Throttle speed changes according to variable ping threshold value.
I decided to start a new topic as this is more specific to what I'm currently attempting.
So far results are good and movement is smooth.
*Just a few problems:
-Right when I upload my sketch, the motors temporarily go in reverse (for a few seconds) and then code works as I want it to
-At the moment acceleration/deceleration is a bit slow. I would like to modify this by increasing the ++ and -- in the void handleAcceleration() function...just wondering the best way.
Here is the sketch:
//Sabertooth 2X25 motor controlled robot in RC microcontroller (mixed) mode
// with differential & exponential settings.
//S1 controls throttle.
//S2 controls steering.
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
const byte pingPins [N_PINGS] = {
  22, 23, 24, 25};   // PING pins
const int minRanges [N_PINGS] = {
  14, 14, 36, 14};
Servo servoThrottle; // create servo object for throttle
Servo servoSteering; // create servo object steering
int currentSpeed = 0; // variable to store the servo current speed
int targetSpeed = 0; // variable to store the servo target speed
unsigned long lastSpeedUpdateTime = 0;
const unsigned long SPEED_UPDATE_INTERVAL = 10; // ms
  servoThrottle.attach(53, 1000, 2000); // attach the throttle servo
  servoSteering.attach(52, 1000, 2000); // attach the steering servo
  handleAcceleration();
  servoThrottle.write(currentSpeed);
void setSpeed(int requiredSpeed)
  int range [N_PINGS];
  range [2] = ping(pingPins [2]);
  delay(5);
  int centerThresh = range [2];
  centerThresh = map(centerThresh, 14, 54, 1500, 2000);
  requiredSpeed = constrain(centerThresh, 1500, 2000);
  targetSpeed = requiredSpeed;
  setSpeed(targetSpeed);
  unsigned long now = millis();
  if(now - lastSpeedUpdateTime > SPEED_UPDATE_INTERVAL)
    // time to check the motor speed again
    if(currentSpeed < targetSpeed)
      // accelerating
      currentSpeed++;
    else if(currentSpeed > targetSpeed)
      // deccelerating
      currentSpeed--;
      // motor is already at the target speed - no action required
    lastSpeedUpdateTime = now;
void pingCalc()
  for (int i = 0; i < N_PINGS; ++i) {
    range [i] = ping(pingPins [i]);
    //delay(5);
long ping(int pin)
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
  delayMicroseconds(2);
  digitalWrite(pin, HIGH);
  delayMicroseconds(5);
  pinMode(pin, INPUT);
  return (microsecondsToInches(pulseIn(pin, HIGH)));
long microsecondsToInches(long microseconds)
  return microseconds / 74 / 2;
// The following are for object tracking/follow with Kinect sensor
void motForward()
void motBackward()
void motStop()
void motRight()
void motLeft()
void serialEvent()
Instead of sneaking up on the final speed in increments of 1, increment by 10 % of the difference, or 1, which ever is greater.
The NewPing library is non-blocking. The pulseIn() function IS blocking. Just so you know...
PaulS:
Thanks for the reply Paul.
So possibly using a For loop?:
 for(int i = 1; i <= 10; i++)  //accel
Also thought of it this way:
for(int i=1; i <= 10; i++)  //accel
currentSpeed*i;
No, not like that at all.
If you are accelerating, it is because the current speed is less than the target speed. So:
int incr = (targetSpeed - currentSpeed) / 10;
if(incr == 0)
   incr = 1;
currentSpeed += incr;
If you are decelerating, it is because the current speed is greater than the target speed, reverse targetSpeed and currentSpeed and use -= instead.
Thanks Paul,
The accel/decel with threshold distance part of the code works great.
I'm trying now to incorporate the steering according to data received from the Kinect camera.
Incoming data is the X axis values of the object being tracked.
The width of the camera screen is 640, so values range from 0 to 640 and 320 being center.
I setup a threshold of something like 160>=centerthresh<=480. If the object is on the left of the screen or<160 then steer left until object is in center threshold. If object is on the right of the screen or >480 then steer right until object is in center threshold.
Some things I was unsure of doing:
-Should I use acceleration/deceleration for the steering? Something similar to the handleAcceleration() function?
-Should the steering be independent to the throttle accel/decel functions and actions?
-should I/could I combine the serialEvent() and handleCommand() functions?
Here is my code as of now:
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
String command; // a string to hold the incoming command
#define SOP '<'
#define EOP '>'
boolean commandReceived = false;
int valAxisX =0;  //Variable to hold incoming Kinect camera X axis values
const int neutralSpeed = 1500;
const int neutralSteer = 1500;
int currSteerSpeed =0;
  pingCalc();
  serialEvent();
  handleCommand();
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      // deccelerating
      int incr = (currentSpeed - targetSpeed) / 10;
      if(incr == 0)
        incr = 1;
      currentSpeed -= incr;
void leftSteer()
void rightSteer()
int pingCalc()
    //delay(5);
  return range [0];
long ping(int pin)
void serialEvent()
  while (Serial.available())
    // all we do is construct the incoming command to be handled in the main loop
    // get the incoming byte from the serial stream
    char incomingByte = (char)Serial.read();
    if (incomingByte == EOP)
      // marks the end of a command
      commandReceived = true;
      return;
    else if (incomingByte == SOP)
      // marks the start of a new command
      command = "";
      return;
      command += incomingByte;
      return;
void handleCommand()
  if (!commandReceived) return; // no command to handle
  // variables to hold the command id and the command data
  int data[17];
  char cmd[command.length()+1];
  command.toCharArray(cmd, command.length()+1);
  char *token = strtok(cmd, ",");
  // data
  for (int i = 0; i < 17; i++)
    if (token)
      data[i] = atoi(token);
      token = strtok(NULL, ",");
  //test
  //Serial.println(command);
  //Serial.print("data[0] = ");
  //Serial.println(data[0]);
  valAxisX = data[0];
  // flag that we've handled the command
I think you are using acceleration where you mean something else. You want to make the amount to turn proportional to the angle that the object is off from directly in center. A small amount off requires a small correction. A large amount off requires a large correction. I don't see acceleration playing a role.
Yes. That is how people move. Looking left and right, and focusing on a destination is independent on how fast you approach the destination.
My opinion is that serialEvent() should never have been added. Handling serial data is not a separate activity. It should be handled in loop(). So, my recommendation here is no.
Even in loop(), you read and store some serial data, until you get an end-of-packet marker. Then, you call handleCommand() to determine what the serial data is telling you to do.
PaulS:
Ahh, I understand. It would be more of a timing thing. The further away from center threshold the more time steering back to center? etc...
I don't see this as a timing issue, at all. You are heading some direction. It is either spot on, or it isn't. If it isn't, you make a correction. The amount of correction is dependent on how far off course you are.
Then, you check again, and correct again.
The only role that timing plays is in how often you check and how much you correct your off-course-ness. If you check often, you make small corrections. If you check once a month, you make larger corrections.
PaulS:
I updated my sketch, let me know if I'm getting close
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
#define SOP '<'
#define EOP '>'
int angle =0;
      return;
      command = "";
      return;
      return;
pingCalc();
handleCommand();
if((valAxisX >= 0) && (valAxisX <= 160))
  leftSteer();
else if((valAxisX >= 480) && (valAxisX <= 640))
  rightSteer();
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      //currentSpeed++;
      // deccelerating
      if(incr == 0)
        incr = 1;
      //currentSpeed--;
void leftSteer()
for(angle = valAxisX; angle < 220; angle += 10)
  servoSteering.write(angle);
void rightSteer()
for(angle = valAxisX; angle > 420; angle -= 10)
int pingCalc()
    //delay(5);
  return range [0];
long ping(int pin)
  int data[17];
  // data
    if (token)
  //test
  valAxisX = data[0];
      return;
      command = "";
      return;
      return;
Every time you get a new character, start loop() over again. Why? (That is what return is doing.)
handleCommand();
Regardless of whether or not you got a complete packet, handle the command. No, I don't think so.
void leftSteer()
Regardless of how far off course you are, turn the same amount. No, I don't think so. (You will start with the steering angle close to the amount you are off course, but you will end up steering to 220.) (Or 420, in the other case.)
leftSteer() and rightSteer() should accept arguments - the point to steer towards. The call to the function should include the correct angle, based on the angle between the current heading and the desired heading. The functions should not be using for loops.
PaulS:
     return;
     command = "";
     return;
     return;
So, would I only need a 'return;' if I get a EOP?
   return;
      command = "";
How about using something along these lines:
void handleAngle()
  int targetAngle =0;
  if(now - lastAngleUpdateTime > ANGLE_UPDATE_INTERVAL)
    if(currentAngle < targetAngle)
      //left steer
      int incr = (targetAngle - currentAngle) / 10;
      if(incr == 0)
        incr = 1;
      currentAngle += incr;
      servoSteering.write(currentAngle);
    else if(currentAngle > targetAngle)
      // right steer
      int incr = (currentAngle - targetAngle) / 10;
      if(incr == 0)
        incr = 1;
      currentAngle -= incr;
      // Already at target angle..
    lastAngleUpdateTime = now;
Why return at all? That is a cue to call handleCommand(), not to restart loop().
Well, I don't see where currentAngle is defined, and I see no purpose in defining targetAngle to 0. currentAngle, as that code is currently written is either positive or negative. so, targetAngle (= 0) doesn't seem to contribute much.
PaulS:
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
#define SOP '<'
#define EOP '>'
unsigned long lastPosUpdateTime = 0;
const unsigned long POS_UPDATE_INTERVAL = 10; //ms
int currentPos = valAxisX;
int targetPos = constrain(valAxisX, 220, 420);
      command = "";
  pingCalc();
  handleCommand();
    leftSteer();
    rightSteer();
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      // deccelerating
      if(incr == 0)
        incr = 1;
void leftSteer()
  valAxisX = map(valAxisX, 0, 640, 1000, 2000);
  if(now - lastPosUpdateTime > POS_UPDATE_INTERVAL)
    if(currentPos < targetPos)
      //left steer
      int incr = (targetPos - currentPos) / 10;
      if(incr == 0)
        incr = 1;
      currentPos += incr;
      servoThrottle.write(currentPos);
    lastPosUpdateTime = now;
void rightSteer()
    if(currentPos > targetPos)
      // right steer
      int incr = (currentPos - targetPos) / 10;
      if(incr == 0)
        incr = 1;
      currentPos -= incr;
int pingCalc()
    //delay(5);
  return range [0];
long ping(int pin)
  int data[17];
  // data
    if (token)
  //test
  valAxisX = data[0];
Here's my left & right Steer functions.
void leftSteer()
    if(valAxisX < targetPos)
      //left steer
      int incr = (targetPos - valAxisX) / 10;
      if(incr == 0)
        incr = 1;
      valAxisX += incr;
void rightSteer()
    if(valAxisX > targetPos)
      // right steer
      int incr = (valAxisX - targetPos) / 10;
      if(incr == 0)
        incr = 1;
      valAxisX -= incr;
Not sure on how to convert the values of valAxisX to servo values...
Possibly?:
currentPos = map(valAxisX, 0, 640, 1000, 2000);
And full sketch:
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
#define SOP '<'
#define EOP '>'
int valAxisX =0;
const int targetPos = 320;
const unsigned long POS_UPDATE_INTERVAL = 10; // ms
int currentPos = 0;
      command = "";
  pingCalc();
  handleCommand();
    leftSteer();
    rightSteer();
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      // deccelerating
      if(incr == 0)
        incr = 1;
void leftSteer()
      //left steer
      if(incr == 0)
        incr = 1;
      valAxisX += incr;
void rightSteer()
      // right steer
      if(incr == 0)
        incr = 1;
      valAxisX -= incr;
int pingCalc()
    //delay(5);
  return range [0];
long ping(int pin)
  int data[17]; // up to three integers of data
  // data
    if (token)
  //test
  valAxisX = data[0];
Any help appreciated..
Since you're using servo.write, you'll need a value between 0 and 180 for currentpos (if your servo can manage those angles) so:
currentPos = map(valAxisX, 0, 640, 0, 180);
There is some strange stuff going on with arrays:
int pingCalc()
    //delay(5);
  return range [0];
You're building an array of ping data which is then thrown away when the function exits, returning only the first element; why use an array at all?
The same pattern appears in HandleCommand.
Thanks for the reply and info, made a few changes and seem to have it working like I want to...not sure how the code looks though...
//Date:  7Jan14
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
int pingRange = 0;
#define SOP '<'
#define EOP '>'
int valAxisX =0;
int currentPos = 0;
const int targetPos = constrain(valAxisX, 260, 370);
int Step = 10;
      command = "";
  pingCalc();
  handleCommand();
  if((valAxisX <= 200) && (valAxisX >= 0))
    servoThrottle.write(neutralSpeed);
    leftSteer();
  else if((valAxisX >= 440) && (valAxisX <= 640))
    rightSteer();
  else if((valAxisX > 200) && (valAxisX < 440))
    servoSteering.write(neutralSteer);
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      // deccelerating
      if(incr == 0)
        incr = 1;
void leftSteer()
  int newPos = currentPos + Step;
  if((currentPos < targetPos) && (newPos > targetPos))
    newPos = targetPos;
  int currServPos = map(newPos, 0, 640, 1000, 2000);
  servoSteering.write(currServPos);
void rightSteer()
  int newPos = currentPos - Step;
  if((currentPos > targetPos) && (newPos < targetPos))
    newPos = targetPos;
void pingCalc()
    //delay(5);
    pingRange = range[i];
long ping(int pin)
  // data
    if (token)
      valAxisX = data[i];
Argh....
Having a small bug :confused:
When I move my red object to the left of the kinect the motors turn right and moving the object to the right of the kinect motors turn left.
Basically the steering is reversed. Been trying everything I can think of (all night...)
Here's the main loop:
      command = "";
  pingCalc();
  //stepperMove();
  //stepper.run();
  handleCommand();
  if((valAxisX >= 0) && (valAxisX <= 200))
    leftSteer();
    rightSteer();
Here's the left & right steering functions:
void leftSteer()
  const int targetPos = 1500;
  const int Step = 10;
  int currentLPos = valAxisX;
  currentLPos = map(currentLPos, 0, 640, 1000, 2000);
  int newPos = currentLPos + Step;
  if((currentLPos < targetPos) && (newPos > targetPos))
    newPos = targetPos;
  servoSteering.write(newPos);
void rightSteer()
  int currentRPos = valAxisX;
  currentRPos = map(currentRPos, 0, 640, 1000, 2000);
  int newPos = currentRPos - Step;
  if((currentRPos > targetPos) && (newPos < targetPos))
    newPos = targetPos;
And the full sketch:
//Date:  7Jan14
#include <AccelStepper.h>
#include <Servo.h>
#define N_PINGS 4
  14, 14, 36, 14};
int pingRange = 0;
AccelStepper stepper(2,12,13);
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 8;
const int brakeB = 9;
#define SOP '<'
#define EOP '>'
int valAxisX =0;
  pinMode(pwmA, OUTPUT);
  pinMode(pwmB, OUTPUT);
  pinMode(brakeA, OUTPUT);
  pinMode(brakeB, OUTPUT);
  digitalWrite(pwmA, HIGH);
  digitalWrite(pwmB, HIGH);
  digitalWrite(brakeA, LOW);
  digitalWrite(brakeB, LOW);
  stepper.setMaxSpeed(100);
  stepper.setSpeed(50);
  stepper.setAcceleration(200);
  //stepper.moveTo(40);
      command = "";
  pingCalc();
  //stepperMove();
  //stepper.run();
  handleCommand();
    leftSteer();
    rightSteer();
  delay(5);
      // accelerating
      if(incr == 0)
        incr = 1;
      // deccelerating
      if(incr == 0)
        incr = 1;
void leftSteer()
    newPos = targetPos;
void rightSteer()
    newPos = targetPos;
void pingCalc()
    //delay(5);
long ping(int pin)
  // data
    if (token)
      valAxisX = data[i];
void stepperWaiting()
  while (stepper.distanceToGo() != 0)
    stepper.run();
  Serial.println(stepper.currentPosition());
  delay(2000);
void stepperMove()
  stepper.moveTo(40);
  stepperWaiting();
  stepper.moveTo(0);
  stepperWaiting();
  stepper.move(-40);
  stepperWaiting();
  stepper.moveTo(0);
  stepperWaiting();
Captain Obvious says, rename leftsteer as rightsteer and vice versa :stuck_out_tongue:
wildbill:
Yeah, I've tried that....no luck, no change (includes the functions and the function calls in main loop :confused:
thanks WildBill.
..must be something small..
