Three codes with led and two break beam sensors
These three codes make an led come on or blink using two break beam sensors. The first code makes the led come on when the first sensor is made or LOW and makes the led go off when the second sensor is made or LOW. The second code makes the led blink when the first sensor is made or LOW and stop blinking when the second sensor is made or LOW. The third code makes the led blink when the first sensor is LOW, after that if the first sensor is HIGH the led stays on solid until the second sensor is made or LOW.
This code makes the led come on when sensor one is made and go off when sensor two is made.
const byte SENSORPIN1 = 5;
const byte SENSORPIN2 = 6;
const byte LEDPIN = 8;
int sensorState1 = 0, lastState1 = 0;
int sensorState2 = 0, lastState2 = 0;
 pinMode(SENSORPIN1, INPUT_PULLUP);
  pinMode(SENSORPIN2, INPUT_PULLUP);
  pinMode(LEDPIN, OUTPUT);
  led_switch();
void led_switch(){
  sensorState1 = digitalRead(SENSORPIN1);
  sensorState2 = digitalRead(SENSORPIN2);
  if (sensorState1 == LOW){
    digitalWrite(LEDPIN, HIGH);
  if (sensorState2 == LOW){
    digitalWrite (LEDPIN, LOW);
This code makes the led blink after the first sensor is made and stop blinking when the second sensor is made.
boolean blinkState = LOW;
boolean ledState = LOW;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
const long interval = 250;
  blinkState = HIGH;
  led_switch();
  led_blink();
void led_switch(){
    blinkState = LOW;
    blinkState = HIGH;
void led_blink(){
  if (blinkState == LOW){
  if (currentMillis - previousMillis >= interval){
    if (ledState == LOW){
      ledState = HIGH;
    else{
      ledState = LOW;
    digitalWrite(LEDPIN, ledState);
This code makes the led blink while sensor one is LOW after that when sensor one is HIGH the led stays on solid until sensor two is made.
boolean blinkdone = false;
boolean event;
  blinkState = HIGH;
  event = true;
  led_switch();
  led_blink();
void led_switch(){
    blinkState = LOW;
  if (sensorState1 == HIGH){
    blinkState = HIGH;
  if ((blinkdone == true) && (sensorState1 == HIGH) && (sensorState2 == HIGH)){
    digitalWrite (LEDPIN, HIGH);
    event = false;
    digitalWrite(LEDPIN, LOW);
    blinkdone = false;
    event = true;
void led_blink(){
  if (event == true){
      ledState = HIGH;
      blinkdone = true;
    else{
      ledState = LOW;
Is there a question?
Not a actual question but always looking for ways to improve my coding and get one step closer to completing my squiggle maximizer.
