Three codes to run timed code after sleep mode
Hello,
I would like to activate a motor for 3 minutes a day.
Since the system is battery powered I am going to use the RTC DS3231 to wake up the PRO MINI at a specific time every day in order to run a water pump for 3 minutes.
I came out with three different solutions (and I imagine the good one is not among them):
To keep it short I did not paste the setup.
I am using the following libraries:
#include <avr/sleep.h>//this AVR library contains the methods that controls the sleep modes
#include <Wire.h> // must be included here so that Arduino library object file references work
#include <RtcDS3231.h>
Solution 1: Use of millis()
  delay(100) //delay
  unsigned long currentTime = millis();
  if(currentTime - previousTime > interval){
  Going_To_Sleep(); //put Arduino on sleep mode
  WaterPump();
void Going_To_Sleep(){
    sleep_enable();//Enabling sleep mode
    attachInterrupt(0, WakeUp, FALLING); //0 for D2 pin
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);//Setting up the sleep mode
    sleep_cpu();//activating sleep mode
void WakeUp(){
   sleep_disable();//Disable sleep mode
   detachInterrupt(0); //Removes the interrupt from pin 2;
   previousTime = millis();
void WaterPump(){
  //code for the water pump
Practically, after the interrupt, the variable previousTime will be changed with the current time and the the function WaterPump is called until the interval is passed.
Advantages: simple, just combination of standard code
Disadvantages: the variable of time is declared as unsigned long and it can record up to 50ish days
Solution 2: Use of the alarm as latching switch
  delay(100) //delay
  if(SwitchState == 1){
  time_t t; //create a temporary time variable so we can set the time and read the time from the RTC
  t=RTC.get();//Gets the current time of the RTC
  RTC.setAlarm(ALM1_MATCH_HOURS , 19, 30, 0, 0);// Setting alarm 1 to go off at 7:30pm every day
  RTC.alarm(ALARM_1);
  // enable interrupt output for Alarm 1
  RTC.alarmInterrupt(ALARM_1, true);
  WaterPump();
    SwitchState == 1
void WakeUp(){
   SwitchState =0 ;
    RTC.setAlarm(ALM1_MATCH_MINUTES , 0, minute(t)+5, 0, 0);// Setting alarm 1 to go off 5 minutes from now
    RTC.alarm(ALARM_1);
    attachInterrupt(0, Going_To_Sleep, FALLING); //0 for D2 pin
void WaterPump(){
Practically the interrupt can call two functions (GoingToSleep or Wakeup) according to the value of the variable SwitchCase
Advantages: use of the interrupts and good if interval is quite long
Disadvantages: cumbersome code
Solution 3: Get time from RTC and use instead of millis()
  delay(100) //delay
  if(t - previousTime > interval){
  WaterPump();
void WakeUp(){
   previousTime = RTC.get();
void WaterPump(){
Advantages: avoid the problem of Solution 1, it can be run indefinitely
Disadvantages: not sure about calculations with variable time
Any idea or comments? Can every solution work? Is there any better? Thanks
For solution #1, you have a disadvantage of millis() rolling over ~50 days but that is not a disadvantage. If you code it properly (like you did), having millis() rollover does not impact your code. That is the beauty of unsigned math.
(all unsigned)
Say currentTime = 1;
Say prevTime = 4294967295; // highest value for unsigned long
then currentTime - prevTime = 1 - 4294967295 == 2!
The math still works.
blh64:
(all unsigned)
Thanks, I did not know about this property.
I thought unsigned was like the absolute value. I think I ll go with solution 1. Cheers
Yes, #1 is clean, simple and readable.
Within the info you’ve given, it’s the way to go.
