Tilt sensor shut off LED?
Hey guys, so im working on a project in which an ultrasonic sensor detects an object in range, and switches on an led. I also have a tilt switch (The one with the metal ball) and whenever that moves it sets of a diffrent LED ( i will refer to this as LED2). Is there anyway I can make the switch turn off LED 1? Please help me, thank you!
This is the code
const int trigPin = 7;
const int echoPin = 8;
const int uvLed = 6;
int Emergency = 9;
int sensorPin = 2;
int sensorValue;
int LastTiltState = HIGH;
long duration;
int distance;
int safteyDistance;
long lastDebounceTime = 0;
long debounceDelay = 50;
void setup(){
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin,HIGH);
pinMode(Emergency, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(uvLed, OUTPUT);
sensorValue = digitalRead(sensorPin);
if (sensorValue == LastTiltState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
LastTiltState = sensorValue;
digitalWrite(uvLed, LOW);
digitalWrite(Emergency, LastTiltState);
Serial.println(sensorValue);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance= duration*0.034/2;
safteyDistance = distance;
if (safteyDistance <= 10){
digitalWrite(uvLed, HIGH);
else{
Serial.print("Distance: ");
Serial.println(distance);
Please use code tags when posting code.
If digitalWrite(Led, LOW) turns ON the LED, then use digitalWrite(Led, HIGH) to turn it off. Or vice versa.
jremington:
Yes, i know that, its just the placement in the code i dont understand.
The code makes no reference to "LED 1" or "LED2".
jremington:
re read the post, but in code led1 is uvLed and led2 is Emergency
If you edit your post to put the code in code tags and put a few //explainations after each bit of code it will be a lot easier to read for you as well as anyone helping. Also hit the auto format in the ide
