Tick Tock Shield Arduino
Bonjour
J ai acquis récemment ce kit pour “débutant” !!
J’ai téléchargé et installé la Tick Tock Shield Library
Ensuite ce kit propose 7 programmes de demo toujours pour débutant
Déjà le le démo 1 me pose d’énormes pbs mais en le modifiant avec mes connaissances je suis parvenu à le faire fonctionner
Donc je m attaque au prog démo 2
//  Demo function:Use the three buttons to control four LEDs.
//			Note: K3-menu, K2-increase,K1-decrease
//			Power up: all the LED off
//	Every time the menu key pressed, the status changes from TEST_START
//	to TEST_END or from TEST_END to TEST_START.
//  When it starts, "increase" key can turn on one more LED from right to left
//	every time the "increase" key pressed.
//	The "decrease" key operation is inverse process of "increase" key's.
//  Author:Frankie.Chu
//  Date:23 September, 2012
//  This library is free software; you can redistribute it and/or
//  modify it under the terms of the GNU Lesser General Public
//  License as published by the Free Software Foundation; either
//  version 2.1 of the License, or (at your option) any later version.
//  This library is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
//  Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with this library; if not, write to the Free Software
//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
//  Modified record:
#include <TimerOne.h>
#define DEBUG 1//comment out if you don't need debug information
//-------pin definition of LEDs---------------//
#define LED_CLOCK_ADJUST	5
#define LED_ALARM_ADJUST	4
#define LED_ALARM_ENABLE	3
#define LED_BRIGHTNESS_ADJUST	2
//-------pin definition of keys---------------//
#define KEY_MENU	11
#define KEY_UP		10
#define KEY_DOWN	9
//------the status of the test---------------//
/*Every time the MENU key pressed, it toggle status between TEST_START and TEST_END	*/
/*When it is TEST_START, it turns to be TESTING if UP key or DOWN key is pressed.*/
uint8_t status;
	#define TEST_END   0 //the LEDs are off
	#define TEST_START 1 //the LEDs blink once per second
	#define TESTING	   2 //UP key or DOWN key can control the LEDs
const int LEDS_PIN[] =
	LED_BRIGHTNESS_ADJUST,
	LED_ALARM_ENABLE,
	LED_ALARM_ADJUST,
	LED_CLOCK_ADJUST
/*Store ID of highest ranked lit LED.*/
/*eg:If highest ranked lit LED is LED1, LED_on_number is 0.*/
/*	 If it is LED2, LED_on_number is 1 and so on.*/
int8_t LED_on_number = -1;
/*Toggle the status between TEST_START and TEST_END.*/
/*If flag_test_start is 0, the status is TEST_END.*/
/*Otherwise, the status is TEST_START.*/
boolean flag_test_start;//the initial value is 0
/*If flag_all_on is 0,then turn on all LEDs.*/
/*Otherwise, turn off all LEDs.*/
/*Use only when the status is TEST_START.*/
boolean flag_all_on;
#ifdef DEBUG//if debug message needed, start serial communication
#endif
	/*Initialization for the hardware*/
	init_pins();
	Timer1.initialize(500000); // set a timer of length 500000 microseconds
	Timer1.attachInterrupt( timer1Isr ); // attach the interrupt service routine to the timer1
	int16_t key_pressed = scanKey();//poll status of all keys
	if(key_pressed == KEY_MENU)
	/*Every time the menu key pressed, it toggle status between TEST_START and TEST_END	*/
		flag_test_start = ~flag_test_start;
		if(flag_test_start)status = TEST_START;
		else status = TEST_END;
	else if(key_pressed == KEY_UP)
	/*When it is TESTING, "UP" key can turn on one more LED from right to left*/
	/*every time the "UP" key pressed. */
		if(status == TEST_START)status = TESTING;
		if(status == TESTING)turnOnMoreLED();
	else if(key_pressed == KEY_DOWN)
	/*When it is TESTING, "DOWN" key can turn off one more LED from left to right*/
	/*every time the "DOWN" key pressed. */
		if(status == TESTING)turnOffMoreLED();
	/*if a key has been pressed, wait for extra 200ms*/
	if(key_pressed > 0)delay(200);
/*Initialization for the hardware,and should be called first*/
void init_pins()
	/*set keys to be inputs and define the initial status as HIGH*/
	pinMode(KEY_MENU, INPUT);
	digitalWrite(KEY_MENU, HIGH);
	pinMode(KEY_UP, INPUT);
	digitalWrite(KEY_UP, HIGH);
	pinMode(KEY_DOWN, INPUT);
	digitalWrite(KEY_DOWN, HIGH);
	/*define the pin mode of LEDs*/
	pinMode(LED_CLOCK_ADJUST, OUTPUT);
	pinMode(LED_ALARM_ADJUST, OUTPUT);
	pinMode(LED_BRIGHTNESS_ADJUST, OUTPUT);
	pinMode(LED_ALARM_ENABLE, OUTPUT);
	turnOffAll();//Turn off all the LEDs first.
/*Turn on one LED*/
inline void turnOn(int pinLED)
	digitalWrite(pinLED, HIGH);
/*Turn Off one LED*/
inline void turnOff(int pinLED)
	digitalWrite(pinLED, LOW);
/*Turn on all the LEDs*/
inline void turnOnAll()
	turnOn(LED_CLOCK_ADJUST);
	turnOn(LED_ALARM_ADJUST);
	turnOn(LED_BRIGHTNESS_ADJUST);
	turnOn(LED_ALARM_ENABLE);
/*Turn off all the LEDs*/
inline void turnOffAll()
	turnOff(LED_CLOCK_ADJUST);
	turnOff(LED_ALARM_ADJUST);
	turnOff(LED_BRIGHTNESS_ADJUST);
	turnOff(LED_ALARM_ENABLE);
/*Turn on one more LED*/
void turnOnMoreLED()
	if(LED_on_number < 3) //when not all LEDs are on
		LED_on_number ++;
		turnOn(LEDS_PIN[LED_on_number]);
		for(byte i = LED_on_number + 1;i < 4;i ++)
			turnOff(LEDS_PIN[i]);//make sure the higher ranked LEDs are off
/*Turn off one more LED*/
void turnOffMoreLED()
	if((LED_on_number > 0) || (LED_on_number == 0))//when not all LEDs are off
		turnOff(LEDS_PIN[LED_on_number]);
		LED_on_number --;
/*Scan keys and get to know which one is pressed*/
int16_t scanKey()
	int16_t pin_number = -1;//define non-existent pin number
	if(digitalRead(KEY_MENU) == LOW)
		delay(20);
			pin_number = KEY_MENU;
	#ifdef DEBUG //print out the message on serial monitor
		Serial.println("KEY_MENU is pressed");
	#endif
	else if(digitalRead(KEY_UP) == LOW)
		delay(20);
			pin_number = KEY_UP;
	#ifdef DEBUG
		Serial.println("KEY_UP is pressed");
	#endif
	else if(digitalRead(KEY_DOWN) == LOW)
		delay(20);
			pin_number = KEY_DOWN;
	#ifdef DEBUG
		Serial.println("KEY_DOWN is pressed");
	#endif
	return pin_number;
/*Timer one interrupt service routine*/
void timer1Isr()
	/*if it start, all the LEDs will blink once a second.*/
		flag_all_on = ~flag_all_on;
		if(flag_all_on)
			LED_on_number = 3;//no more LED to turn on
			turnOnAll();
			LED_on_number = -1;//no more LED to turn off
			turnOffAll();
	else if(status == TEST_END)
		turnOffAll();
		LED_on_number = -1;
Mais la lorsque je veux le compiler j obtiens des message d’erreur
Arduino : 1.7.10 (Windows 7), Carte : “Arduino Uno”
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-ar: unable to rename ‘C:\Users\Alju\AppData\Local\Temp\build1615483783681806320.tmp/core.a’; reason: File exists
Erreur lors de la compilation.
C:\Users\Alju\AppData\Local\Temp\build1615483783681806320.tmp/core.a(wiring.c.o): In function `delay’:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/wiring.c:114: undefined reference to `yield’
collect2.exe: error: ld returned 1 exit status
Je trouve aussi ce programme très compliqué pour un débutant
Donc si qq utilise ce shield pourrai me donner qqs conseils
cordialement
bonjour
je suis étonné que vraiment personne n'utilise ce shield
cordialement chriiss62
Bonjour,
Il n’y a pas de problème pour compiler ton programme.
C’est to compilateur qui doit disfonctionner.
Essaie de supprimer manuellement le fichier qui pose problème: ‘C:\Users\Alju\AppData\Local\Temp\build1615483783681806320.tmp/core.a’
Installez la dernière version de l'IDE on dirait que vous utilisez la 1.7.10
bonjour et merci de me répondre
j ai déjà essayé de charger une nouvelle version d'arduino sur un autre pc (heureusement) et lorsque je le lance il m indique un message d'erreur Je n ai pas l intitulé du message d'erreur en tête car la suis en vacances et le pc en question est à mon travail.
cordialement
OK sans doute une piste à explorer
Bonjour
Oui, j'utilise la version 1.7.10
Donc comme je disais lorsque j ai essayer d'installer une autre version il met impossible de lancer le programme
De mémoire c était une erreur de croquis manquant
