Tian clearance for shields?
On the new Tain, does anyone know the clearance required for a shield to be mounted. Looking at it, it has the same issue the Yun had, the Ethernet port is in the way and they didn't use the extended pin headers. I'm making a custom shield and would at least like to design it so it would work on the new Tian. Looking at the Tian it seems that the 10 pin header is a little beyond the Ethernet port so if a perpendicular cut is made to the pin header, it will still hit the Ethernet port?
I would like to make a straight cut on the shield, but looking at it, it does appear to be the case?
Anyone have one yet to know if this is true?
