#include <Servo.h>
Servo myservo;
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
int pos = 0;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
// declare LED as output
pinMode(inputPin, INPUT); // declare pushbutton as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
for(pos = 0; pos < 180; pos += 8) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
} // turn LED OFF
for(pos = 180; pos>=1; pos-=8) // goes from 180 degrees to 0 degrees
its a function for my auto dog feeder
