So I'm making a new LED matrix board for the newest version of a synth/sequencer I've been working on for a while.
I designed one a couple years ago in Eagle that I got fabbed by batchPCB. It was okay, there were some silly design errors and general newbie layout and design (all auto-routed).
I re-made the schematic, making sure there were no errors, and making some little improvements here and there, and just for the heck of it, I decided I'll hand-wire it this time...
Here's the schematic. The 5 shift registers that control the display are all daisy-chained, so only 3 wires (data, clock, latch) are needed to control the entire display.
a schematic by beefinator, on Flickr
And here's the board I designed. Yes, I used Eagle again, but this time it was all manually laid out and routed.
I designed it so that I could wire up everything on the back of the board with uninsulated solid wire; the red traces in the design would be higher above the board than the blue traces, or vice versa.
circuit layout by beefinator, on Flickr
The 6-pin header (ICSP pinout, just an arbitrary choice to have a uniform system to connect the individual boards within the synth's enclosure) and the caps are not laid out and connected yet, but that's trivial. E.g. the 0.1uf caps cam probably just be soldered wherever they fit on the back of the board across the Vcc and Gnd pins of the 595's.
I imagine this board will look pretty cool when it's done...
[sarcasm]But this is certainly going to be fun wiring it all up...[/sarcasm]
