Hi guyz. Hope all is well.
My project is simple. I set the time on a RV-1805 Real Time Clock Module using the code below.
( SparkFun Real Time Clock Module - RV-1805 (Qwiic) - BOB-14558 - SparkFun Electronics )
Can this RTC be set to count Unix time instead? By that I mean, can I directly feed 1721743817 into the RTC and then ask the RTC to increase this 1721743817 number by 1 for every real second that ticks in real life?
Right now, the code below sets the time in normal human format and prints the time in normal human format.
My project prefers that I work directly with the 'raw Unix' time.
The datasheet and the manual do not mention any info that helps.
Ty 4 the replies!
Setting time from the RV-1805 Real Time Clock
By: Andy England
Date: 2/22/2017
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
Feel like supporting our work? Buy a board from SparkFun!
https://www.sparkfun.com/products/14642
This example shows how to set the time on the RTC to the compiler time or a custom time.
Hardware Connections:
Attach the Qwiic Shield to your Arduino/Photon/ESP32 or other
Plug the RTC into the shield (any port)
Open the serial monitor at 9600 baud
#include <SparkFun_RV1805.h>
RV1805 rtc;
//The below variables control what the date will be set to
int hund = 50;
int sec = 2;
int minute = 18;
int hour = 7;
int date = 25;
int month = 6;
int year = 2018;
int day = 5;
Wire.begin();
Serial.println("Read Time from RTC Example");
if (rtc.begin() == false) {
Serial.println("Something went wrong, check wiring");
//Use the time from the Arduino compiler (build time) to set the RTC
//Keep in mind that Arduino does not get the new compiler time every time it compiles. to ensure the proper time is loaded, open up a fresh version of the IDE and load the sketch.
if (rtc.setToCompilerTime() == false) {
Serial.println("Something went wrong setting the time");
//Uncomment the below code to set the RTC to your own time
/*if (rtc.setTime(hund, sec, minute, hour, date, month, year, day) == false) {
Serial.println("RTC online!");
if (rtc.updateTime() == false) //Updates the time variables from RTC
Serial.print("RTC failed to update");
String currentTime = rtc.stringTime();
Serial.println(currentTime);
