I would like to put time and date inot this code, after the SALES line if possible?
[/#include <LiquidCrystal.h> // include the LCD driver library
//declare variables
float tempC = 0; // Variable for holding Celcius temp (floating for decimal points precision)
float tempf = 0; // variable for holding Fareghneit temp
int tempPin = 0; // Declaring the Analog input to be 0 (A0) of Arduino board.
float samples[8]; // Array to hold 8 samples for Average temp calculation
float maxi = 0,mini = 100; // Max/Min temperature variables with initial values. LM35 in simple setup only measures Temp above 0.
int i;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the library with the numbers of the interface pins
Serial.begin(9600); // Opens serial port, sets data rate to 9600 bps
lcd.begin(16, 2); // Set up the LCD's number of columns and rows:
lcd.setCursor(2, 0); // Set LCD cursor position (column, row)
lcd.print("INSTALLED BY"); // Print text to LCD
lcd.setCursor(0, 1); // Set LCD cursor position (column,row)
lcd.print("EUROTECK SYSTEMS"); // Print text to LCD
delay(3000); // wait 500ms // Delay to read text
lcd.clear(); // clear LCD display // Clear the display
lcd.setCursor(0, 0); // Set LCD cursor position (column, row)
lcd.print("CALL 01827312455"); // Print text to LCD
lcd.print("FOR A ENGINEER"); // Print text to LCD
delay(5000); // wait 500ms // Delay to read text
lcd.setCursor(4, 0); // Set LCD cursor position (column, row)
lcd.print("OR SALES"); // Print text to LCD
delay(2000); // wait 500ms // Delay to read text
Serial.println(""); // Blank line for spacing in the serial monitor
Serial.println("You are looking at a project built by WWC."); // Print text to Serial monitor
Serial.print("Feal free to use and modife as needed.");
Serial.print("LM35 Raw data: "); // Print text to Serial monitor
Serial.println(analogRead(tempPin)); // Displays on serial monitor the sampled value before conversion to real Temperature reading
// Start of calculations FOR loop.
for(i = 0;i<=7;i++){ // gets 8 samples of temperature
samples[i] = ( 4.4 * analogRead(tempPin) * 100.0) / 1024.0; // conversion math of LM35 sample to readable temperature and stores result to samples array.
// 5v is the supply volts of LM35. Change appropriatelly to have correct measurement. My case is 4.4Volts.
// If powered from USB then use value 4.4v to 4.6v. If power is 7v< to the Arduino then use 4.9v to 5.1v
// The voltage is critical for accurate readings
Serial.println(samples[i]); // Print samples [i] to sertiual monitor
// ( LCD note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 0); // Set LCD cursor position (column 0, row 0)
lcd.print("TODAYS TEMP IS: "); // Print text to LCD
lcd.setCursor(5, 1); // Set LCD cursor position (column 1, row 1)
lcd.print(" C "); // Print text to LCD
lcd.setCursor(1, 1); // Set LCD cursor position (column 12, row 1)
lcd.print(samples[i]); // print current Temp sample to LCD
tempC = tempC + samples[i]; // do the addition for average temperature
delay(800); // wait 800ms
} // END of FOR loop
tempC = tempC/8.0; // calculated the averare of 8 samples in Celcius
tempf = (tempC * 9)/ 5 + 32; // converts to fahrenheit
if(tempC > maxi) {maxi = tempC;} // set max temperature
if(tempC < mini) {mini = tempC;} // set min temperature
// Send Results to Serial Monitor
Serial.println("New measurement:");
Serial.print(" Average Temperature in Celcius is " ); // Print text to Serial monitor
Serial.println(tempC);//send the data to the computer // Send the data to the computer
Serial.print(" Average Temperature in Farenait is " ); // Print text to Serial monitor
Serial.println(tempf);//send the data to the computer // Send the data to the computer
Serial.print(" MAX Temperature in Celcius is " ); // Print text to Serial monitor
Serial.println(maxi);//send the data to the computer // Send the data to the computer
Serial.print(" MIN Temperature in Celcius is " ); // Print text to Serial monitor
Serial.println(mini);//send the data to the computer // Send the data to the computer
// Send results to LCD.
lcd.setCursor(6, 1); // Set LCD cursor position (column 0, line 1)
lcd.print(" F "); // Print text to LCD
lcd.setCursor(1, 1); // Set LCD cursor position (column 12, line 1)
lcd.print(tempf); // Send the data to the LCD
delay(5000); // Wait 3 seconds to display the Fahrenheit temp and 3 seconds to display results to LCD screen befor starting the loop again = 6 seconds.
tempC = 0; // Set tempC to 0 so calculations can be done again
lcd.clear(); code]
