16(TCS34725_CDATAL);
*redSensor = SENSOR.read16(TCS34725_RDATAL);
*greenSensor = SENSOR.read16(TCS34725_GDATAL);
*blueSensor = SENSOR.read16(TCS34725_BDATAL);
int getColourDistance(int redSensor, int greenSensor, int blueSensor, int redSample, int greenSample, int blueSample)
// Calculates the Euclidean distance between two RGB colours
// Color difference - Wikipedia
return sqrt(pow(redSensor - redSample, 2) + pow(greenSensor - greenSample, 2) + pow(blueSensor - blueSample, 2));
This is the fist time i am posting on the forum and I hope i am doing it properly, Thanks, Art
"Not declared in this Scope"
It's a pity you couldn't have spent a few minutes reading about how to use the forum
Please post the exact error message, do not paraphrase.
Please remember to use code tags when posting code
Adafruit_TCS34725 SENSOR = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X); This is the error message. Sorry what is a tag.
Correction: That is what gave the error message.
'TCS34725_INTEGRATIONTIME_700MS' was not declared in this scope
Hi @artman12us. Welcome to the forum!
We shall try to help you!
TCS34725_INTEGRATIONTIME_700MS is referenced here:
but it is not defined in your code. So, looking in the library file we find many similar definitions including these:
#define TCS34725_INTEGRATIONTIME_540MS                                         \
  (0x1F) /**< 540.0ms - 225 cycles - Max Count: 65535 */
#define TCS34725_INTEGRATIONTIME_600MS                                         \
  (0x06) /**< 600.0ms - 250 cycles - Max Count: 65535 */
#define TCS34725_INTEGRATIONTIME_614MS                                         \
  (0x00) /**< 614.4ms - 256 cycles - Max Count: 65535 */
BUT not your TCS34725_INTEGRATIONTIME_700MS !!!
so I think this is an error in your tutorial or in the library.
I suggest you modify your code to ...614MS and try to compile again.
BTW - if you use ``` before and after a block of code it will highlight it on forums like this
Great that got me past there almost to the end then I got this error "'SENSOR' was not declared in this scope" Thanks
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
The error message showed you where the error is, but you chose not to share that important item of information.
Why would you do that?
Can we expect those code tags any time soon?
Are you the Administrator of this Forum?
No - why do you ask?
Without code tags the code usually gets formatted incorrectly because certain character sequences are misinterpreted by the forum software. This means we can't copy the code and compile it ourselves if necessary, or even read the code easily.
