Three node Zigbee network Programming in Arduino
I set up a three node network in Digimesh using S1 radios. Each node is configured to send and receive data from other node and it is happening fine which I checked with X-CTU console.
Now I need to know how to program to take the serially communicated data and display in serial monitor when they are connected with Arduino. Each node must be able to send to and receive data from other two nodes and able to identify from which node it came and display the received data in serial monitor.
How? A series 1 radio communicates with one other radio.
To and from which other node?
That depends on how the XBee is connected to the Arduino.
Without using API mode, you can't do this. With API mode, and Andrew Rapp's XBee library, it is trivial. Believe it or not, there are even examples provided with the library.
The node 1 can send and receieve data from node 2 and 3.Similarly each node can send and receive data from other two nodes.
This is carried out by configuring them in Digimesh mode.
Xbee is connected to the arduino using x-bee shield.here is the link for the product
http://shieldlist.org/libelium/xbee
I sent an address identifier say 1 for node 1,2 for node 2 and so on along with data for each node. I want the receiver to identify the source of the data by identifying this identifier.
code at the sender:
  Serial.print('l');
  Serial.print('H');
   Serial.print('l');
  Serial.print('L');
code at the receiver:
int incomingByte; //a variable to read data
int add;// a variable to read identifier
  // initialize serial communication:
  // see if there's incoming serial data:
  if (Serial.available() > 1) {
    Serial.print("start");
    add=Serial.read();
//if identifier is 1,print the received data
    if (add==1)
      Serial.println("first node");
    incomingByte = Serial.read();
    Serial.write(incomingByte);
On the sender, you send an identifier of '1', but on the receiver, you check the value against 1. '1' and 1 aren't the same value.
You also don't read the second byte if the identifier doesn't match. That will cause it to get it off sync very fast.
Hi Arrch,
Thanks for pointing out.I thought both represent numeral 1. I was wondering Why the control doesn't enter the loop.Now I get it.
So should the program at the receiver must be modified like this?
 if (add=='1')
I am beginner. So please pardon me if I am making some silly mistakes
Hi paulS,
Can you send me those examples which you mentioned?
Why? They come with the library. If you have the library, you have the examples. If you don't, then code I sent you wouldn't compile, so I'd be wasting my time.
viz_90:
Hi Arrch,
 if (add=='1')
There is no loop in what you posted, post your entire sketch. You also shouldn't be using Serial to communicate with both the serial monitor AND the other Arduino.
this is the code at receivers end
    add=Serial.read();
    if (add=='1')
Is there any other way to communicate to serial monitor other than serial?
How to communicate then with serial other than
    add=Serial.read();
    if (add=='1')
Again:
Even if you were to read both regardless of if the identifier matches, a single missed digit and you're out of sync. I think you should re-think your strategy. State machines are the best way to handle this. You would send a "start packet" byte, then the identifier, then the value. If the length of the value could vary, you would want to also send a "stop packet" byte. The state machine would accept the incoming byte as its input and have states such as SEEKING_START_BYTE, SEEKING_IDENTIFIER and SEEKING_VALUE.
Not with a regular Arduino
Assuming you're using an Uno or other single UART device, you can use the SoftwareSerial library.
Hi arrch,
what do you mean by state machine?.API mode?
Do you have any examples for this?
There aren't any. No one else has ever use SoftwareSerial.
Have your google skills completely gone away?
