Time Alarm Problem
hello!! :frowning:
can you help me with my problem on this project . I am working with arduino Time Alarm. the number of alarm that i will use, consumed a more than a memory limit of the arduino. I am trying to shorten this code for low memory consumption and I am worrying for the stability of my program.
I am using:
  1. DS1307 RTC Module
  2. SD card module
  3. arduino uno
the triggering time for MWF and TTH is the same but i came up to put it individually. Can you help me for this??
#include <TimeAlarms.h>
#include <Time.h>
#include <SD.h>
#include <SPI.h>
#define SD_ChipSelectPin 4
#include <TMRpcm.h>
#include <Wire.h>
#include <DS1307RTC.h>
TMRpcm tmrpcm;
//unsigned long time = 0;
void setup()  {
  // pinMode (2, OUTPUT);
    while (!Serial) ;
    setSyncProvider(RTC.get);
    if(timeStatus()!= timeSet)
      Serial.println(F("Unable to sync with the RTC"));
     Serial.println(F("RTC has set the system time"));
                tmrpcm.speakerPin = 9;
                 if (!SD.begin(SD_ChipSelectPin)) {
                 Serial.println(F("SD fail"));
                return;
Alarm.alarmRepeat(dowMonday,8,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,9,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,10,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,11,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,12,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,1,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,2,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,3,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,4,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,5,0,0,WeeklyAlarm);
Alarm.alarmRepeat(dowMonday,6,0,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,7,30,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,9,0,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,10,30,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,12,0,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,13,0,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,14,30,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,15,0,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,16,30,0,WeeklyAlarm);
  Alarm.alarmRepeat(dowTuesday,17,30,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,8,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,9,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,10,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,11,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,12,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,13,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,14,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,15,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,16,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,17,0,0,WeeklyAlarm);
          Alarm.alarmRepeat(dowWednesday,18,0,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,7,30,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,9,0,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,10,30,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,12,0,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,13,0,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,14,30,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,15,0,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,16,30,0,WeeklyAlarm);
              Alarm.alarmRepeat(dowThursday,17,30,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,8,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,9,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,10,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,11,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,12,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,13,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,14,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,15,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,16,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,17,0,0,WeeklyAlarm);
                                Alarm.alarmRepeat(dowFriday,18,0,0,WeeklyAlarm);
Alarm.alarmRepeat(7,30,0,seventhirty);
Alarm.alarmRepeat(8,0,0,eight);
Alarm.alarmRepeat(8,30,0,eightthirty);
Alarm.alarmRepeat(9,0,0,nine);
Alarm.alarmRepeat(9,30,0,ninethirty);
Alarm.alarmRepeat(10,0,0,ten);
Alarm.alarmRepeat(10,30,0,tent);
Alarm.alarmRepeat(11,0,0,eleven);
Alarm.alarmRepeat(11,30,0,elevent);
Alarm.alarmRepeat(12,0,0,twelve);
Alarm.alarmRepeat(13,0,0,one);
Alarm.alarmRepeat(13,30,0,onet);
Alarm.alarmRepeat(14,53,0,two);
Alarm.alarmRepeat(14,30,0,twot);
Alarm.alarmRepeat(15,0,0,three);
Alarm.alarmRepeat(15,30,0,threet);
Alarm.alarmRepeat(16,14,0,four);
Alarm.alarmRepeat(16,16,0,fourt);
Alarm.alarmRepeat(16,18,0,five);
Alarm.alarmRepeat(17,30,0,fivet);
Alarm.alarmRepeat(18,0,0,six);
  if (timeStatus() == timeSet) {
    digitalClockDisplay();
    Serial.println(F("The time has not been set.  Please run the Time"));
    Serial.println(F("TimeRTCSet example, or DS1307RTC SetTime example."));
    delay(4000);
    Alarm.delay(1000);
void digitalClockDisplay(){
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void WeeklyAlarm(){
  tmrpcm.play("open.wav"); }
  void seventhirty(){
      tmrpcm.play("730.wav");     }
   void eight(){
       tmrpcm.play("8.wav"); }
          void eightthirty(){
             tmrpcm.play("830.wav"); }
          void nine(){
              tmrpcm.play("9.wav"); }
          void ninethirty(){
             tmrpcm.play("930.wav"); }
          void ten(){
             tmrpcm.play("10.wav"); }
          void tent(){
              tmrpcm.play("1030.wav"); }
          void eleven(){
             tmrpcm.play("11.wav"); }
          void elevent(){
              tmrpcm.play("1130.wav"); }
          void twelve(){
              tmrpcm.play("speak 12.wav"); }
          void one(){
              tmrpcm.play("1.wav"); }
          void onet(){
              tmrpcm.play("130.wav"); }
          void two(){
               tmrpcm.play("2.wav"); }
          void twot(){
                tmrpcm.play("230.wav"); }
          void three(){
                 tmrpcm.play("3.wav"); }
          void threet(){
                tmrpcm.play("330.wav"); }
          void four(){
              tmrpcm.play("4.wav"); }
          void fourt(){
               tmrpcm.play("430.wav"); }
          void five(){
              tmrpcm.play("5.wav"); }
          void fivet(){
               tmrpcm.play("530.wav"); }
          void six(){
              tmrpcm.play("6.wav"); } :(
thank you and more power!!
It is pointless to use the TimeAlarm library when you have a real time clock.
On every pass through loop(), read the time. It the time corresponds to when something should happen, make that something happen.
Did you read the TimeAlarms readme ? There is a limit to how many alarms you can create unless you make a change a variable declaration in the library .h file. Mind you, whether you can create over 70 alarms even with the change is a moot point. You may need to take a different approach.
thon95:
Like a Mega 2560. :slight_smile:
PaulS:
Unless, of course, your coding skills are limited to cut-and-paste.
But to do that would require coding skills beyond cut-and-paste, and here in Arduino-land, we bend over backwards to remove the need for such skills.
Not all of us. Some of us try to get people to think.
