TIL-306 wiring
Hiya, i have recently dug out some old electronics bits i had put to one side. one of them is a 16 pin 7 Seg display, with its own micro controller (TIL-306). I am just trying to wire this up to an Arduino so that i can either count button presses or send something from the Arduino to it. If any one could help that would be great :). Thanks in advance.
Oh the Datasheet for the TIL-306 is attached
Here is a quick way to test/experiment with TIL307/TIL307
NOTE: LATCH should occur before a CLEAR and BOTH LATCH and CLEAR should be held HIGH until you want to either LATCH or CLEAR the counter, at which point the respective pin is set LOW.
Thats great thanks PWillard, now i'm having a little trouble actually getting it working though so i will explain what i have done to try and make it count.
I have an Arduino Mega 1280 By the way.
I have connected the following
Latch to Pin 22
Clear to Pin 23
Pulse to Pin 24
The code i am using is below
const int Latch = 22;
const int Clear = 23;
const int Pulse = 24;
  pinMode(Latch, OUTPUT);
  pinMode(Clear, OUTPUT);
  pinMode(Pulse, OUTPUT);
  digitalWrite(Latch, HIGH);   // set the LED on
  digitalWrite(Clear, LOW);   // set the LED on
  digitalWrite(Clear, HIGH);   // set the LED on
  digitalWrite(Pulse, LOW);   // set the LED on
  digitalWrite(Pulse, HIGH);   // set the LED on
  delay(2500);
I am simply trying to get it to count up to 5. But it seems to just show random numbers sometimes :~. Is there something i am doing wrong?
Um... this is sort of tricky... I'll see if I can write up a some sample code for you. I have a number of these parts I can play with from an old Frequency Counter project.
OK, this was quick:
You were on the right track... I misled you about LATCH... sorry.
// NOTE currently setup to clear counter at 7
const int Latch = 12;  // Different PINS (BOARDUINO)
const int Clear = 3;
const int Pulse = 2;
int counter;
  // PIN PRESETS
  // Initialize latch and clear settings to
  // allow COUNT mode
  // ______|                LATCH
  digitalWrite(Latch, HIGH); // LOCK THE DISPLAY
  delay(100);
  // ______|                PULSE
  digitalWrite(Clear, HIGH); // Leave CLEAR HIGH to allow counting
  delay(100);
  counter = 0;
 // use serial monitor for debugging
  counter = counter++;
  Serial.println(counter,DEC);
  //      |_______________  LATCH
  digitalWrite(Latch, LOW);  // LATCH LOW to COUNT
  // ______|      |______  PULSE
  delay(100);
  digitalWrite(Pulse, HIGH);  // PULSE TOGGLE to count up
  delay(100);
  delay(1000); // So we can see stuff happen
  // --SOME DEBUG--
  // COUNT TO 7 to show how CLEAR works
  if (counter == 7) {
    Serial.println("clear");
 // Set COUNT to Zero on Display
 //       |_______|        CLEAR
    delay(100);
    counter = 0;
Thank you, I am not able to try this out right away but will let you know the results asap :slight_smile:
I got this working fine, then added a second TIL-306 and it seems to count to 16 before it resets? i will look into this and post the results if i figure it out. Thanks for the help :).
