I have a tft display and I need to created an box that does not stop the rest of the code from running while it flashes.
I need the process to run when a digital pin goes high. ad run until that pin goes low. (Change States). I can get all of this to work except when I start the Flashing box my code stops until the flashing process is done.
The digital read is not in the following code yet because I am not using it yet. I am testing my code.
The timed action library gave me the same result as it not being there. The RightTurn and LeftTurn procedures do not run in the background. They stay in the foreground.
I am not sure how to set up background processes in arduino. most of my experience is with VB. Any help would be appreciated.
#include <TimedAction.h>
#include <Event.h>
TimedAction LeftTurnAction = TimedAction(50,LeftTurn);
TimedAction RightTurnAction= TimedAction(50, RightTurn);
int LCDRestart = 0 ;
int FIn = 8 ; //47ohm Resistor to +5vdc
int BIn = 9 ; //4.7K to Ground and 47K to 12V
int WIn = 10 ; //47ohm Resistor to +5vdc
int OIn = 11 ; //100ohm Resistor to +5vdc
int FVal = 0; float FValSnapshot = 0 ; float FuelLevel = 0 ; float FuelLevelSnapshot = 0 ;
int BVal = 0; float BVolts = 0 ; float BVoltsSnapshot = 0 ;
int WVal = 0 ; int WTemp = 0 ; float WTempSnapshot = 0 ;
int OVal = 0 ; int OilPressure = 0 ; float OilPressureSnapshot = 0 ;
int SensorReadLoop = 30; int LoopCount = 30 ;
#include <UTFT.h>
UTFT myGLCD(GEEE32,38,39,40,41);
extern uint8_t Inconsola[]; //24 x 32
extern uint8_t OCR_A_Extended_M[]; //16 x 24
void setup(){
myGLCD.InitLCD(LANDSCAPE);
myGLCD.clrScr();
myGLCD.setFont(OCR_A_Extended_M);
myGLCD.fillScr(VGA_BLUE) ;
myGLCD.setBackColor(VGA_BLUE);
myGLCD.setColor (VGA_YELLOW);//Red,Green,Blue
myGLCD.print("Oil Pressure",0,40);
myGLCD.print("Water Temperature",0,80);
myGLCD.print("Fuel Level",0,120);
myGLCD.print("Voltage",0,160);
void loop(){
myGLCD.setColor (VGA_YELLOW) ;
SensorReadings();
LeftTurnAction.check();
RightTurnAction.check();
void SensorReadings(){
if (SensorReadLoop <= LoopCount){
OilRead(); WaterRead(); FuelRead(); BatteryRead();
OilPressureSnapshot = OilPressureSnapshot + OilPressure;
WTempSnapshot = WTempSnapshot + WTemp;
FuelLevelSnapshot = FuelLevelSnapshot + FuelLevel;
BVoltsSnapshot = BVoltsSnapshot + BVolts;
SensorReadLoop = SensorReadLoop - 1;
myGLCD.print(" Update in " + String(SensorReadLoop),RIGHT,0);
if (SensorReadLoop == 0){
myGLCD.print(" ",0,0);
OilPressure = OilPressureSnapshot/LoopCount;
WTemp=WTempSnapshot/LoopCount;
FuelLevel=FuelLevelSnapshot/LoopCount;
BVolts=BVoltsSnapshot/LoopCount;
OilTFT(); delay(100); WaterTFT(); delay(100); FuelTFT(); delay(100); BatteryTFT() ;delay(100);
SensorReadLoop=LoopCount;
OilPressureSnapshot=0; WTempSnapshot=0; FuelLevelSnapshot=0; BVoltsSnapshot=0;
int CheckGauges(String(Gauge)){
for (int WarnLoop=0; WarnLoop <= 2; WarnLoop++){
myGLCD.setBackColor (VGA_RED);
myGLCD.print(" ",CENTER,0);
myGLCD.print("Check " + String(Gauge),CENTER,0);
delay (200) ;
myGLCD.setBackColor (VGA_BLUE);
void OilTFT(){
if (OilPressure <=10){
myGLCD.print(" Oil ",0,40);
myGLCD.print(String(OilPressure),150,40);
myGLCD.print("PSI",RIGHT,40);
CheckGauges("Oil Pressure");
if (OilPressure >=11){
myGLCD.print("Oil Pressure OK",CENTER,0);
void WaterRead () {
WVal = analogRead(WIn) ; // WInput
WVal = map(WVal, 1, 1024, 1024, 1);//Invert Reading Scale
WTemp = (WVal /4.021053) ;
WTemp=250;
void WaterTFT(){
if (WTemp <=220){
myGLCD.print(" Water Temp OK ",CENTER,0);
myGLCD.print(" Water ",0,80);
myGLCD.print(String(WTemp),150,80);
myGLCD.print(" `F",RIGHT,80);
if (WTemp >=220){
myGLCD.setBackColor (VGA_RED);//Red,Green,Blue
myGLCD.print(" `F",RIGHT,80); // Degree is ascii 0176
CheckGauges("Water Temp");
void FuelRead(void){
FVal = analogRead(FIn); // FInput
FVal = map(FVal, 1, 1024, 1024, 1);//Invert Reading Scale to compensate for 10 Ohm Full 80 Ohm Empty Scale.
if (FVal < 388 ) { // Prevent Negative numbers from being displayed on the digital readout.
FVal = 388 ;
FVal=1000;
void FuelTFT(){
FuelLevel = (FVal /27.7)-14.0;
if (FuelLevel <=1){
myGLCD.print(" Fuel ",0,120);
myGLCD.printNumF((FuelLevel),2,150,120);
myGLCD.print("GAL",RIGHT,120);
CheckGauges("Fuel Level");
if (FuelLevel >=1.01){
myGLCD.print(" Fuel Level OK ",CENTER,0);
void BatteryRead (void){
float BVOut = 0.00;
float BR1 = 47000;
float BR2 = 4700;
BVal = analogRead(BIn); //BInput
//BVal =1000;
BVOut = ((BVal * 5.0) / 1024.0);
BVolts = BVOut / (BR2/(BR1+ BR2));
BVolts=13.8;
void BatteryTFT(){
if (BVolts <=12.5){
myGLCD.print(" Battery ",0,160);
myGLCD.printNumF((BVolts), 2, 150, 160);
myGLCD.print("Volts",RIGHT,160);
CheckGauges("Alternator");
if (BVolts >=12.5){
myGLCD.print(" Battery Voltage OK ",CENTER,0);
void LeftTurn(){
myGLCD.setFont(Inconsola);
myGLCD.setColor(VGA_LIME);
myGLCD.fillRoundRect(5,190,135,235);
myGLCD.setColor(VGA_BLUE);
myGLCD.setBackColor(VGA_LIME);
myGLCD.print(" < ",10,200);delay(10);
myGLCD.print(" < ",10,200);delay(100);
void RightTurn(){
myGLCD.fillRoundRect(175,190,319,235);//delay(10);
myGLCD.print(" > ",RIGHT,200);delay(10);
myGLCD.print(" > ",RIGHT,200);delay(100);
