throughbeam ir sensor with sms
Hello everybody .
I`m building burglar alarm with sms alert with ir throughbeam sensors
I have a problem with the code
gsm modem sending sms even when the throughbeam is not broken
Can please anyone help me with this code:
#include “SIM900.h”
#include <SoftwareSerial.h>
#include “sms.h”
#include <Wire.h>
SMSGSM sms;
String smsText = "INTRUDER ";
boolean started = true;
char sms_text[160];
int ledPin = 13;
int SENSORPin = 4;
int val = HIGH;
#define SENSORPIN 4
// variables will change:
int sensorState = 0, lastState=0;
pinMode (ledPin, OUTPUT);
pinMode(SENSORPIN, INPUT);
digitalWrite(SENSORPIN, HIGH); // turn on the pullup
if (gsm.begin(9600))
Serial.println("\nstatus=READY");
started = true;
Serial.println("\nstatus=IDLE");
void loop ()
val = digitalRead(SENSORPin);
digitalWrite(ledPin, val);
if (val == 1)
smsText = smsText;
smsText.toCharArray(sms_text, 160);
sms.SendSMS(“0701548869”, sms_text);
String smsText = "intruder ";
for(;;){ /empty/ }
int SENSORPin = 4;
int val = HIGH;
#define SENSORPIN 4
Two names that differ only in case are NOT a good idea. Make up your mind which ONE you want to use and get rid of the other one.
With pullup resistors, HIGH means not pressed, so getting a message when the beam is not broken is not surprising.
Hmm, i have changed it
It is the same
Rapsbagge:
It is the same
Then it is a hardware issue. We need to see a schematic.
Rapsbagge:
It is the same
Did you deal with the last paragraph of Reply #1 ?
Post your latest code - we have no idea what changes you made.
And please use the code button </>
so your code looks like this
and is easy to copy to a text editor
…R
it`s working now :) :) :) :)
Rapsbagge: it`s working now :) :) :) :)
As an aid to other newcomers who may read your Thread please describe how you solved the problem.
...R
